Home » Eclipse Projects » Eclipse 4 » XWT and Form Layout - Problems ?
XWT and Form Layout - Problems ? [message #520584] Fri, 12 March 2010 17:22 Go to next message
I am trying to use a FormLayout in XWT and have have limitted success. For instance the code below works as expected.
That is: attach the top of button1 to the bottom of button0
attach the left side of button 1 to the left side of button 0 + 10 pixels
attach the right side of button0 to the right side of its parent
<Composite xmlns="http://www.eclipse.org/xwt/presentation"
xmlns:x="http://www.eclipse.org/xwt"
xmlns:c="clr-namespace:sample.hello"
xmlns:j="clr-namespace:java.lang"
x:Class="sample.hello.HelloWorld"
bounds="0,0,449,171">
<Composite.layout>
<FormLayout />
</Composite.layout>
<Button text="Button Two is attached to me" selectionEvent="sayHello" name="button0">
<Button.layoutData>
<FormData top="0,40" left="0,100"/>
</Button.layoutData>
</Button>
<Button text="Button Two" x:style="SWT.PUSH" selectionEvent="sayHello" name="button1">
<Button.layoutData>
<!--Explanation of FormData *************************************************
<FormData
top="{FormAttachment control={Binding ElementName=button0}, alignment=SWT.BOTTOM, offset=0}"
left="{FormAttachment control={Binding ElementName=button0}, alignment=SWT.LEFT, offset=10}"
right="100,-10"/>
</Button>
</Composite>
BUT I WOULD THINK that the code below would have the same result at the code above but it does not (matter of fact I don't even see button1:
<Composite.layout>
<FormLayout />
</Composite.layout>
<Button.layoutData>
</Button>
<Button.layoutData>
<FormData
right="alignment=SWT.RIGHT, offset=-10}"/> <!- THIS LINE CHANGED FROM THE EXAMPLE ABOVE -->
</Button>
</Composite>
ALSO, if you use the first example but move button0 so it is is after the code for button1 then button1 doesn't seem to know about button0 at all (In SWT I can define a button, use it as a control and then define how it is layed out BUT in AWT it seems that a control must precede the element that it controls)...
For example I would expect that the code below should work exactly like the first example in this post but it does not... if there a way to define an element without "laying it out" and then reference it later on and layo it out ?
<Composite.layout>
<FormLayout />
</Composite.layout>
<Button.layoutData>
<FormData
right="100,-10"/>
</Button>
<!--- WHEN button0 is defined after button1 then button1 does not know about button0...
CAN I Define button0 before button1 and then layit out later ? I've tried using creating an element
with name=button0 prior to creating button1 and then using that same name for the element after
defining button1 but that just adds an extra element-->
<Button.layoutData>
</Button>
</Composite>
[Updated on: Fri, 12 March 2010 17:23] by Moderator
Re: XWT and Form Layout - Problems ? [message #520605 is a reply to message #520584] Fri, 12 March 2010 23:54 Go to previous messageGo to next message
Please report a bug in bugzilla !
Yves YANG
"Frank Gualtieri" <fgualtieri@promia.com> wrote in message
news:hneera$ii3$1@build.eclipse.org...
> That is: attach the top of button1 to the bottom of button0 attach the
> parent
> <Composite.layout>
> <FormLayout />
> </Composite.layout> <Button text="Button Two is attached to me"
> <Button.layoutData>
> </Button.layoutData> </Button>
> name="button1">
> <Button.layoutData>
> attach the top of button1 to the bottom of button0 attach the left side of
> <FormData top="{FormAttachment control={Binding ElementName=button0},
> right="100,-10"/>
> </Composite>
> <Composite.layout>
> <FormLayout />
> </Composite.layout>
> name="button0">
> <Button.layoutData>
> name="button1">
> <Button.layoutData>
> EXAMPLE ABOVE -->
> </Composite>
> it out ?
> <Composite.layout>
> <FormLayout />
> </Composite.layout>
> name="button1">
> <Button.layoutData>
> right="100,-10"/>
> about button0...
> name="button0">
> <Button.layoutData>
> </Composite>
Re: XWT and Form Layout - Problems ? [message #520607 is a reply to message #520605] Sat, 13 March 2010 00:45 Go to previous messageGo to next message
I wasn't sure if this was a bug or if I just didn't understand how it worked. I will re-post it in bugzilla.
Re: XWT and Form Layout - Problems ? [message #520613 is a reply to message #520607] Fri, 12 March 2010 23:56 Go to previous messageGo to next message
We need to open the bug for a case, not necessary a bug. It is best way to
track the issue. We'll look at it after EclipseCcon.
Best regards
Yves YANG
news:hnf8pb$ga0$1@build.eclipse.org...
Re: XWT and Form Layout - Problems ? [message #570439 is a reply to message #520605] Sat, 13 March 2010 00:45 Go to previous messageGo to next message
Re: XWT and Form Layout - Problems ? [message #570481 is a reply to message #570439] Sat, 13 March 2010 04:38 Go to previous message
Best regards
Yves YANG
Previous Topic:XWT and Form Layout - Problems ?
Next Topic:Model components should be displayed directly after application start
Current Time: Wed Jul 23 12:36:04 EDT 2025
Powered by FUDForum. Page generated in 0.50429 seconds
