Home » Language IDEs » Java Development Tools (JDT) » Change one file but must do clean on project
Change one file but must do clean on project [message #522464] Mon, 22 March 2010 13:36 Go to next message
I am using Eclipse 3.5 (eclipse-java-galileo-SR2-linux) for a java project. I make a change to one file and then I compile. The change I have made in the code is not built/compiled. It is still using the old version. However when I am making a clean on the project and then build/compile I get the changed code. I would do a clean all the time but it takes a lot of time. I can see that when I am building after a clean there is some copying of resources. And it takes forever....
Any idea how I can avoid this?
br,
//mike
Re: Change one file but must do clean on project [message #522482 is a reply to message #522464] Mon, 22 March 2010 09:32 Go to previous messageGo to next message
Originally posted by: richkulp.us.NOSPAM.ibm.com
Are you sure you have incremental build turned on?
Rich Kulp
Re: Change one file but must do clean on project [message #522571 is a reply to message #522482] Tue, 23 March 2010 04:05 Go to previous messageGo to next message
Thanks for reply. Where can I check that in Eclipse?
br,
//mike
Re: Change one file but must do clean on project [message #522728 is a reply to message #522571] Tue, 23 March 2010 13:45 Go to previous messageGo to next message
Bring down the Project menu and see if "Build automatically" is checked.
Rich Kulp
Re: Change one file but must do clean on project [message #522871 is a reply to message #522464] Wed, 24 March 2010 00:50 Go to previous message
Enable "Build automatically" (as Rich says) and be sure you don't have
buildpath problems on your project.
Mauro.
Previous Topic:Update CDT to JDT
Next Topic:Introduce Indirection does nothing on a .class file
Current Time: Sun Jul 20 22:07:59 EDT 2025
Powered by FUDForum. Page generated in 0.06386 seconds
