Home » Archived » BIRT » Hide a crosstab if empty(Works in designer, fails in tomcat)
Hide a crosstab if empty [message #520769] Mon, 15 March 2010 05:39 Go to next message
I want to hide a crosstab if there is no data returned. I'm doing this by setting the visibility in the properties of the crosstab as follows:
In the expression builder I can see the datacube so I pick the summary field and check if its null
measure["AMOUNT1"] == null
This works fine in the designer but when I drop the report into TC 6.0.18 I get the exception below:
Can anyone help with what is causing it, or offer a different method of hiding the crosstab when datacube is empty?
thanks
java.lang.RuntimeException: org.eclipse.birt.data.engine.core.DataException: The level member cannot be achieved because the result set has not
started.
        at org.eclipse.birt.data.engine.olap.script.JSMeasureAccessor.get(JSMeasureAccessor.java:67)
        at org.mozilla.javascript.ScriptableObject.getProperty(ScriptableObject.java:1575)
        at org.mozilla.javascript.ScriptRuntime.getObjectElem(ScriptRuntime.java:1363)
        at org.mozilla.javascript.ScriptRuntime.getObjectElem(ScriptRuntime.java:1345)
        at org.mozilla.javascript.gen.c78._c0(<inline>:1)
        at org.mozilla.javascript.gen.c78.call(<inline>)
        at org.mozilla.javascript.ContextFactory.doTopCall(ContextFactory.java:401)
        at org.mozilla.javascript.ScriptRuntime.doTopCall(ScriptRuntime.java:3003)
        at org.mozilla.javascript.gen.c78.exec(<inline>)
        at org.eclipse.birt.report.engine.javascript.JavascriptEngine.evaluate(JavascriptEngine.java:256)
        at org.eclipse.birt.core.script.ScriptContext.evaluate(ScriptContext.java:152)
        at org.eclipse.birt.report.engine.executor.ExecutionContext.evaluate(ExecutionContext.java:706)
        at org.eclipse.birt.report.engine.executor.ExecutionContext.evaluate(ExecutionContext.java:687)
        at org.eclipse.birt.report.engine.executor.ExecutionContext.evaluate(ExecutionContext.java:664)
        at org.eclipse.birt.report.engine.data.dte.CubeResultSet.evaluate(CubeResultSet.java:195)
        at org.eclipse.birt.report.item.crosstab.core.re.executor.ContentUtil.processVisibility(ContentUtil.java:220)
        at org.eclipse.birt.report.item.crosstab.core.re.executor.ContentUtil.processVisibility(ContentUtil.java:178)
        at org.eclipse.birt.report.item.crosstab.core.re.executor.BaseCrosstabExecutor.processVisibility(BaseCrosstabExecutor.java:162)
        at org.eclipse.birt.report.item.crosstab.core.re.executor.CrosstabReportItemExecutor.execute(CrosstabReportItemExecutor.java:107)
        at org.eclipse.birt.report.engine.executor.ExtendedItemExecutor.execute(ExtendedItemExecutor.java:62)
        at org.eclipse.birt.report.engine.internal.executor.wrap.WrappedReportItemExecutor.execute(WrappedReportItemExecutor.java:46)
        at org.eclipse.birt.report.engine.internal.executor.emitter.ReportItemEmitterExecutor.execute(ReportItemEmitterExecutor.java:46)
        at org.eclipse.birt.report.engine.internal.executor.dup.SuppressDuplicateItemExecutor.execute(SuppressDuplicateItemExecutor.java:43)
        at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:65)
        at org.eclipse.birt.report.engine.layout.html.HTMLStackingLM.layoutChildren(HTMLStackingLM.java:26)
        at org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.layout(HTMLAbstractLM.java:137)
        at org.eclipse.birt.report.engine.layout.html.HTMLInlineStackingLM.resumeLayout(HTMLInlineStackingLM.java:111)
        at org.eclipse.birt.report.engine.layout.html.HTMLInlineStackingLM.layoutNodes(HTMLInlineStackingLM.java:160)
        at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:70)
        at org.eclipse.birt.report.engine.layout.html.HTMLTableLM.layoutChildren(HTMLTableLM.java:132)
        at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout(HTMLPageLM.java:90)
        at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutEngine.layout(HTMLReportLayoutEngine.java:99)
        at org.eclipse.birt.report.engine.presentation.ReportDocumentBuilder.build(ReportDocumentBuilder.java:258)
        at org.eclipse.birt.report.engine.api.impl.RunTask.doRun(RunTask.java:243)
        at org.eclipse.birt.report.engine.api.impl.RunTask.run(RunTask.java:82)
        at com.fineos.reporting.birt.BirtReportManager.runReport(BirtReportManager.java:828)
        at com.fineos.reporting.birt.BIRTReportsProvider.runReport(BIRTReportsProvider.java:184)
        at com.fineos.reporting.services.serviceskeleton.ReportingServicesSkeleton.runReport(ReportingServicesSkeleton.java:171)
        at com.fineos.reports.operationtypes.ReportingServicesMessageReceiverInOut.invokeBusinessLogic(ReportingServicesMessageReceiverInOut.java:16
        at org.apache.axis2.receivers.AbstractInOutMessageReceiver.invokeBusinessLogic(AbstractInOutMessageReceiver.java:40)
        at org.apache.axis2.receivers.AbstractMessageReceiver.receive(AbstractMessageReceiver.java:100)
        at org.apache.axis2.engine.AxisEngine.receive(AxisEngine.java:176)
        at org.apache.axis2.transport.http.HTTPTransportUtils.processHTTPPostRequest(HTTPTransportUtils.java:275)
        at org.apache.axis2.transport.http.AxisServlet.doPost(AxisServlet.java:131)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:637)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
        at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
        at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
        at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
        at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
        at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
        at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
        at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
        at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:286)
        at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:845)
        at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:583)
        at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
        at java.lang.Thread.run(Thread.java:619)
[Updated on: Mon, 15 March 2010 05:41] by Moderator
Re: Hide a crosstab if empty [message #520873 is a reply to message #520769] Mon, 15 March 2010 11:57 Go to previous messageGo to next message
Trevor,
It would be good if you could log an enhancement request for this.
As a work around if you are using the frameset mapping or RE API with
separate run and render tasks you could enter the following script on
the xtab:
function onPrepareCrosstab( crosstab, reportContext )
importPackage(Packages.java.lang)
reportContext.setPersistentGlobalVariable("displayme", new Integer(0));
function onCreateCell( cellInst, reportContext )
if( cellInst.getCellType() == "aggregation"){
importPackage(Packages.java.lang);
reportContext.setPersistentGlobalVariable("displayme", new Integer(1));
function onRenderCrosstab( crosstabInst, reportContext )
var dm = parseInt(reportContext.getPersistentGlobalVariable("displayme "));
if( dm == 0 ){
crosstabInst.getStyle().display = "none";
Jason
TREVOR.HIGGINS@FINEOS.COM wrote:
> [CODE]
> /CODE]
> 6.0.18 I get the following exception:
> thanks
> be achieved because the result set has not star
> d.
> at
> org.eclipse.birt.data.engine.olap.script.JSMeasureAccessor.g et(JSMeasureAccessor.java:67)
> at
> org.mozilla.javascript.ScriptableObject.getProperty(Scriptab leObject.java:1575)
> at
> org.mozilla.javascript.ScriptRuntime.getObjectElem(ScriptRun time.java:1363)
> at
> org.mozilla.javascript.ScriptRuntime.getObjectElem(ScriptRun time.java:1345)
> at
> org.mozilla.javascript.ContextFactory.doTopCall(ContextFacto ry.java:401)
> at
> org.mozilla.javascript.ScriptRuntime.doTopCall(ScriptRuntime .java:3003)
> at
> org.eclipse.birt.report.engine.javascript.JavascriptEngine.e valuate(JavascriptEngine.java:256)
> at
> org.eclipse.birt.core.script.ScriptContext.evaluate(ScriptCo ntext.java:152)
> at
> org.eclipse.birt.report.engine.executor.ExecutionContext.eva luate(ExecutionContext.java:706)
> at
> org.eclipse.birt.report.engine.executor.ExecutionContext.eva luate(ExecutionContext.java:687)
> at
> org.eclipse.birt.report.engine.executor.ExecutionContext.eva luate(ExecutionContext.java:664)
> at
> org.eclipse.birt.report.engine.data.dte.CubeResultSet.evalua te(CubeResultSet.java:195)
> at
> org.eclipse.birt.report.item.crosstab.core.re.executor.Conte ntUtil.processVisibility(ContentUtil.java:220)
> at
> org.eclipse.birt.report.item.crosstab.core.re.executor.Conte ntUtil.processVisibility(ContentUtil.java:178)
> at
> org.eclipse.birt.report.item.crosstab.core.re.executor.BaseC rosstabExecutor.processVisibility(BaseCrosstabExecutor.java: 162)
> at
> org.eclipse.birt.report.item.crosstab.core.re.executor.Cross tabReportItemExecutor.execute(CrosstabReportItemExecutor.jav a:107)
> at
> org.eclipse.birt.report.engine.executor.ExtendedItemExecutor .execute(ExtendedItemExecutor.java:62)
> at
> org.eclipse.birt.report.engine.internal.executor.wrap.Wrappe dReportItemExecutor.execute(WrappedReportItemExecutor.java:4 6)
> at
> org.eclipse.birt.report.engine.internal.executor.emitter.Rep ortItemEmitterExecutor.execute(ReportItemEmitterExecutor.jav a:46)
> at
> org.eclipse.birt.report.engine.internal.executor.dup.Suppres sDuplicateItemExecutor.execute(SuppressDuplicateItemExecutor .java:43)
> at
> org.eclipse.birt.report.engine.layout.html.HTMLBlockStacking LM.layoutNodes(HTMLBlockStackingLM.java:65)
> at
> org.eclipse.birt.report.engine.layout.html.HTMLStackingLM.la youtChildren(HTMLStackingLM.java:26)
> at
> org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.la yout(HTMLAbstractLM.java:137)
> at
> org.eclipse.birt.report.engine.layout.html.HTMLInlineStackin gLM.resumeLayout(HTMLInlineStackingLM.java:111)
> at
> org.eclipse.birt.report.engine.layout.html.HTMLInlineStackin gLM.layoutNodes(HTMLInlineStackingLM.java:160)
> at
> at
> at
> org.eclipse.birt.report.engine.layout.html.HTMLBlockStacking LM.layoutNodes(HTMLBlockStackingLM.java:70)
> at
> at
> org.eclipse.birt.report.engine.layout.html.HTMLTableLM.layou tChildren(HTMLTableLM.java:132)
> at
> at
> at
> org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout (HTMLPageLM.java:90)
> at
> org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutE ngine.layout(HTMLReportLayoutEngine.java:99)
> at
> org.eclipse.birt.report.engine.presentation.ReportDocumentBu ilder.build(ReportDocumentBuilder.java:258)
> at
> org.eclipse.birt.report.engine.api.impl.RunTask.doRun(RunTas k.java:243)
> at
> org.eclipse.birt.report.engine.api.impl.RunTask.run(RunTask. java:82)
> at
> com.fineos.reporting.birt.BirtReportManager.runReport(BirtRe portManager.java:828)
> at
> com.fineos.reporting.birt.BIRTReportsProvider.runReport(BIRT ReportsProvider.java:184)
> at
> com.fineos.reporting.services.serviceskeleton.ReportingServi cesSkeleton.runReport(ReportingServicesSkeleton.java:171)
> at
> com.fineos.reports.operationtypes.ReportingServicesMessageRe ceiverInOut.invokeBusinessLogic(ReportingServicesMessageRece iverInOut.java:16
> at
> org.apache.axis2.receivers.AbstractInOutMessageReceiver.invo keBusinessLogic(AbstractInOutMessageReceiver.java:40)
> at
> org.apache.axis2.receivers.AbstractMessageReceiver.receive(A bstractMessageReceiver.java:100)
> at org.apache.axis2.engine.AxisEngine.receive(AxisEngine.java:1 76)
> at
> org.apache.axis2.transport.http.HTTPTransportUtils.processHT TPPostRequest(HTTPTransportUtils.java:275)
> at
> org.apache.axis2.transport.http.AxisServlet.doPost(AxisServl et.java:131)
> at
> org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:290)
> at
> org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterChain.java:206)
> at
> org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:233)
> at
> org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:191)
> at
> org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:128)
> at
> org.apache.catalina.valves.ErrorReportValve.invoke(ErrorRepo rtValve.java:102)
> at
> org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:109)
> at
> org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAd apter.java:286)
> at
> org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:845)
> at
> org.apache.coyote.http11.Http11Protocol$Http11ConnectionHand ler.process(Http11Protocol.java:583)
> at
> org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoin t.java:447)
Re: Hide a crosstab if empty [message #520896 is a reply to message #520873] Mon, 15 March 2010 12:55 Go to previous messageGo to next message
Cool, thanks for that. I was thinking something similar but couldnt quite get it going. Do you know why my original approach fails in TC, so I can log a meaningful enhancement request?
Re: Hide a crosstab if empty [message #520904 is a reply to message #520896] Mon, 15 March 2010 13:10 Go to previous messageGo to next message
Trevor,
I tried that approach in 2.5.2 and it did not work at all (designer or
deployed). I am not certain why you got the error. Log a bug and
someone on the dev team will have a look. Log it as an enhancement so
we can get the feature requested.
Jason
Re: Hide a crosstab if empty [message #520906 is a reply to message #520769] Mon, 15 March 2010 13:23 Go to previous messageGo to next message
Will do, thanks again for quick and helpful response, as usual
Re: Hide a crosstab if empty [message #817050 is a reply to message #520873] Fri, 09 March 2012 10:21 Go to previous messageGo to next message
You can hide the crosstab entirely by using this code.
paste this code snippet at Corsstab's OnCreateCrosstab section
function onCreateCrosstab( crosstabInst, reportContext )
if( reportContext.evaluate("dimension['EmpGroup']['NAME']") == null)
crosstabInst.getStyle().display="None";
At the place of "dimension['Emp NameGroup']['VAR_FIRSTNAME']" give a column binding data and change the quotes as shown above.
This will hide the crosstab
[Updated on: Fri, 09 March 2012 10:23] by Moderator
Re: Hide a crosstab if empty [message #904386 is a reply to message #817050] Tue, 28 August 2012 07:02 Go to previous messageGo to next message
Hi. I am new to BIRT and I am unable to get the above script to work.
I have a crosstab that I wish to hide if empty or ideally display a message such as "no results for ......"
My cube is called Dispensers, with a Dimension called DispenserGroup that contains fields partid and partdesc. My Measure is called quantity with the field quantity1.
I am able to hide the crosstab using the visibility expression builder with data["quantity1"] == null.
I thought by using the script you mention above I would be able to have statement to add in my " no results for......." message, however I am falling at the first hurdle and unable to hide the crosstab!!.
Regard's
Paul
Re: Hide a crosstab if empty [message #904621 is a reply to message #904386] Tue, 28 August 2012 16:41 Go to previous message
Paul
Where did you put the script and how did you check for null?
if( reportContext.evaluate("dimension['DispenserGroup']") == null)
You could change one of the labels to say no data or you could set a
global variable in your visibility expression like:
if( data["quantity1"] == null ){
reportContext.setGlobalVariable("crosstabHide", true);
}else{
reportContext.setGlobalVariable("crosstabHide", false);
You could then add a label to the report that says No Data and set a
visibility expression on it using:
reportContext.getGlobalVariable("crosstabHide");
For more on crosstab scripting have a look at:
http://birtworld.blogspot.com/2010/02/birt-crosstab-scripting.html
Jason
> Regard's
> Paul
Previous Topic:report doesn't show up
Next Topic:including a Birt report to a JSF application (howto?)
Current Time: Thu Jul 24 22:48:12 EDT 2025
Powered by FUDForum. Page generated in 0.07651 seconds
