Home » Eclipse Projects » Eclipse 4 » problem opening Application.e4xmi in e4 windows 64bit
problem opening Application.e4xmi in e4 windows 64bit [message #522061] Fri, 19 March 2010 15:14 Go to next message
I've installed 2 versions of e4 on my Vista 64 bit:
eclipse-e4-SDK-incubation-I20100318-2100-win32-x86_64
eclipse-e4-SDK-incubation-1.0M4-win32-x86_64
I've tried sample e4 projects and creating new e4 projects on both installations, but whenever I try to open the Application.e4xmi file using the e4 Workbench Designer it just opens with a blank white interface (doesn't look like the screenshots of other OSes with the gui layout stuff).
Is this a known issue or is there a newer plugin I need on 64 bit for it to behave like the screenshots from the mac and 32 bit versions I've seen?
Todd
Re: problem opening Application.e4xmi in e4 windows 64bit [message #522107 is a reply to message #522061] Fri, 19 March 2010 17:22 Go to previous messageGo to next message
try the reflective EMF editor or a text editor, as described also here:
http://www.vogella.de/articles/EclipseE4/article.html
Best regards, Lars
> layout stuff).
> Todd
Re: problem opening Application.e4xmi in e4 windows 64bit [message #522110 is a reply to message #522107] Fri, 19 March 2010 22:23 Go to previous messageGo to next message
Hi Lars,
Thanks for the feedback. I've tried both the Sample Reflective Ecore Model Editor and a text editor with no troubles. It's only the e4 Workbench Designer that's not working. I couldn't find a bug report or find any posts from anyone else experiencing this issue on Windows 64 bit, so I was curious whether it was just me or if there are others that can't use the Workbench Designer then I would report a bug on Bugzilla.
Todd
Re: problem opening Application.e4xmi in e4 windows 64bit [message #522412 is a reply to message #522110] Mon, 22 March 2010 11:14 Go to previous messageGo to next message
Todd Wilson wrote on Fri, 19 March 2010 22:23
Best to just get a 32-bit build and a 32-bit JRE and see if that works out for you. That would narrow down some variables.
Re: problem opening Application.e4xmi in e4 windows 64bit [message #571363 is a reply to message #522110] Mon, 22 March 2010 11:14 Go to previous message
Previous Topic:Call XWT.findElementByName Method in User-Interface Thread
Next Topic:Call XWT.findElementByName Method in User-Interface Thread
Current Time: Fri Jul 25 22:21:05 EDT 2025
Powered by FUDForum. Page generated in 0.04820 seconds
