Newbe-question: Eclipse Helios and RAP [message #520665] |
Sat, 13 March 2010 18:26  |
Originally posted by: gunnar.stahl.gunnarstahl.org
Hello list,
I do have some trouble installing the RAP target platform under eclipse helios (3.6). I've downloaded the RAP tooling
stuff via the update manager. When I now click on "Install target platform" I get the attached error message.
The system is: debian linux, openjdk-1.6, 64bit.
Does anybody know how to get rap working on helios?
Yt,
Gunnar
Failed execute command: org.eclipse.rap.ui.intro.installTarget
And a stack trace:
org.eclipse.core.commands.ExecutionException: Failed to install target platform.
at org.eclipse.rap.ui.internal.intro.target.InstallRAPTargetHan dler.execute(InstallRAPTargetHandler.java:65)
at org.eclipse.rap.ui.internal.intro.target.InstallRAPTargetHan dler.execute(InstallRAPTargetHandler.java:36)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(Handle rProxy.java:293)
at org.eclipse.core.commands.Command.executeWithChecks(Command. java:476)
at org.eclipse.ui.internal.handlers.HandlerService.executeComma nd(HandlerService.java:178)
at org.eclipse.ui.internal.handlers.SlaveHandlerService.execute Command(SlaveHandlerService.java:247)
at org.eclipse.rap.ui.internal.intro.target.InstallRAPTargetAct ion.run(InstallRAPTargetAction.java:36)
at org.eclipse.ui.internal.intro.impl.model.url.IntroURL.runAct ion(IntroURL.java:285)
at org.eclipse.ui.internal.intro.impl.model.url.IntroURL.doExec ute(IntroURL.java:193)
at org.eclipse.ui.internal.intro.impl.model.url.IntroURL$1.run( IntroURL.java:144)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
at org.eclipse.ui.internal.intro.impl.model.url.IntroURL.execut e(IntroURL.java:141)
at
org.eclipse.ui.internal.intro.impl.presentations.BrowserIntr oPartLocationListener.changing(BrowserIntroPartLocationListe ner.java:130)
at org.eclipse.swt.browser.Mozilla.OnStartURIOpen(Mozilla.java: 3547)
at org.eclipse.swt.browser.Mozilla$17.method3(Mozilla.java:1608 )
at org.eclipse.swt.internal.mozilla.XPCOMObject.callback3(XPCOM Object.java:266)
at org.eclipse.swt.internal.gtk.OS._g_main_context_iteration(Na tive Method)
at org.eclipse.swt.internal.gtk.OS.g_main_context_iteration(OS. java:2181)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3143)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2407)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2371)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 20)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:115)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:367)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:57)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 611)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:566)
at org.eclipse.equinox.launcher.Main.run(Main.java:1363)
at org.eclipse.equinox.launcher.Main.main(Main.java:1339)
Caused by: java.lang.RuntimeException: java.lang.ClassNotFoundException: org.eclipse.pde.internal.core.target.TargetModel
at org.eclipse.rap.ui.internal.intro.target.TargetSwitcher34.co nstruct(TargetSwitcher34.java:96)
at org.eclipse.rap.ui.internal.intro.target.TargetSwitcher34.ge tTargetModel34(TargetSwitcher34.java:59)
at org.eclipse.rap.ui.internal.intro.target.TargetSwitcher34.sw itchTarget(TargetSwitcher34.java:41)
at org.eclipse.rap.ui.internal.intro.target.InstallRAPTargetHan dler.switchTarget(InstallRAPTargetHandler.java:79)
at org.eclipse.rap.ui.internal.intro.target.InstallRAPTargetHan dler.access$0(InstallRAPTargetHandler.java:72)
at org.eclipse.rap.ui.internal.intro.target.InstallRAPTargetHan dler$1.run(InstallRAPTargetHandler.java:52)
at org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:121)
Caused by: java.lang.ClassNotFoundException: org.eclipse.pde.internal.core.target.TargetModel
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:506)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:422)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:410)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:104)
at java.lang.ClassLoader.loadClass(ClassLoader.java:264)
at org.eclipse.rap.ui.internal.intro.target.TargetSwitcher34.co nstruct(TargetSwitcher34.java:86)
.... 6 more
Re: Newbe-question: Eclipse Helios and RAP [message #520787 is a reply to message #520704] |
Mon, 15 March 2010 06:42  |
Hi Ben,
thanks for the infos. Just by chance I found the installation informations on the eclipse rap project site yesterday and
that worked. As a newbe the very concept of a "target platform" is something which is pretty new to me. So I have to get
into this way of thinking, which will make all of this easier over the time.
Thanks for your help!
Gunnar
Benjamin Muskalla wrote:
> Hi Gunnar,
> there was a mismatch between PDE and RAP Tooling in the last milestone.
> This bug has been fixed with RAP 1.3 M6 which will be released next week.
> See 302045: [Tooling] Target installation broken with newer PDE Builds
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=302045
> In the meantime, just download the target yourself from the RAP download
> page and set it up as target in your preferences (see RAP Newcomer
> tutorial).
> Regards,
> Ben
> Gunnar Stahl wrote:
>> Hello list,
>> eclipse helios (3.6). I've downloaded the RAP tooling stuff via the
>> Yt,
>> Gunnar
>> And a stack trace:
>> platform.
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Method)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 6 more
FUDForum. Page generated in 0.25135 seconds
