Home » Archived » Riena » Default Logging
Default Logging [message #521053] Tue, 16 March 2010 06:46 Go to next message
By default Riena logs using the Equinox Logger. This can be switched off
using the system prop "riena.development".
Wouldn't it be better to assume "production" (no logging) as default and
let interested developers activate the logger on demand?
Any chance to get this changed?
Stefan.
Re: Default Logging [message #521109 is a reply to message #521053] Tue, 16 March 2010 09:01 Go to previous message
On 16.03.2010 11:46, Stefan Roeck wrote:
Yes, Riena logs using the Equinox Logger. This can not be switched on or
off.
But what you can do is configuring log listeners and log catchers.
LogListener will perform the actual logging, i.e. write the logging
information to files. LogCatcher attach themselves to other sources of
events and route them into Equinox Logger.
This can all be done with extensions to
org.eclipse.riena.core.logListeners and org.eclipse.riena.core.logCatchers.
If no such extensions have been defined and the system property
"riena.development" is "true" (which is the default if you do nothing)
then a default initialization will be done which creates a logger that
writes to System.out and a log catcher will created that catches events
from org.eclipse.core.runtime.Platform.
Well ..
The idea behind this behavior is that while you are developing you will
get a simple console logging for free.
If you want to deploy your application and you define loggers (e.g. for
log4j) and catchers everything is still fine.
If you do not want logging at all you have to set the system property to
"false".
Can you elaborate on this? What do you mean with "interested developers"
and what is the granularity of "on demand"? While you app is running? ..
With the greatest of reluctance!
> Regards,
> Stefan.
Tschüß,
Stefan
Re: Default Logging [message #584821 is a reply to message #521053] Tue, 16 March 2010 09:01 Go to previous message
off.
Well ..
"false".
> Regards,
> Stefan.
Tschüß,
Stefan
Previous Topic:2.0.0.M6
Next Topic:Programmatically Focus on Workarea
Current Time: Fri Jul 25 05:39:00 EDT 2025
Powered by FUDForum. Page generated in 0.03281 seconds
