Home » Eclipse Projects » Standard Widget Toolkit (SWT) » [Outlook Drop] Read bytes from an IStorage
[Outlook Drop] Read bytes from an IStorage [message #520204] |
Thu, 11 March 2010 09:50  |
Hi all, I am making progress with my outlook drop transfer. The trick is to register FileContent and use the returned int as type for the transfers FORMATETC. it then returns an IStorage and I don't know how to read the bytes from it. It seems to be an outlook .msg file content (dont need to parse it, just want to store the file in jackrabbit) I found a c# example that goes like
switch(medium.tymed)
case TYMED.TYMED_ISTORAGE:
//to handle a IStorage it needs to be written into a second unmanaged
//memory mapped storage and then the data can be read from memory into
//a managed byte and returned as a MemoryStream
NativeMethods.IStorage iStorage = null;
NativeMethods.IStorage iStorage2 = null;
NativeMethods.ILockBytes iLockBytes = null;
System.Runtime.InteropServices.ComTypes.STATSTG iLockBytesStat;
try
//marshal the returned pointer to a IStorage object
iStorage = (NativeMethods.IStorage)Marshal.GetObjectForIUnknown(medium.unionmember);
Marshal.Release(medium.unionmember);
//create a ILockBytes (unmanaged byte array) and then create a IStorage using the byte array as a backing store
iLockBytes = NativeMethods.CreateILockBytesOnHGlobal(IntPtr.Zero, true);
iStorage2 = NativeMethods.StgCreateDocfileOnILockBytes(iLockBytes, 0x00001012, 0);
//copy the returned IStorage into the new IStorage
iStorage.CopyTo(0, null, IntPtr.Zero, iStorage2);
iLockBytes.Flush();
iStorage2.Commit(0);
//get the STATSTG of the ILockBytes to determine how many bytes were written to it
iLockBytesStat = new System.Runtime.InteropServices.ComTypes.STATSTG();
iLockBytes.Stat(out iLockBytesStat, 1);
int iLockBytesSize = (int)iLockBytesStat.cbSize;
//read the data from the ILockBytes (unmanaged byte array) into a managed byte array
byte[] iLockBytesContent = new byte[iLockBytesSize];
iLockBytes.ReadAt(0, iLockBytesContent, iLockBytesContent.Length, null);
//wrapped the managed byte array into a memory stream and return it
return new MemoryStream(iLockBytesContent);
finally
//release all unmanaged objects
Marshal.ReleaseComObject(iStorage2);
Marshal.ReleaseComObject(iLockBytes);
Marshal.ReleaseComObject(iStorage);
can anyone tell me what i need to do to gte the bytes from this IStorage
my code so far goes this way:
public OutLookTransfer()
type = registerType("FileContents");
public Object nativeToJava(TransferData transferData)
IDataObject idata = new IDataObject(transferData.pIDataObject);
idata.AddRef();
FORMATETC formatetc = new FORMATETC();
STGMEDIUM stgmedium = new STGMEDIUM();
// stgmedium.tymed = COM.TYMED_HGLOBAL;
formatetc.cfFormat = type;
System.out.println("Format: " + formatetc.cfFormat);
formatetc.lindex = 0;
formatetc.ptd = 0;
formatetc.tymed = 4 | 8 | 1;
formatetc.dwAspect = COM.DVASPECT_CONTENT;
transferData.result = getData(idata, formatetc, stgmedium);
idata.Release();
if (transferData.result != COM.S_OK)
// BigInteger bd = new BigInteger(Long.valueOf(transferData.result * -1).toString());
System.out.println("Fehler" + transferData.result);
else
System.out.println("Ok");
if ((stgmedium.tymed & 8) == 8)
// IStorage
IStorage storage = new IStorage(stgmedium.unionField);
storage.AddRef();
// what now ?
[Updated on: Thu, 11 March 2010 09:53] by Moderator
Re: [Outlook Drop] Read bytes from an IStorage [message #520890 is a reply to message #520204] |
Mon, 15 March 2010 12:29   |
Unfortunately I'm getting a different result than you in this scenario, it's
giving me an IStream instead of an IStorage (maybe it's because I'm on
Windows 2000 and have an Outlook version from that era as well?). So I
don't have a way to write code and run it to see if it actually works. Here
are some thoughts though, with code snippets copied from various places in
swt that seem to be doing something similar:
To use the approach in your last reply you'll need to recompile swt's
libraries, or create a new library of your own, because swt's libraries do
not currently contain natives for CreateILockBytesOnHGlobal or
StgCreateDocfileOnILockBytes. I'm assuming this isn't ideal, so it may be
possible to use another approach that does not require adding any new
natives. To try this, go back to the last post in thread
http://www.eclipse.org/forums/index.php?t=msg&&th=14 7516&goto=464661 , get
the rest of its content that follows "storage.AddRef();", and see how many
times its while loop happens. If it's just once, then get its STATSTG's
pwcsName, and use it to invoke IStorage.OpenStream(...) like:
int length = OS.GlobalSize(pwcsName);
int /*long*/ ptr = OS.GlobalLock(pwcsName);
char[] buffer = new char[length];
COM.MoveMemory(buffer, ptr, length);
OS.GlobalUnlock(pwcsName);
String name = new String(buffer);
int /*long*/[] address = new int /*long*/[1];
yourIStorage.OpenStream(name, 0, COM.STGM_DIRECT | COM.STGM_READ |
COM.STGM_SHARE_EXCLUSIVE, 0, address); // not sure about the access bits,
just COM.STGM_READ may be enough
If OpenStream returns COM.S_OK then address[0] should contain a pointer to
an IStream, which can then be read with something like:
IStream tempContents = new IStream(address[0]);
tempContents.AddRef();
try {
FileOutputStream writer = new FileOutputStream(file);
int increment = 1024 * 4;
int /*long*/ pv = COM.CoTaskMemAlloc(increment);
int[] pcbWritten = new int[1];
while (tempContents.Read(pv, increment, pcbWritten) == COM.S_OK &&
pcbWritten[0] > 0) {
byte[] buffer = new byte[ pcbWritten[0]];
OS.MoveMemory(buffer, pv, pcbWritten[0]);
writer.write(buffer); // Note: if file does not exist, this will
create the file the first time it is called
COM.CoTaskMemFree(pv);
writer.close();
} catch (IOException err) {
tempContents.Release();
I'd be interested to know how close this gets to being helpful ;-).
Grant
"Thomas Kratz" <eiswind@googlemail.com> wrote in message
news:hnavvc$afh$1@build.eclipse.org...
that goes like
second unmanaged
from memory into
iLockBytesStat;
> try
object
> iStorage =
(NativeMethods.IStorage)Marshal.GetObjectForIUnknown(medium. unionmember);
> iLockBytes =
> iStorage2 =
> iLockBytes.Flush();
> finally
> idata.AddRef();
> formatetc.ptd = 0;
> idata.Release();
* -1).toString());
> else
> // IStorage
> storage.AddRef();
> // what now ?
Current Time: Sat Jul 26 13:21:12 EDT 2025
Powered by FUDForum. Page generated in 0.03488 seconds
