Home » Archived » BIRT » Newbie problem with BIRT using POJO's
Newbie problem with BIRT using POJO's [message #521908] Fri, 19 March 2010 00:22 Go to next message
I'm new to BIRT and have downloaded the Report Desginer Full Eclipse
Install. I am trying to create reports using POJO (I'm using a scripted data
source) by following Lars Vogel's tutorial "Reporting with Eclipse BIRT and
Java Objects (POJO's)"
( http://www.vogella.de/articles/EclipseBIRT/article.html#birt deploying_rcp)
and it works fine in a demo RCP project that I have created. However, if I
try to create/move the data-access and model Java files and the .rptdesign
file to another RCP project that I am working on, I get the following error
message when I try to preview the results by double clicking on the data
set-
"A BIRT exception occurred.
Plug-in Provider:Eclipse.org
Plug-in Name:BIRT Data Engine
Plug-in ID:org.eclipse.birt.data
Version:2.3.2.r232_v20090521
Error
Code:data.engine.BirtException
Error Message:A BIRT exception occurred: There are errors evaluating
script "__bm_open()":
TypeError: [JavaPackage reportDataPackage.StockDaoMock]
is not a function, it is org.mozilla.javascript.NativeJavaPackage.
(<inline>#4).. See next exception for more information.
There are errors evaluating script "__bm_open()":
TypeError: [JavaPackage reportDataPackage.StockDaoMock] is not a function,
it is org.mozilla.javascript.NativeJavaPackage. (<inline>#4).
Could someone please help me out with this problem?
Re: Newbie problem with BIRT using POJO's [message #522005 is a reply to message #521908] Fri, 19 March 2010 11:33 Go to previous messageGo to next message
Nikita,
This looks like a classpath issue. What does your scripted dataset code
look like?
Jason
Nikita wrote:
> set-
> Error
Re: Newbie problem with BIRT using POJO's [message #522154 is a reply to message #522005] Sat, 20 March 2010 11:47 Go to previous messageGo to next message
Hi Jason,
I've created 2 packages, reportDataPackage and reportModelPackage, in the
src package and placed the data access class (StockDaoMock.java) and the
model class (StockData.java) in those two packages respectively.
The code in the open script is as follows-
count = 0;
gsh = new Packages.reportDataPackage.StockDaoMock();
stock = gsh.getStockValues("Java");
and the code in the fetch script is-
if(count < stock.size()){
row["columnDate"] = stock.get(count).getDate();
row["columnOpen"] = stock.get(count).getOpen();
row["columnHigh"] = stock.get(count).getHigh();
row["columnLow"] = stock.get(count).getLow();
row["columnClose"] = stock.get(count).getClose();
row["columnVolume"] = stock.get(count).getVolume();
count++;
return true;
return false;
This is exactly what I'd done in the sample project I'd created too...But
when I moved these files to the existing project I'm working on, I got this
error.
"Jason Weathersby" <jasonweathersby@windstream.net> wrote in message
news:ho05a3$jnv$1@build.eclipse.org...
> Nikita,
> look like?
> Jason
> Nikita wrote:
>> Hi,
>> data source) by following Lars Vogel's tutorial "Reporting with Eclipse
>> BIRT and Java Objects (POJO's)"
>> I try to create/move the data-access and model Java files and the
>> .rptdesign file to another RCP project that I am working on, I get the
>> following error message when I try to preview the results by double
>> clicking on the data set-
>> Error
>> function, it is org.mozilla.javascript.NativeJavaPackage. (<inline>#4).
Re: Newbie problem with BIRT using POJO's [message #522381 is a reply to message #522154] Mon, 22 March 2010 05:18 Go to previous messageGo to next message
Nikita,
How do you have the reportDataPackage and reportModelPackage jars in the
classpath?
you can also try importPackage( Pacakges.reportDataPackage );
gsh = new StockDaoMock();
Jason
Nikita wrote:
> Hi Jason,
> count = 0;
> count++;
> return true;
> return false;
> error.
>> Nikita,
>> look like?
>> Jason
>> Nikita wrote:
>>> Hi,
>>> Error
Re: Newbie problem with BIRT using POJO's [message #522611 is a reply to message #522381] Tue, 23 March 2010 06:26 Go to previous messageGo to next message
Hi Jason,
The reportDataPackage and reportModelPackage are packages that I've created
in the src package in the same project that contains the .rptdesign file.
These packages contain the source files (data and model) containing the data
for creating the report. In this case why is it necessary to have the jars
in the classpath?
I've tried out this method too-using the importPackage statement..But I'm
still getting an error, this time its as follows-
Error Code:data.engine.BirtException
ReferenceError: "StockDaoMock" is not defined.
(<inline>#6).. See next exception for more information.
ReferenceError: "StockDaoMock" is not defined. (<inline>#6).
news:ho7t43$bde$3@build.eclipse.org...
> Nikita,
> classpath?
> Jason
> Nikita wrote:
>> Hi Jason,
>> count = 0;
>> count++;
>> return true;
>> return false;
>> this error.
>>> Nikita,
>>> look like?
>>> Jason
>>> Nikita wrote:
>>>> Hi,
>>>> if I try to create/move the data-access and model Java files and the
>>>> Error
Re: Newbie problem with BIRT using POJO's [message #522955 is a reply to message #522611] Wed, 24 March 2010 11:44 Go to previous messageGo to next message
Nikita,
It is because the BIRT runtime uses OSGi. Can you try to create a
report project in the same workspace as the java project. The BIRT
runtime in 2.3.2 should search for java projects in the same workspace.
In BIRT 2.5.2 you have to specify addition projects, but in 2.3.2 it
automatically searches all java projects for classes.
Jason
Nikita wrote:
> Hi Jason,
> in the classpath?
>> Nikita,
>> classpath?
>> Jason
>> Nikita wrote:
>>> Hi Jason,
>>> count = 0;
>>> count++;
>>> return true;
>>> return false;
>>> this error.
>>>> Nikita,
>>>> look like?
>>>> Jason
>>>> Nikita wrote:
>>>>> Hi,
>>>>> Error
Re: Newbie problem with BIRT using POJO's [message #523963 is a reply to message #522955] Mon, 29 March 2010 20:18 Go to previous message
Thanks Jason... I'll try that out..
news:hodc03$fsu$3@build.eclipse.org...
> Nikita,
> It is because the BIRT runtime uses OSGi. Can you try to create a report
> project in the same workspace as the java project. The BIRT runtime in
> 2.3.2 should search for java projects in the same workspace. In BIRT 2.5.2
> you have to specify addition projects, but in 2.3.2 it automatically
> Jason
> Nikita wrote:
>> Hi Jason,
>> created in the src package in the same project that contains the
>> .rptdesign file. These packages contain the source files (data and model)
>> containing the data for creating the report. In this case why is it
>> necessary to have the jars in the classpath?
>>> Nikita,
>>> classpath?
>>> Jason
>>> Nikita wrote:
>>>> Hi Jason,
>>>> the src package and placed the data access class (StockDaoMock.java)
>>>> and the model class (StockData.java) in those two packages
>>>> respectively.
>>>> count = 0;
>>>> count++;
>>>> return true;
>>>> return false;
>>>> too...But when I moved these files to the existing project I'm working
>>>> on, I got this error.
>>>>> Nikita,
>>>>> code look like?
>>>>> Jason
>>>>> Nikita wrote:
>>>>>> Hi,
>>>>>> scripted data source) by following Lars Vogel's tutorial "Reporting
>>>>>> with Eclipse BIRT and Java Objects (POJO's)"
>>>>>> the following error message when I try to preview the results by
>>>>>> double clicking on the data set-
>>>>>> Error
>>>>>> (<inline>#4).
Previous Topic:Export to Excel
Next Topic:Plot 2D point in line chart with multiple curves?
Current Time: Fri Jul 18 20:23:18 EDT 2025
Powered by FUDForum. Page generated in 0.08401 seconds
