Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Excel ActiveX DisplayAlerts property
Excel ActiveX DisplayAlerts property [message #521824] Thu, 18 March 2010 15:37 Go to next message
Hi all,
I would like to set the DisplayAlerts property on an Excel ActiveX
object embedded in an application I have. However, when I try to set the
property it remains unchanged. I am using Windows XP with Excel 2003.
Here is a snippet that illustrates the problem.
import org.eclipse.swt.SWT;
import org.eclipse.swt.SWTError;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.ole.win32.OLE;
import org.eclipse.swt.ole.win32.OleAutomation;
import org.eclipse.swt.ole.win32.OleControlSite;
import org.eclipse.swt.ole.win32.OleFrame;
import org.eclipse.swt.ole.win32.Variant;
import org.eclipse.swt.widgets.Shell;
public class DisplayAlertsSnippet {
Display display = new Display();
Shell shell = new Shell(display);
shell.setLayout(new FillLayout());
OleControlSite controlSite;
try {
OleFrame frame = new OleFrame(shell, SWT.NONE);
controlSite = new OleControlSite(frame, SWT.NONE, "Excel.Sheet");
controlSite.doVerb(OLE.OLEIVERB_INPLACEACTIVATE);
} catch (SWTError e) {
System.out.println("Unable to open activeX control");
display.dispose();
return;
shell.open();
OleAutomation excelSheet = new OleAutomation(controlSite);
int[] dispIDs = excelSheet.getIDsOfNames(new String[] { "Application" });
Variant pVarResult = excelSheet.getProperty(dispIDs[0]);
OleAutomation application = pVarResult.getAutomation();
displayAlerts(application, false);
pVarResult.dispose();
excelSheet.dispose();
while (!shell.isDisposed()) {
if (!display.readAndDispatch())
display.sleep();
application.dispose();
display.dispose();
private static void displayAlerts(OleAutomation application, boolean
display) {
int[] dispIds = application.getIDsOfNames(new String[]{"DisplayAlerts"});
System.out.println("DisplayAlerts dispId " + dispIds[0]);
Variant result = application.getProperty(dispIds[0]);
System.out.println("DisplayAlerts before setting property = " + result);
result.dispose();
Variant variant = new Variant(display);
application.setProperty(dispIds[0], variant);
variant.dispose();
System.out.println("DisplayAlerts after setting property = " + result);
result.dispose();
The output from the snippet is as follows.
DisplayAlerts dispId 343
DisplayAlerts before setting property = VT_BOOL{true}
DisplayAlerts after setting property = VT_BOOL{true}
Is there anyone out there that has successfully managed to do this?
Paul
Re: Excel ActiveX DisplayAlerts property [message #522457 is a reply to message #521824] Mon, 22 March 2010 12:36 Go to previous messageGo to next message
Hi Paul,
I see the same behaviour, but unfortunately don't know why this is
happening. However a google search of "excel cannot set DisplayAlerts"
finds several other posts with a similar problem in non-swt contexts, so I
don't think it's an swt problem. Hopefully one of them has a follow-up that
can help with your case.
Grant
"Paul Watson" <pablowatson@gmail.com> wrote in message
news:hntvcu$pu8$1@build.eclipse.org...
> Hi all,
> import org.eclipse.swt.widgets.Display;
> public static void main(String[] args) {
> try {
> display.dispose();
> return;
> shell.open();
> display.sleep();
> display.dispose();
> display) {
> result.dispose();
> variant.dispose();
> result.dispose();
> Cheers,
> Paul
Re: Excel ActiveX DisplayAlerts property [message #522468 is a reply to message #522457] Mon, 22 March 2010 13:44 Go to previous message
Hi Grant,
Thanks for the suggestion. I think I found out what the problem is. This
is one of the application properties you cannot set until you have made
the application 'visible'. The follow snippet will let you set the
display alerts property, but at the rather ugly cost of flashing the
Excel application window.
try {
display.dispose();
return;
shell.open();
setVisible(application, true);
setVisible(application, false);
display.sleep();
display.dispose();
private static void setVisible(OleAutomation application, boolean
visible) {
int[] dispIds = application.getIDsOfNames(new String[]{"Visible"});
System.out.println("Visible dispId " + dispIds[0]);
application.setProperty(dispIds[0], new Variant(visible));
display) {
result.dispose();
variant.dispose();
result.dispose();
// Set it back to true, otherwise the Excel process that never dies
will have the property set to false.
application.setProperty(dispIds[0], new Variant(true));
On 3/22/2010 9:36 AM, Grant Gayed wrote:
> Hi Paul,
> Grant
> "Paul Watson"<pablowatson@gmail.com> wrote in message
>> Hi all,
>> try {
>> display.dispose();
>> return;
>> shell.open();
>> display.sleep();
>> display.dispose();
>> display) {
>> result.dispose();
>> variant.dispose();
>> result.dispose();
>> Cheers,
>> Paul
Previous Topic:Add border to sourceviewer
Next Topic:OLE Understanding Excel Automation
Current Time: Wed Sep 17 13:59:20 EDT 2025
Powered by FUDForum. Page generated in 0.03236 seconds
