Home » Modeling » UML2 » Storing aggregation property in .uml file
Storing aggregation property in .uml file [message #522770] |
Tue, 23 March 2010 17:15  |
Hi all,
I was looking at the xml model representation stored in the .uml file for a simple class diagram containing two classes ("whole" and "part") linked by a composite relationship IsPartOf (diamond next to the "whole" side, a "whole" can contain between 3 and "*" parts).
Everything seemed normal until I realized that the "whole" association end had the right name, type and cardinality but no information about the composition. Surprisingly (to me) the information describing that the association is a composition was stored in the opposite association end (the "part" end). See the XML excerpt below.
This does not seem right to me (and in fact, different from the XML/XMI generated by other modeling tools). So, I'd like to know if you think this is correct, and if so why this is done this way. What am I missing?
<packagedElement xmi:type="uml:Class" xmi:id="_OUqi0DYVEd-QwOAQi-R_Aw" name="Whole"/>
<packagedElement xmi:type="uml:Class" xmi:id="_RiS8cDYVEd-QwOAQi-R_Aw" name="Part"/>
<packagedElement xmi:type="uml:Association" xmi:id="_Ue860DYVEd-QwOAQi-R_Aw" name="IsPartOf" memberEnd="_Ue860TYVEd-QwOAQi-R_Aw _Ue861DYVEd-QwOAQi-R_Aw">
<ownedEnd xmi:id="_Ue860TYVEd-QwOAQi-R_Aw" name="whole" type="_OUqi0DYVEd-QwOAQi-R_Aw" association="_Ue860DYVEd-QwOAQi-R_Aw">
<upperValue xmi:type="uml:LiteralUnlimitedNatural" xmi:id="_Ue860zYVEd-QwOAQi-R_Aw" value="1"/>
<lowerValue xmi:type="uml:LiteralInteger" xmi:id="_Ue860jYVEd-QwOAQi-R_Aw" value="1"/>
</ownedEnd>
<ownedEnd xmi:id="_Ue861DYVEd-QwOAQi-R_Aw" name="part" type="_RiS8cDYVEd-QwOAQi-R_Aw" aggregation="composite" association="_Ue860DYVEd-QwOAQi-R_Aw">
<upperValue xmi:type="uml:LiteralUnlimitedNatural" xmi:id="_Ue861jYVEd-QwOAQi-R_Aw" value="*"/>
<lowerValue xmi:type="uml:LiteralInteger" xmi:id="_Ue861TYVEd-QwOAQi-R_Aw" value="3"/>
</ownedEnd>
</packagedElement>
Re: Storing aggregation property in .uml file [message #522784 is a reply to message #522770] |
Tue, 23 March 2010 18:15   |
Hi, Jordi,
In UML2, the aggregation semantics is an attribute of the Property "of"
the the aggregating type. I say "of" in quotation marks because often
the composite end will actually be an owned attribute of the composing
classifier.
That is to say, in terms of your scenario, the 'Whole' class "has" an
association-end 'part' that provides the Parts that a Whole composes.
It is also common that the association will not own the 'part' end, but
the Whole class will own it. But, that is not necessary.
The point is, that the relationship of a Whole to a Part is
characterized as a composite aggregation, so in the UML2 that is
expressed as an attribute of the 'part' association end that navigates
from the Whole to the Part.
HTH,
Christian
On 23/03/10 05:15 PM, Jordi Cabot wrote:
> Hi all,
> name="Whole"/>
> name="Part"/>
> </ownedEnd>
> </ownedEnd>
> </packagedElement>
Re: Storing aggregation property in .uml file [message #522789 is a reply to message #522784] |
Tue, 23 March 2010 18:17   |
I should mention, additionally, that the XMI you showed is in exact
concordance with the in-memory representation, and thus what you would
see using the Eclipse UML2 API to inspect the model.
This is all in agreement with the UML 2.x metamodel.
Christian
On 23/03/10 06:15 PM, Christian W. Damus wrote:
> Hi, Jordi,
> classifier.
> association-end 'part' that provides the Parts that a Whole composes. It
> is also common that the association will not own the 'part' end, but the
> HTH,
> Christian
--------8<--------
Re: Storing aggregation property in .uml file [message #522947 is a reply to message #522788] |
Wed, 24 March 2010 11:31  |
Hi Jordi
I can confirm that what Christian mentioned is indeed correct ( and very
beautifully put also ).
You may want to convince yourself by looking at chapter 7 in the
Superstructure spec. (section 7.3.2 ).
- James.
"Jordi Cabot" <jordi.cabot@inria.fr> wrote in message
news:hobf9p$b1$1@build.eclipse.org...
> Hi Christian,
> Thanks for your quick answer. I'm afraid I'm still not convinced. I think
> it is counterintuitive that all the properties that a user sees
> graphically depicted next to an association end (like cardinality and name
> of the association end) are stored in the XMI section corresponding to
> that end except one, the aggregation property that it is stored in the
> opposite end.
> However, the last thing I want is to start a discussion about UML
> semantics here (and I'm not even sure that the decision on where to add
> the "aggregation" attribute in the .uml file has to do with the
> semantics). My goals is to parse .uml files so I just wanted to confirm
> that this was the selected representation for aggregation/compositions in
> the .uml file and not a mysterious error in my model.
> From your answer I take that this is the desired behaviour so thanks again
> for clarifying this point. I'll just follow this structure in my program.
Re: Storing aggregation property in .uml file [message #628337 is a reply to message #522784] |
Christian
> Hi, Jordi,
> classifier.
> HTH,
> Christian
--------8<--------
Re: Storing aggregation property in .uml file [message #628338 is a reply to message #522784] |
Tue, 23 March 2010 18:28  |
Hi Christian,
Thanks for your quick answer. I'm afraid I'm still not convinced. I think it is counterintuitive that all the properties that a user sees graphically depicted next to an association end (like cardinality and name of the association end) are stored in the XMI section corresponding to that end except one, the aggregation property that it is stored in the opposite end.
However, the last thing I want is to start a discussion about UML semantics here (and I'm not even sure that the decision on where to add the "aggregation" attribute in the .uml file has to do with the semantics). My goals is to parse .uml files so I just wanted to confirm that this was the selected representation for aggregation/compositions in the .uml file and not a mysterious error in my model.
From your answer I take that this is the desired behaviour so thanks again for clarifying this point. I'll just follow this structure in my program.
Re: Storing aggregation property in .uml file [message #628342 is a reply to message #628338] |
Hi Jordi
- James.
> Hi Christian,
> opposite end.
Current Time: Wed Jul 23 06:45:57 EDT 2025
Powered by FUDForum. Page generated in 0.07278 seconds
