Home » Eclipse Projects » GEF » Drag and Drop between Views
Drag and Drop between Views [message #52144] Thu, 02 January 2003 11:31 Go to next message
Hello!
There seem to be 2 different kinds of Drag'nDrop in GEF:
1. Inside one viewer- no problems there
2. between different viewers / forms / windows
(Like the templates from the logic example palette)
Both kinds use a DragEditPartsTracker, but in case one, the state changes to
4 on movement
while in case 2 is the state will be 2 till the drop.
Only case 2 will print Drag Events in the debug window.
What is the difference and how can I tell my EditParts to use the second
kind?
Thanks for any help,
Manfred Goetz.
Re: Drag and Drop between Views [message #52223 is a reply to message #52144] Fri, 03 January 2003 12:59 Go to previous message
Originally posted by: hudsonr.us.eye-bee-em.com
When using native drag and drop, the DragEditPartsTracker is not used to
perform the drag. Its function is simply to select the EditPart on mouse
down. It gets unloaded immediately if a native drag begins.
"Manfred Goetz" <xgoetz@de.ibm.com> wrote in message
news:av4d93$uer$1@rogue.oti.com...
> Hello!
to
> 4 on movement
> kind?
> Manfred Goetz.
Previous Topic:selection problem
Next Topic:Need help with ZOOM implementation
Current Time: Thu Nov 06 20:36:34 EST 2025
Powered by FUDForum. Page generated in 0.03911 seconds
