Questions about Adapter DataFlow Services [message #520409] |
Fri, 12 March 2010 04:58  |
I read the project introduction, where it is explicitly said that several adapters will be developed during the project life cycle, so assuming that the work is in progress, here are my questions:
- How the quoted GLA is used to manage CBE?
- Is it necessary that the various sources generate their data following a particular standard?
- Would it be possible to customize the monitoring criterias, for instance being able to consider some received information as an "error" rather than a "warning"?
Mirko
Re: Questions about Adapter DataFlow Services [message #520626 is a reply to message #520409] |
Sat, 13 March 2010 08:31  |
As you read, we are starting to develop the eBAM components.
These are the answers to your questions:
- GLA is able to create event using CBE standard, you have to configure GLA using a specific Eclipse utility that will help you to write the GLA configuration file
- NO, you can use CBE or you can design your specific messages schema
- Yes, eBAM is able to receive information about the message type's (like error, info...). For example you
can define rules to send an alert when an error message is arrived.
Thanks for your attentions
Angelo
FUDForum. Page generated in 0.03711 seconds
