Home » Archived » B3 » Using p2 model to generate a p2 site
Using p2 model to generate a p2 site [message #521750] Thu, 18 March 2010 12:33 Go to next message
I am about to start implementing p2 publishing support in b3 engine.
My approach is to use the p2 ecore model in the aggregator, and hoping
that there is code there that I can just call.
Two questions...
- The p2 model is nested at the moment. Should we break it out into its
own bundle?
- Once I have populated a p2 model, how to I write it out as a "p2 repo
on disk" ?
- henrik
Re: Using p2 model to generate a p2 site [message #522900 is a reply to message #521750] Wed, 24 March 2010 08:47 Go to previous messageGo to next message
Sorry for late answer. Comments inside. I can help with implementing the changes if you like.
Filip
Henrik Lindberg wrote:
> Two questions...
> own bundle?
Yes, I think that it would be nice to share one common p2 model for everything in b3.
> on disk" ?
Currently we can only read a p2 repository into the model. We have "importToModel" methods which scan the original p2 structure and copy it into the EMF model. Perhaps we need to write inverse methods to push the model into a native p2 repository instance to be able to store it.
Re: Using p2 model to generate a p2 site [message #523010 is a reply to message #522900] Wed, 24 March 2010 09:44 Go to previous messageGo to next message
> Filip
>> Hi,
>> Two questions...
>> own bundle?
> everything in b3.
I logged this issue:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=306979
>> on disk" ?
....and this issue
https://bugs.eclipse.org/bugs/show_bug.cgi?id=306980
- henrik
Re: Using p2 model to generate a p2 site [message #603463 is a reply to message #521750] Wed, 24 March 2010 08:47 Go to previous messageGo to next message
Filip
> Two questions...
> own bundle?
> on disk" ?
Re: Using p2 model to generate a p2 site [message #603469 is a reply to message #522900] Wed, 24 March 2010 14:34 Go to previous message
> Filip
>> Hi,
>> Two questions...
>> own bundle?
> everything in b3.
>> on disk" ?
....and this issue
- henrik
Previous Topic:URL of update site is worng
Next Topic:newversion of b3 book uploaded
Current Time: Fri Jul 25 06:44:54 EDT 2025
Powered by FUDForum. Page generated in 0.08312 seconds
