Home » Eclipse Projects » Platform - User Assistance (UA) » Trying To Run Infocenter Standalone(java.lang.NoClassDefFoundError: org/eclipse/help/standalone/Help)
Trying To Run Infocenter Standalone [message #522790] Tue, 23 March 2010 18:36 Go to next message
I'm trying to run the infocenter in standalone mode of fedora. I followed the instructions:
Platform Plug-in Developer Guide > Programmer's Guide > User assistance support > Help > Configuration/setup
The launch command I'm running is:
java -classpath /home/ole/Documents/eclipse3/plugins/org.eclipse.help.base_3 .4.0.v20090526 org.eclipse.help.standalone.Help -command displayHelp
I exported the org.eclipse.help feature to the eclipse3 folder prior to running the above command.
When I run the command I get:
Exception in thread "main" java.lang.NoClassDefFoundError: org/eclipse/help/standalone/Help
Caused by: java.lang.ClassNotFoundException: org.eclipse.help.standalone.Help
Any ideas on how to trouble shoot this?
- Ole
Re: Trying To Run Infocenter Standalone [message #522801 is a reply to message #522790] Tue, 23 March 2010 19:01 Go to previous messageGo to next message
Try adding -noexec to the launch command.
I've seen that error before, and I don't recall if I tracked down the
precise cause. I usually always use the -noexec param on my launch
command when I'm running the infocenter on non-Windows platforms. It
then by-passes the eclipse.exe executable to launch the Java class.
Hope that helps,
Lee Anne
Ole Ersoy wrote:
> java -classpath
> - Ole
Re: Trying To Run Infocenter Standalone [message #522806 is a reply to message #522801] Tue, 23 March 2010 19:13 Go to previous messageGo to next message
Lee Anne,
Thanks - I gave it a shot - but still no love. I tried it like this:
java -classpath /home/ole/Documents/eclipse3/plugins/org.eclipse.help.base_3 .4.0.v20090526 org.eclipse.help.standalone.Help -command -noexec displayHelp
And like this:
java -classpath /home/ole/Documents/eclipse3/plugins/org.eclipse.help.base_3 .4.0.v20090526 org.eclipse.help.standalone.Help -command displayHelp -noexec
Ole
Re: Trying To Run Infocenter Standalone [message #523269 is a reply to message #522806] Thu, 25 March 2010 13:47 Go to previous messageGo to next message
Ooops - OK - Just realized I was leaving off the .jar part of the classpath argument. It finds the class now.
- Ole
Re: Trying To Run Infocenter Standalone [message #623969 is a reply to message #522801] Tue, 23 March 2010 19:13 Go to previous messageGo to next message
Lee Anne,
And like this:
Ole
Re: Trying To Run Infocenter Standalone [message #623977 is a reply to message #623969] Thu, 25 March 2010 13:47 Go to previous message
- Ole
Previous Topic:adding infocenters to search scope : works in 3.5 broken in in 3.4 ?
Next Topic:Disabling/removing the Index tab in plug-in help?
Current Time: Sat Jul 26 16:55:39 EDT 2025
Powered by FUDForum. Page generated in 0.04021 seconds
