2.0.0.M6 [message #521108] |
Tue, 16 March 2010 09:00 |
Hi Rienaers,
a new version of Riena is available. Riena 2.0.0.M6 as part of the M5 milestone in Helios.
New and Noteworthy can be found here http://wiki.eclipse.org/Riena_New_And_Noteworthy#2.0.0.M6
Links to updatesite and target platform are available here http://wiki.eclipse.org/Riena_Getting_started
We started a migration guide from 1.2. to 2.0 over here http://wiki.eclipse.org/Riena_Migrating_to_2.0_from_1.2 .
2.0.0.M6 brings quite a number of changes which are detailed in the Riena Migration Page. They will require that you do
a small change to your RCP Views. Those no longer extend from SubModuleView <your controller> but they only extend
SubModuleView, they are many more changes, most notiable is the change to a new assembly extension (assembly2). However
existing assembly entries will be converted on the fly so that they can be used. We will not make any modifications on disk.
So you have a little work to upgrade to 2.0.0.M6 but get a much cleaner and easier to use API. We also worked a lot on
adding Javadoc for interfaces and documentation for extension points.
Make sure that you address all deprecate warnings that you see coming. We will remove those methods, classes and
possibly extension points before the release.
If you have any problems, dont hesitate to contact us......
christian campo
FUDForum. Page generated in 0.09515 seconds
