Home » Archived » BPMN Modeler » Parse a .bpmn-File
Parse a .bpmn-File [message #520392] Fri, 12 March 2010 03:46 Go to next message
I'm trying to convert BPMN-Diagramms created with the BPMN-modeler into our own modeling-language. So i have to parse the .bpmn-File. My problem is that I don't understand how the .bpmn-file is created and what it's structure is. It is neither consistent with the .xsd not with the .ecore in the Model.
So all I can do at the moment is to look into the .bpmn-file and figure out what it's structure is.
One of my greatest problems is, that there are two IDs for every element (except associations) and I dont't know wich one is referenced.
So can you please tell me how it is created?
Re: Parse a .bpmn-File [message #524478 is a reply to message #520392] Thu, 01 April 2010 02:30 Go to previous messageGo to next message
Originally posted by: atoulme.intalio.com
Trust me, the bpmn file is consistent with the xsd and the ecore file -
since everything is generated from them.
How do you parse the file ? Through a XML parser ? Why don't you use EMF
to load the file and browse it ?
> in the Model.
Re: Parse a .bpmn-File [message #524502 is a reply to message #524478] Thu, 01 April 2010 04:05 Go to previous messageGo to next message
Thanks for the reply.
Never worked with EMF before.I am using it since a few days. Fixed a lot of my Problems.
Re: Parse a .bpmn-File [message #637089 is a reply to message #524502] Thu, 04 November 2010 03:14 Go to previous messageGo to next message
I have the same question, but how can I do that? I don't know how to use ResourceSet to get bpmn file. Anyone can help me please? Thanks a lot.
Re: Parse a .bpmn-File [message #637150 is a reply to message #637089] Thu, 04 November 2010 07:57 Go to previous messageGo to next message
try this:
File bpmnFile = new File(_pathToFile_);
ResourceSet rs = new ResourceSetImpl();
URI uri = URI.createFileURI(bpmnFile.getAbsolutePath());
Resource resource = rs.getResource(uri, true);
BpmnDiagram bpmnModel = (BpmnDiagram ) resource.getContents().get(0);
best regards,
Gilbert
Re: Parse a .bpmn-File [message #637625 is a reply to message #637150] Sun, 07 November 2010 22:28 Go to previous messageGo to next message
Thanks a lot. I've had a try to do so, by using a template plugin example hello world from eclipse. I just put a line of instantiating a ResourceSet object as follow (on the SampleAction.java) and got a problem:
public void run(IAction action) {
Date dt = new Date();
/*ResourceSet rs = new ResourceSetImpl();*/
MessageDialog.openInformation(
window.getShell(),
"One",
"Hello, Eclipse world " + dt.toString());
When I open the line, it does not work, but if I close the line the dialog can be shown. My planning is, when those code works I want to put information of a certain bpmn model on the dialog e.g. name pool, etc., just for testing. I do not know what is going on, I am a beginner in this plug n development. Can help me please? Thanks.
Takoner
Re: Parse a .bpmn-File [message #637659 is a reply to message #637625] Mon, 08 November 2010 03:26 Go to previous messageGo to next message
I think you should tell us about what exactly does not work. Any console
output or error log entries?
> window.getShell(),
> "One",
> Takoner
Re: Parse a .bpmn-File [message #637670 is a reply to message #637659] Mon, 08 November 2010 05:05 Go to previous message
No console output shown as expected, and I can not debug at all as well. Thanks.
Previous Topic:Generating bpmn file in a server runtime environment
Next Topic:Version of BPMN specification
Current Time: Wed Jul 23 20:27:49 EDT 2025
Powered by FUDForum. Page generated in 0.05430 seconds
