Home » Eclipse Projects » Eclipse 4 » e4 1.0M4: example psf still points to R0_9 and photo sample not compiling
e4 1.0M4: example psf still points to R0_9 and photo sample not compiling [message #520308] Thu, 11 March 2010 16:26 Go to next message
I installed e4 1.0M4 and generate the example project via menu.
however the psf still points to the 0.9 Release. is this intended ?
I think it should be tag 1_0M4, right ?
also please note that the photoapplication does not compile (at least
using 1.0M4 with the R0_9 version of the photo sample.
thanks,
Berni.
<psf version="2.0">
<provider id="org.eclipse.team.cvs.core.cvsnature">
<project
reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/eclipse,e4/org.eclipse .e4.ui/examples/org.eclipse.e4.demo.contacts,org.eclipse.e4. demo.contacts,R0_9 "/>
<project
reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/eclipse,e4/org.eclipse .e4.ui/examples/org.eclipse.e4.demo.e4photo,org.eclipse.e4.d emo.e4photo,R0_9 "/>
</provider>
</psf>
Re: e4 1.0M4: example psf still points to R0_9 and photo sample not compiling [message #520347 is a reply to message #520308] Thu, 11 March 2010 18:14 Go to previous messageGo to next message
what does not compile in photo?
Cheers, Lars
http://www.vogella.de/ - Eclipse plugin and Eclipse RCP Tutorials
http://www.twitter.com/vogella - vogella on Twitter
On 11.03.2010 13:26, Bernhard Merkle wrote:
> thanks,
> Berni.
> <psf version="2.0">
> <project
> <project
> </provider>
> </psf>
Re: e4 1.0M4: example psf still points to R0_9 and photo sample not compiling [message #520375 is a reply to message #520347] Fri, 12 March 2010 02:21 Go to previous messageGo to next message
Lars Vogel wrote on Thu, 11 March 2010 18:14
ExifTable.java
import org.eclipse.e4.core.services.events.IEventBroker;
@Inject
private IEventBroker eventBroker;
type seems to be moved or removed...
kind regards,
Berni.
Re: e4 1.0M4: example psf still points to R0_9 and photo sample not compiling [message #520556 is a reply to message #520308] Fri, 12 March 2010 14:19 Go to previous messageGo to next message
Did you get the e4 1.0M4 SDK zip or did you install it on top of
something existing?
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: e4 1.0M4: example psf still points to R0_9 and photo sample not compiling [message #520558 is a reply to message #520556] Fri, 12 March 2010 14:27 Go to previous messageGo to next message
>> Hi,
> something existing?
i get the e4 1.0M4 SDK from the website, clean fresh install.
new workspace etc. so should be easy to reproduce.
Berni.
Re: e4 1.0M4: example psf still points to R0_9 and photo sample not compiling [message #520589 is a reply to message #520558] Fri, 12 March 2010 18:21 Go to previous message
okay, please ignore this post. my 1.0M4 installation was somehow
corrupted. after reinstall everything worked fine....
Berni.
Re: e4 1.0M4: example psf still points to R0_9 and photo sample not compiling [message #569927 is a reply to message #520308] Thu, 11 March 2010 23:03 Go to previous message
Cheers, Lars
> thanks,
> Berni.
> <psf version="2.0">
> <project
> <project
> </provider>
> </psf>
Re: e4 1.0M4: example psf still points to R0_9 and photo sample not compiling [message #570012 is a reply to message #569927] Fri, 12 March 2010 02:21 Go to previous message
ExifTable.java
@Inject
kind regards,
Berni.
Re: e4 1.0M4: example psf still points to R0_9 and photo sample not compiling [message #570237 is a reply to message #520308] Fri, 12 March 2010 14:19 Go to previous message
something existing?
PW
Paul Webster
Re: e4 1.0M4: example psf still points to R0_9 and photo sample not compiling [message #570273 is a reply to message #520556] Fri, 12 March 2010 14:27 Go to previous message
>> Hi,
> something existing?
Berni.
Re: e4 1.0M4: example psf still points to R0_9 and photo sample not compiling [message #570393 is a reply to message #520558] Fri, 12 March 2010 18:21 Go to previous message
Berni.
Previous Topic:XWT. How to set absolute (null) layout?
Next Topic:XWT and Form Layout - Problems ?
Current Time: Sat Jul 26 02:59:28 EDT 2025
Powered by FUDForum. Page generated in 0.04262 seconds
