Home » Archived » Test and Performance Tools Platform (TPTP) » Build path contains duplicate entry(Buld Path contains duplicate entry)
Build path contains duplicate entry [message #522600] Tue, 23 March 2010 06:33 Go to next message
Hi, I am trying to debug a problem I encountered with using my generic log adapter to import a log file into the Log Trace Analyzer. So I checked out org.eclipse.hyades.logging.adapter from /cvsroot/tptp/monitoring into a java project. When I try to build the project, I got the following error:
Build path contains duplicate entry: 'root/ibm/isa41/applications/eclipse/plugins/com.ibm.etools. ac.rcpla.linux_4.5.0.200909240916/plugins/org.eclipse.tptp.p latform.agentcontroller_4.2.200.v200806162043/config.jar' for project 'org.eclipse.hyades.logging.adapter'
Could some one let me know how to find out what's wrong?
" /root/ibm/isa41/applications/eclipse/plugins/com.ibm.etools. ac.rcpla.linux_4.5.0.200909240916 " is the Location in my Target Platorm specification of Plugin Development.
Appreciate your help. Thanks
Re: Build path contains duplicate entry [message #523091 is a reply to message #522600] Wed, 24 March 2010 21:41 Go to previous messageGo to next message
I found and fixed the problem:
1. right clicked the project->Build Path->Configure Build Path
2. In the Libraries tab, under Plugin-Dependencies, I found the duplicate entry.
3. Remove the dependency in PDE Tools->Open Manifest->dependencies, this removed the last of the duplicate entry.
Re: Build path contains duplicate entry [message #523613 is a reply to message #523091] Sat, 27 March 2010 04:31 Go to previous message
Sorry, for #3 in my last post, it should be in the "build" tab rather than the "dependencies" tab where I removed the Extra Classpath entries.
Previous Topic:Use TPTP to profile TOMCAT server remotely
Next Topic:TPTP and OSGi
Current Time: Thu Nov 06 00:34:21 EST 2025
Powered by FUDForum. Page generated in 0.03446 seconds
