Home » Archived » Buckminster » Buckminster IDE shows me a CSPEC for a Java Project
Buckminster IDE shows me a CSPEC for a Java Project [message #522929] Wed, 24 March 2010 10:48 Go to next message
I was wondering why the Buckminster Eclipse IDE shows me a CSPEC for a Java Project (i.e when I right click on a freshly minted Java Project, then go to Buckminster, then go to "View CSPEC", I actually get what resembles a CSPEC.
What I would like to know is whether I can use this straight off the bat, if the project has dependencies and such?
If not, what work is required in writing the CSPEC for a plain Java Project?
Maybe that is the wrong way to go about it, maybe I should just convert any Java project that I need into a plug-in project? I guess I am sort of thinking about old legacy code that lives in a CVS somewhere.
[Updated on: Wed, 24 March 2010 10:55] by Moderator
Re: Buckminster IDE shows me a CSPEC for a Java Project [message #523008 is a reply to message #522929] Wed, 24 March 2010 14:27 Go to previous message
The CSPEC that ypu get (generated from the information) does not contain
very much information. To add dependencies, you write a '.cspec' file
and place it in the java project.
There is an editor for cspec.
What you can do, and how it works is described in the Buckminster Book
available from the Buckminster download site.
For components where you want to augment/decorate the discovered meta
data, a CSPEX (CSPEC extension) should be used instead of a CSPEC. This
is also described in the book.
I hope this gives you a starting point to explore this further.
- henrik
> resembles a CSPEC.
> Project?
> Thanks
Previous Topic:passing properties file in Hudson's Buckminster plugin
Next Topic:Problem using BundleModel.load()
Current Time: Sun Jun 08 08:39:22 EDT 2025
Powered by FUDForum. Page generated in 0.10368 seconds
