Home » Eclipse Projects » Remote Application Platform (RAP) » Problem with TableViewer setAlignment on column
Problem with TableViewer setAlignment on column [message #522986] Wed, 24 March 2010 12:47 Go to next message
There is a problem with the TableViewer.
I set the alignment of a TableColumn (column.setAlignment( SWT.CENTER );)
This works when put some text in the cell. (cell.setText( "someText" );)
But I put an image it the cell (cell.setImage( image );), the image will
always displayed left.
Is this a bug???
to reproduce see rap.demo #controls #Table-Tab
Roland
Re: Problem with TableViewer setAlignment on column [message #522988 is a reply to message #522986] Wed, 24 March 2010 12:55 Go to previous messageGo to next message
Roland,
if I'm not entirely mistaken, this behaviour is intended. The rule of
thumb is, if it works in SWT/RCP, it should work the same in RWT/RAP.
Hence, if you can prove that SWT behaves differently, then please file a
bugzilla.
HTH
Rüdiger
Rüdiger Herrmann
http://eclipsesource.com
On 24.03.2010 17:47, Roland wrote:
> Is this a bug???
> Roland
Re: Problem with TableViewer setAlignment on column [message #523114 is a reply to message #522988] Thu, 25 March 2010 03:49 Go to previous messageGo to next message
I have tested it in SWT and you're right. It shows the same behavior as
in RAP.
But the JavaDoc says:
Controls how text and *images* will be displayed in the receiver. The
argument should be one of LEFT, RIGHT or CENTER.
Strange.
Roland
Am 24.03.2010 17:55, schrieb Rüdiger Herrmann:
> Roland,
> bugzilla.
> HTH
> Rüdiger
Re: Problem with TableViewer setAlignment on column [message #523116 is a reply to message #523114] Thu, 25 March 2010 04:14 Go to previous messageGo to next message
On 25.03.2010 08:49, Roland wrote:
> in RAP.
> Strange.
It may be that SWT behaves differently on different platforms. However,
it could also be a bug in the documentation. If you want to be sure,
search for a bug or newsgroup entry in SWT.
> Roland
>> Roland,
>> bugzilla.
>> HTH
>> Rüdiger
Rüdiger Herrmann
Re: Problem with TableViewer setAlignment on column [message #909827 is a reply to message #523116] Fri, 07 September 2012 17:51 Go to previous messageGo to next message
I hit into the same problem too. Is there a way to align images also in the table cell? The image inside the table is always left-aligned.
Thanks.
Re: Problem with TableViewer setAlignment on column [message #909968 is a reply to message #909827] Sat, 08 September 2012 03:39 Go to previous message
No. This is not possible in the SWT table and it isn't in RAP. But maybe
the markup support added in 1.5 can be an alternative? When you enable
markup for a Table, you can put <img> tags into its text.
HTH, Ralf
Ralf Sternberg
Twitter: @EclipseRAP
Previous Topic:TreeViewer with SWT.VIRTUAL and a ILazyTreeContentProvider weird behaviour
Next Topic:Minimizing, maximizing and restoring views, editors programatically
Current Time: Sat Jul 26 01:11:48 EDT 2025
Powered by FUDForum. Page generated in 0.04919 seconds
