Home » Archived » Buckminster » Downloading/installing buckminster through the director: Unpack facility not configured
Downloading/installing buckminster through the director: Unpack facility not configured [message #521349] Wed, 17 March 2010 07:12 Go to next message
I am using buckminster for the eclipse.org hudson build. When updating to the latest buckminster build and trying to
download it I get this exception. I think it is a director/p2 issue but maybe someone here has encountered the same
issue and solved it.
See here for the complete log:
https://build.eclipse.org/hudson/job/emft-texo-nightly/72/co nsole
Is this a buckminster thing? Or maybe a director issue?
[echo] Configuring headless buckminster with needed features
[java] Installing org.eclipse.buckminster.cmdline.product 1.2.0.r11290.
[java] Installing org.eclipse.buckminster.core.headless.feature.feature.group 1.3.0.r11313.
[java] Installing org.eclipse.buckminster.pde.headless.feature.feature.group 1.2.0.r11295.
[java] Installing org.eclipse.buckminster.cvs.headless.feature.feature.group 1.1.0.r11210.
[java] Installing org.eclipse.buckminster.emma.headless.feature.feature.group 0.9.0.r11256.
[java] An error occurred while collecting items to be installed
[java] session context was:(profile=Buckminster,
phase=org.eclipse.equinox.internal.provisional.p2.engine.pha ses.Collect, operand=, action=).
[java] Result of processing steps.
[java] Unpack facility not configured
[java] OK
[java] OK
[java] OK
[java] OK
[java] OK
[java] OK
[java] OK
[java] OK
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Downloading/installing buckminster through the director: Unpack facility not configured [message #521360 is a reply to message #521349] Wed, 17 March 2010 08:01 Go to previous messageGo to next message
Seems you have the same problem as Eike did yesterday. Check if you have this line in the director task:
<jvmarg value=" -Dorg.eclipse.update.jarprocessor.pack200=${org.eclipse.upda te.jarprocessor.pack200} " />
If you do, the problem is probably that the property is not set. You can either remove this line and make sure you use a
JVM that isn't buggy with respect to pack200 (i.e. do not use the Hudson default 1.6, nor the 1.6 M4), or you can make
sure that the property is correctly propagated in your Hudson config. I.e., add:
org.eclipse.update.jarprocessor.pack200=/shared/common/ibm-j ava2-ppc-50/jre/bin
to the Ant -> Advanced properties.
HTH,
- thomas
On 03/17/2010 12:12 PM, Martin Taal wrote:
> to the latest buckminster build and trying to download it I get this
> encountered the same issue and solved it.
> [java] Installing
> [java] Installing
> [java] Installing
> [java] Installing
> operand=, action=).
> [java] OK
> [java] OK
> [java] OK
> [java] OK
> [java] OK
> [java] OK
> [java] OK
> [java] OK
Re: Downloading/installing buckminster through the director: Unpack facility not configured [message #521369 is a reply to message #521360] Wed, 17 March 2010 08:59 Go to previous message
Thanks Thomas, that worked!
gr. Martin
> <jvmarg
> either remove this line and make sure you use a JVM that isn't buggy
> 1.6 M4), or you can make sure that the property is correctly propagated
> HTH,
> - thomas
>> Hi,
>> [java] Installing
>> [java] Installing
>> [java] Installing
>> [java] Installing
>> operand=, action=).
>> [java] OK
>> [java] OK
>> [java] OK
>> [java] OK
>> [java] OK
>> [java] OK
>> [java] OK
>> [java] OK
The Netherlands
Previous Topic:using jar packed bundles in rmap
Next Topic:Update Authorized CI problem
Current Time: Sat Nov 08 01:05:28 EST 2025
Powered by FUDForum. Page generated in 0.03755 seconds
