Home » Eclipse Projects » Eclipse 4 » Load XWT from a string in memory(Loading XWT from a string in memory)
Load XWT from a string in memory [message #520669] Sat, 13 March 2010 20:00 Go to next message
I have an application that will be creating XWT on the fly. I'd like to be able to grab the "XWT string" that is created and load it. I've only seen XWT being loaded from a file, using a URL. Is there a way to load it from memory ?
Re: Load XWT from a string in memory [message #520767 is a reply to message #520669] Mon, 15 March 2010 05:29 Go to previous messageGo to next message
There is a API in the class API of XWT using InputStream, instead of URL.
But we need more tests.
Best regards
Yves YANG
"Frank Gualtieri" <fgualtieri@promia.com> wrote in message
news:hnhcf4$hdc$1@build.eclipse.org...
>memory ?
Re: Load XWT from a string in memory [message #520768 is a reply to message #520767] Mon, 15 March 2010 05:31 Go to previous messageGo to next message
Sorry, I would liek to say: "There is an API in the class XWT using
InputStream, instead of URL".
yves
"Yves YANG" <yves.yang@soyatec.com> wrote in message
news:hnkumd$q9o$1@build.eclipse.org...
> Best regards
> Yves YANG
>>from memory ?
Re: Load XWT from a string in memory [message #520785 is a reply to message #520768] Mon, 15 March 2010 06:41 Go to previous messageGo to next message
Is there an API for XWT on line somewhere 'cause I wasn't able to find it ? Is the method you mentioned available or when you say it needs more testing do you mean it is not yet available ? If it is available, can you give me a quick example of how it would be called ?
Re: Load XWT from a string in memory [message #520794 is a reply to message #520785] Mon, 15 March 2010 07:58 Go to previous messageGo to next message
I use following code to render XWT document.
			String content = m_context.getContent();
			Map<String, Object> options = Maps.newHashMap();
			XWT.loadWithOptions(IOUtils.toInputStream(content), url, options);
Where IOUtils is org.apache.commons.io.IOUtils is from Jakarta Commons.
Re: Load XWT from a string in memory [message #520796 is a reply to message #520794] Mon, 15 March 2010 08:17 Go to previous messageGo to next message
Konstantin,
Thanks for the quick response. I am new to XWT so I'll ask the questions, although they may seem ridiculous.
In your example:
1) is the value of url null ?
2) once the "load" is done how do I get the Control that is returned from the call to XWT.load... to display ?
Frank
Re: Load XWT from a string in memory [message #520937 is a reply to message #520796] Mon, 15 March 2010 17:11 Go to previous messageGo to next message
news:hnl8h6$vbm$1@build.eclipse.org...
> Konstantin,
> In your example:
The second argument indicates the location to find the Java class event
handler It shouldn't be null.
You can call XWT.findElementByName(context, "<my name>")
There are a lot of examples in org.eclipse.e4.xwt.tests. I recommand to take
a look.
Best regards
Yves YANG
> Frank
Re: Load XWT from a string in memory [message #520939 is a reply to message #520937] Mon, 15 March 2010 12:24 Go to previous messageGo to next message
news:hnm7pb$j4l$1@build.eclipse.org...
>> Konstantin,
>> In your example:
I suppose I misunderstood the question. The load() return a root element,
you can use it to display.
Best regards
Yves YANG
> take a look.
> Best regards
> Yves YANG
>> Frank
Re: Load XWT from a string in memory [message #520947 is a reply to message #520939] Mon, 15 March 2010 17:47 Go to previous messageGo to next message
I still cannot get the load the work.
Your suggestion to look at some fo the examples in org.eclipse.e4.xwt.tests sounds like it would be good BUT where do I find that ?
Re: Load XWT from a string in memory [message #520958 is a reply to message #520947] Mon, 15 March 2010 18:59 Go to previous messageGo to next message
OK... I found the repository and am checking out the project. I hope to find an example that will make things clearer.
Re: Load XWT from a string in memory [message #520960 is a reply to message #520947] Mon, 15 March 2010 19:36 Go to previous messageGo to next message
OK... I checked out the e4 xwt tests and didn't find one that used the loadWithOptions method that takes the stream, url, and Map as parms.
Can you tell me where another example might be or can you write something a bit more informative ?
Re: Load XWT from a string in memory [message #520972 is a reply to message #520960] Mon, 15 March 2010 21:45 Go to previous messageGo to next message
In the ElementManager method below,
public Element load(InputStream stream, URL url) throws Exception {
reset();
// Initialize document root
PushbackInputStream pis = null;
if (stream != null) {
if (stream instanceof PushbackInputStream) {
pis = (PushbackInputStream) stream;
} else {
pis = new PushbackInputStream(stream, 4);
documentRoot.init(pis, url.toString());
InputStream input = pis;
if (pis == null) {
input = documentRoot.openStream();
doLoad(input);
loadXData(input);
input.close();
return rootElement;
The url argument can't be null because of
documentRoot.init(pis, url.toString());.
So even if you pass in a valid stream like
ByteArrayInputStream bs = new ByteArrayInputStream(myXwt.getBytes());
to
Control c = XWT.load(aShell, bs, myUrl, contextObject);
the documentRoot.openStream() call requires a valid URL to
keep "new URL(...).openStream();" happy.
So if you have a stream with your XWT spec, I am not sure
how this combination of arguments makes sense to use.
The above post states,
"The second argument indicates the location to find the Java class event
handler. It shouldn't be null."
But I am not sure what an example of a "Java class event handler"
would be especially when you are trying to debug things.
Maybe Yves YANG can elaborate???
WRT the question of where one can get a "context" for the statement,
"You can call XWT.findElementByName(context, "<my name>")"
see the post within
http://www.eclipse.org/forums/index.php?t=msg&goto=50515 3&
Re: Load XWT from a string in memory [message #521019 is a reply to message #520972] Tue, 16 March 2010 04:42 Go to previous message
<allygirl@mailinator.com> wrote in message
news:hnmnse$e4m$1@build.eclipse.org...
> reset();
> } else {
> if (pis == null) {
> doLoad(input);
> loadXData(input);
> input.close();
> return rootElement;
> to
> So if you have a stream with your XWT spec, I am not sure how this
> The above post states, "The second argument indicates the location to find
we need to develop a snippet. Unfortunately, I'm busy for eclipsecon for
now. I can do it after. Please fill a bug and CC to me.
This feature is used by our XML editor for instant preview of the code in
memory. The class is XWTView in the plugin org.eclipse.e4.xwt.tools.ui.
best regards
Yves YANG
> see the post within
Re: Load XWT from a string in memory [message #570549 is a reply to message #520767] Mon, 15 March 2010 05:31 Go to previous message
yves
> Best regards
> Yves YANG
>>from memory ?
Re: Load XWT from a string in memory [message #570559 is a reply to message #520768] Mon, 15 March 2010 06:41 Go to previous message
Re: Load XWT from a string in memory [message #570569 is a reply to message #570559] Mon, 15 March 2010 07:58 Go to previous message
Konstantin Scheglov,
Instantiations, Inc.
Re: Load XWT from a string in memory [message #570588 is a reply to message #520794] Mon, 15 March 2010 08:17 Go to previous message
Konstantin,
In your example:
Frank
Re: Load XWT from a string in memory [message #570633 is a reply to message #570588] Mon, 15 March 2010 17:11 Go to previous message
> Konstantin,
> In your example:
a look.
Best regards
Yves YANG
> Frank
Re: Load XWT from a string in memory [message #570648 is a reply to message #520937] Mon, 15 March 2010 17:13 Go to previous message
>> Konstantin,
>> In your example:
Best regards
Yves YANG
> take a look.
> Best regards
> Yves YANG
>> Frank
Re: Load XWT from a string in memory [message #570670 is a reply to message #570648] Mon, 15 March 2010 17:47 Go to previous message
Re: Load XWT from a string in memory [message #570688 is a reply to message #570670] Mon, 15 March 2010 18:59 Go to previous message
Re: Load XWT from a string in memory [message #570703 is a reply to message #570670] Mon, 15 March 2010 19:36 Go to previous message
Re: Load XWT from a string in memory [message #570715 is a reply to message #570703] Mon, 15 March 2010 21:45 Go to previous message
reset();
} else {
if (pis == null) {
doLoad(input);
loadXData(input);
input.close();
return rootElement;
to
see the post within
Re: Load XWT from a string in memory [message #570764 is a reply to message #570715] Tue, 16 March 2010 04:42 Go to previous message
> reset();
> } else {
> if (pis == null) {
> doLoad(input);
> loadXData(input);
> input.close();
> return rootElement;
> to
best regards
Yves YANG
> see the post within
Previous Topic:Model components should be displayed directly after application start
Next Topic:XWT and JFace UpdateValueStrategies
Current Time: Fri Jul 18 21:03:33 EDT 2025
Powered by FUDForum. Page generated in 0.09199 seconds
