Home » Modeling » Epsilon » [ETL] Accesing existing output model elements
icon5.gif  [ETL] Accesing existing output model elements [message #522714] Tue, 23 March 2010 13:25 Go to next message
I am working on a ETL rule that creates elements on an output model that already has some elements on it. Some of the existent elements and the new ones need a consecutive id number, so I need to collect all the elements of type IdElement to get a list of existing ids and use the next one. My problem seems that I can not access the existent elements of the output model. I use read on load and store on disposal and new elements are indeed created. Any idea on how to access existent elements?
Re: [ETL] Accesing existing output model elements [message #522726 is a reply to message #522714] Tue, 23 March 2010 13:57 Go to previous messageGo to next message
Hi Horacio,
If your target model is named Target, you should be able to get all
elements of type IdElement using Target!IdElement.all. What does
Target!IdElement.all.println() print?
Dimitris
Spread the word: http://www.eclipse.org/gmt/epsilon/spreadtheword
Follow Epsilon on Twitter: http://twitter.com/epsilonews
Re: [ETL] Accesing existing output model elements [message #522748 is a reply to message #522726] Tue, 23 March 2010 16:01 Go to previous messageGo to next message
Hi Dimitris,
This is what I get: Sequence {}
I have tried with different element types and all return an empty set. The only thing that seems to return something is if I get the elements of the type the rule has as output, which returns 1 element, the one I am creating?
Re: [ETL] Accesing existing output model elements [message #522751 is a reply to message #522748] Tue, 23 March 2010 16:03 Go to previous messageGo to next message
Hi Horacio,
Metamodel(s), sample input model and transformation are then due I guess :)
Dimitris
Horacio wrote:
> Hi Dimitris,
> am creating?
> Cheers,
Re: [ETL] Accesing existing output model elements [message #525425 is a reply to message #522751] Tue, 06 April 2010 10:34 Go to previous messageGo to next message
I have tried to test this to see if somehow I managed to see the elements. Looking at the documentation I did a small eol test:
base!Font.all().println();
var f : new base!Font;
base.allContents().println();
For which I get the next console output:
Sequence {}
Sequence {Font [id=null, color=null, faceName=null, pointSize=null]}
Sequence {DocumentRoot [mixed=[ecore.xml.type:text=
], ], EStringToStringMapEntry [key=xmi, value=http://www.omg.org/XMI], EStringToStringMapEntry [key=xsi, value=http://www.w3.org/2001/XMLSchema-instance], EStringToStringMapEntry [key=tdml, value=http://moosas.uniandes.edu.co/HiLeSPL/tdml], Font [id=null, color=null, faceName=null, pointSize=null]}
If I look at the xml of the base model I see:
<?xml version="1.0" encoding="ASCII"?>
<xmi:XMI xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:tdml="http://moosas.uniandes.edu.co/HiLeSPL/tdml">
  <tdml:TimingDiagram defaultTimeUnits="1e-6" delayRule="first" fontPtr="HL4" lineThickness="1" showDelays="1" showHolds="1" showSamples="1" showSetups="1" showUncertainty="ALL">
  <tdmlAdminInfo>
Comparing it to the console output it would seem that only the model information is beeing loaded (the xmi description) and not the element information.
Hope this helps.
Re: [ETL] Accesing existing output model elements [message #525461 is a reply to message #525425] Tue, 06 April 2010 12:05 Go to previous messageGo to next message
Hi Horacio,
Not sure why this might be happening. Could you please zip and send me
your metamodels/models/transformations so that I can have a closer look
at this?
Dimitris
On 06/04/2010 17:34, Horacio wrote:
> Hello,
> Sequence {}
> <tdmlAdminInfo>
> information.
> Hope this helps.
Re: [ETL] Accesing existing output model elements [message #525676 is a reply to message #525461] Wed, 07 April 2010 08:56 Go to previous messageGo to next message
Dimitris,
I sent you the files to your gmail account the 23 of March from h.hoyos95 at uniandes dot edu dot co. Please tell me if you received them or if I send them to another account.
Re: [ETL] Accesing existing output model elements [message #525681 is a reply to message #525676] Wed, 07 April 2010 09:00 Go to previous message
Hi Horacio,
You're right. I somehow managed to miss it :S Sorry about that. I'll
have a look at this tomorrow (it's a pretty busy day today) and get back
to you.
Dimitris
On 07/04/2010 15:56, Horacio wrote:
> Dimitris,
> Regards,
Re: [ETL] Accesing existing output model elements [message #587617 is a reply to message #522726] Tue, 23 March 2010 16:01 Go to previous message
Hi Dimitris,
Horacio Hoyos Rodriguez
Research Assistant
Universidad de los Andes
Re: [ETL] Accesing existing output model elements [message #587621 is a reply to message #522748] Tue, 23 March 2010 16:03 Go to previous message
Hi Horacio,
Dimitris
Horacio wrote:
> Hi Dimitris,
> am creating?
> Cheers,
Re: [ETL] Accesing existing output model elements [message #588182 is a reply to message #522751] Tue, 06 April 2010 10:34 Go to previous message
Sequence {}
<tdmlAdminInfo>
Hope this helps.
Research Assistant
Re: [ETL] Accesing existing output model elements [message #588190 is a reply to message #588182] Tue, 06 April 2010 12:05 Go to previous message
Hi Horacio,
at this?
Dimitris
> Hello,
> Sequence {}
> <tdmlAdminInfo>
> information.
> Hope this helps.
Re: [ETL] Accesing existing output model elements [message #588196 is a reply to message #525461] Wed, 07 April 2010 08:56 Go to previous message
Dimitris,
Research Assistant
Re: [ETL] Accesing existing output model elements [message #588205 is a reply to message #525676] Wed, 07 April 2010 09:00 Go to previous message
Hi Horacio,
to you.
Dimitris
> Dimitris,
> Regards,
Previous Topic:ETL question
Next Topic:Accessing Enum Literals from ETL
Current Time: Fri Jul 25 21:48:57 EDT 2025
Powered by FUDForum. Page generated in 0.06310 seconds
