Home » Eclipse Projects » Eclipse 4 » XWT callback to specific instance(XWT)
XWT callback to specific instance [message #520304] Thu, 11 March 2010 16:11 Go to next message
I am trying out XWT and running into some confusion.
My foo.xwt has a tag referencing the Java class providing callback support.
For example,
<Composite ... x:Class="Foo">
<Button x:style="SWT.PUSH" text="Bar" SelectionEvent="selection" ></Button>
with a file Foo.java containing the callback handler
public class Foo extends Composite {
public XwtComponent1(Composite parent, int style) {
super(parent, style);
protected void selection(Event event) {
Now, from Bar.java I am loading the XWT to open the GUI. I'd like to have
the button click go to a method in my BAR.java class and to
the *instance* of BAR which opened the GUI.
What are the mechanics of this or am I going down the wrong path completely?
Re: XWT callback to specific instance [message #520424 is a reply to message #520304] Fri, 12 March 2010 00:48 Go to previous messageGo to next message
<allygirl@mailinator.com> wrote in message
news:hnbmao$iks$1@build.eclipse.org...
> support. For example,
The class must be complete name.
You can find more example codes in org.eclipse.e4.xwt.tests.
Yves
> ></Button>
> the *instance* of BAR which opened the GUI. What are the mechanics of this
Re: XWT callback to specific instance [message #520499 is a reply to message #520424] Fri, 12 March 2010 11:05 Go to previous messageGo to next message
Thank you for your response. Perhaps I oversimplified the first part of my post. Yes, the class would be fully qualified.... The core part of my question is the second half regarding having the widget callback (selection(...) ) either 1) go to an instanceof x.y.Foo that is known by my code (vs. a new instance created by the XWT engine) or 2) the callback goes to the instance which requested XWT to open the GUI spec to begin with. I reviewed many of the test examples and nothing is jumping out as addressing this question. Can you point me to an example?
i.e. a button on the XWT created GUI which calls back into the code which opened that XWT GUI.
Many thanks for any assistance you can provide.
Re: XWT callback to specific instance [message #520579 is a reply to message #520499] Fri, 12 March 2010 15:56 Go to previous messageGo to next message
You can specify BAR directly in x:Class.
yves
news:hndonv$h8b$1@build.eclipse.org...
Re: XWT callback to specific instance [message #520580 is a reply to message #520579] Fri, 12 March 2010 16:02 Go to previous message
Precisely, you can look at the class XWTAbstractPart in
org.eclipse.e4.xwt.ui.workbench:
newOptions.put(XWTLoader.CLASS_PROPERTY, this);
Yves
"Yves YANG" <yves.yang@soyatec.com> wrote in message
news:hne9qj$2h6$1@build.eclipse.org...
> Regards
> yves
Re: XWT callback to specific instance [message #570336 is a reply to message #520579] Fri, 12 March 2010 16:02 Go to previous message
Yves
> Regards
> yves
Previous Topic:XWT callback to specific instance
Next Topic:XWT. How to set absolute (null) layout?
Current Time: Sat Jul 26 17:03:23 EDT 2025
Powered by FUDForum. Page generated in 0.04405 seconds
