Home » Eclipse Projects » Standard Widget Toolkit (SWT) » ScrolledComposite scrolling in tiny steps if I click in the scroll bar(Question around page-scrolling in a ScrolledComposite)
ScrolledComposite scrolling in tiny steps if I click in the scroll bar [message #521960] Fri, 19 March 2010 09:19 Go to next message
I am trying to use ScrolledComposite with SWT/Eclipse 3.5.2 and was trying out the snippets at http://www.eclipse.org/swt/snippets/#scrolledcomposite
What I found is that each of the snippets shows a strange scrolling behavior. If I click into the scrollbar region, I usually expect the area to scroll by one page. However what happens with ScrolledComposite is that it only scrolls a bit, much less than a page.
I found Bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=39934 which handles this problem, but there no progress since 2004.
I also found http://stackoverflow.com/questions/858591/how-do-you-change- a-scrolledcomposites-horizontal-scroll-increment, which proposes a workaround, however this does not work for me.
What do I need to make this work?
import org.eclipse.swt.*;
import org.eclipse.swt.widgets.*;
import org.eclipse.swt.layout.*;
import org.eclipse.swt.custom.*;
import org.eclipse.swt.events.ControlAdapter;
import org.eclipse.swt.events.ControlEvent;
public class Snippet5_WithPageScroll {
public static void main (String [] args)
    Display display = new Display ();
    Shell shell = new Shell (display);
    shell.setLayout(new FillLayout());
    // this button is always 400 x 400. Scrollbars appear if the window is resized to be
    // too small to show part of the button
    final ScrolledComposite c1 = new ScrolledComposite(shell, SWT.BORDER | SWT.H_SCROLL | SWT.V_SCROLL);
    Button b1 = new Button(c1, SWT.PUSH);
    b1.setText("fixed size button");
    b1.setSize(400, 400);
    c1.setContent(b1);
    shell.addControlListener( new ControlAdapter() {
        public void controlResized( ControlEvent e ) {
            ScrollBar sbX = c1.getHorizontalBar();
            if ( sbX != null ) {
                sbX.setPageIncrement( sbX.getThumb() );
                sbX.setIncrement( Math.max( 1, sbX.getThumb() / 5 ) );
    shell.setSize(600, 300);
    shell.open ();
    while (!shell.isDisposed ()) {
        if (!display.readAndDispatch ()) display.sleep ();
    display.dispose ();
Thanks... Dominik.
Re: ScrolledComposite scrolling in tiny steps if I click in the scroll bar [message #522479 is a reply to message #521960] Mon, 22 March 2010 09:28 Go to previous messageGo to next message
It looks like the ControlListener being added should be more like the
following (?):
c1.addControlListener( new ControlAdapter() {
ScrollBar sbY = c1.getVerticalBar();
if ( sbY != null ) {
sbY.setPageIncrement(c1.getSize().y);
HTH,
Grant
"Dominik Stadler" <dominik.stadler@gmx.at> wrote in message
news:hnvtl1$vrf$1@build.eclipse.org...
> I also found
resized to be
> c1.setContent(b1);
> @Override
> shell.open ();
> display.dispose ();
> Thanks... Dominik.
Re: ScrolledComposite scrolling in tiny steps if I click in the scroll bar [message #522831 is a reply to message #522479] Wed, 24 March 2010 03:02 Go to previous message
Thanks, that pointed me in the right direction, I now call the following in the ControlListener to set this for both horizontal and vertical scrollbar and also for step scrolling, SCROLL_FACTOR is 1 at the moment, but can be adjusted to get more than one page scrolling:
	public static void setScrollbarIncrement(final ScrolledComposite scrolledComposite) {
		ScrollBar sbX = scrolledComposite.getHorizontalBar();
	        sbX.setPageIncrement( Math.round(scrolledComposite.getSize().y*SCROLL_FACTOR) );
	        sbX.setIncrement( Math.max( 1, scrolledComposite.getSize().y / 5 ) );
	    ScrollBar sbY = scrolledComposite.getVerticalBar();
	        sbY.setPageIncrement( Math.round(scrolledComposite.getSize().y*SCROLL_FACTOR) );
	        sbY.setIncrement( Math.max( 1, scrolledComposite.getSize().y / 5 ) );
Thanks... Dominik
Previous Topic:Key Binding problem
Next Topic:Strange behavior of gc.setForeground() and a table in Cocoa SWT
Current Time: Thu Jul 24 00:34:40 EDT 2025
Powered by FUDForum. Page generated in 0.04880 seconds
