Home » Eclipse Projects » Rich Client Platform (RCP) » Bundle org.eclipse.equinox.launcher.win32.win32.x86_1.0.3.R33x_v20080118 failed to resolve.(How to resolve this error.??)
Bundle org.eclipse.equinox.launcher.win32.win32.x86_1.0.3.R33x_v20080118 failed to resolve. [message #519217] Mon, 08 March 2010 01:27 Go to next message
HI All,
i am getting this error " Bundle org.eclipse.equinox.launcher.win32.win32.x86_1.0.3.R33x_v200 80118 failed to resolve."
whenever i am trying to build my RCP app from ant script on eclipse 3.5 , I have tried copying this plugins from an earlier version of eclipse into my target eclipse's plugins folder but i still see this error
[java] C:\eclipse\plugins\org.eclipse.pde.build_3.5.1.R35x_20090820 \scripts\genericTargets.xml:108: Bundle org.eclipse.equinox.launcher.win32.win32.x86_1.0.3.R33x_v200 80118 failed to resolve.:
[java] Another singleton version selected: org.eclipse.equinox.launcher.win32.win32.x86_1.0.101.R34x_v2 0080731
Any help in this regard will be really grateful to me ..Thanks in advance
Re: Bundle org.eclipse.equinox.launcher.win32.win32.x86_1.0.3.R33x_v20080118 failed to resolve. [message #519410 is a reply to message #519217] Mon, 08 March 2010 13:00 Go to previous messageGo to next message
You appear to be building from bases that include both
1.0.3.R33x_v20080118 and 1.0.101.R34x_v20080731 Do you know why you
have both 3.3 and 3.4 versions of the launcher in your target platform?
Are you including a 3.3 plugin that requires the 3.3 version (and
hence fails when the build picks the 3.4 version)?
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: Bundle org.eclipse.equinox.launcher.win32.win32.x86_1.0.3.R33x_v20080118 failed to resolve. [message #519546 is a reply to message #519217] Tue, 09 March 2010 04:55 Go to previous messageGo to next message
Hi Paul,
what u say is right that i have a two launcher in a base eclipse which is 3.4 and has the launcher 'org.eclipse.equinox.launcher.win32.win32.x86_1.0.101.R34x_v 20080731'
The reason here ,why i have two launcher one that of eclipse 3.3 and other of 3.4 is that i am trying to build my RCp app (which was developed using eclipse 3.3 )from eclipse 3.5 using my base eclipse as 3.4 and since i used to get the error launcher 'org.eclipse.equinox.launcher.win32.win32.x86_1.0.3.R33x_v20 080118' not found, i just copied this launcher plugin into my base eclipse 3.4 and gave a try..But still i find the same problem , but i somehow need to build my RCP on eclipse 3.5 which is what is not happening due to this ein32 launcher plugin issue , so if u know any way i woiuld be grateful to you
Sabir
Re: Bundle org.eclipse.equinox.launcher.win32.win32.x86_1.0.3.R33x_v20080118 failed to resolve. [message #519561 is a reply to message #519546] Tue, 09 March 2010 05:30 Go to previous messageGo to next message
Sabir wrote on Tue, 09 March 2010 04:55
Hi Paul,
Sabir
Re: Bundle org.eclipse.equinox.launcher.win32.win32.x86_1.0.3.R33x_v20080118 failed to resolve. [message #519728 is a reply to message #519546] Tue, 09 March 2010 09:28 Go to previous messageGo to next message
So you're using a vanilla 3.4.2 install as your target platform, and
working in a 3.5 eclipse?
Once 3.4.2 is your target platform, are you not checking out your RCP
app into a clean workspace? If that's the case, then then question
becomes what has a dependency on the R33x launcher, because eclipse
3.4.2 certainly doesn't.
If you have to, unzip a new copy of 3.4.2, create a new workspace, and
import your projects into it.
PW
Paul Webster
Re: Bundle org.eclipse.equinox.launcher.win32.win32.x86_1.0.3.R33x_v20080118 failed to resolve. [message #519826 is a reply to message #519728] Wed, 10 March 2010 00:49 Go to previous messageGo to next message
The problem occurs even if i import my RCP on a clean workspace , and when i try a build, having my eclipse 3.4.2 or for even eclipse 3.5 galileo as my base eclispe , Is it that since the RCP was developed on eclipse 3.3(europa) Is it that it still has a dependency on R33x launcher plugins ?? because i see R33x launcher plugins in eclispe 3.3(europa) versions .
Re: Bundle org.eclipse.equinox.launcher.win32.win32.x86_1.0.3.R33x_v20080118 failed to resolve. [message #519937 is a reply to message #519826] Wed, 10 March 2010 04:54 Go to previous messageGo to next message
1) You create a new workspace in 3.5 and have 3.5.x as your target platform.
2) If you import your projects they should build. (did you just import
your projects, or did you do something else).
3) If you create a launch config (how are you creating your launch
config?) and do a validate in your launch config, it should tell you if
any of your plugins can't meet there own requirements.
4) you should be able to run from that launch config.
At which point in the above steps do you fail? What info did it give you?
PW
Paul Webster
Re: Bundle org.eclipse.equinox.launcher.win32.win32.x86_1.0.3.R33x_v20080118 failed to resolve. [message #520079 is a reply to message #519937] Thu, 11 March 2010 00:01 Go to previous messageGo to next message
Hi Paul,
I tried taking a fresh eclipse 3.5 and having a target platform of eclipse 3.5x , Then when i import the projects i get some issues regarding emf plugins which iam able to solve by copying emf 2.4 version plugins into dropins ,
But when i try to make build of my project from an antscript it throws out this error . And can u please say what exactly is a launch configuration ? and how is it similar to or different to a Run configuration ?
Re: Bundle org.eclipse.equinox.launcher.win32.win32.x86_1.0.3.R33x_v20080118 failed to resolve. [message #520539 is a reply to message #520079] Fri, 12 March 2010 13:58 Go to previous message
Sabir wrote:
> Hi Paul,
perhaps you should use the Galileo version of emf as well, emf 2.5 can
be downloaded from http://download.eclipse.org/releases/galileo
version
So if all of your plugins compile, then none of them need 3.3. That's good
What's in your ant script? This seems to imply there's a bug in your
script. Maybe in your customTargets.xml, maybe in your
build.properties. Why can't you use your product configuration or
File>Export... to export your product first, to confirm there is no
problem there.
Was there more to the error than that single line. Did it explain who
required
org.eclipse.equinox.launcher.win32.win32.x86_1.0.3.R33x_v200 80118 ?
Usually it's not just a single failure, it provides a list of things.
Sorry, launch configs are Run/Debug configs. This was just a way to
confirm there are no problems Running your app from within eclipse.
PW
Paul Webster
Previous Topic:Changing the classpath of an exported product
Next Topic:Add VIEWS_SHORTLIST(id: viewsShortlist) in the org.eclipse.ui.menus extension
Current Time: Fri Jul 18 07:32:45 EDT 2025
Powered by FUDForum. Page generated in 0.04967 seconds
