Home » Eclipse Projects » Remote Application Platform (RAP) » Icons initially not visible in perspective
Icons initially not visible in perspective [message #519847] |
Wed, 10 March 2010 03:42  |
Hi all,
with RAP 1.3.0M5 we run into a strange behaviour. Our application
consists of some perspectives. If I initially start the application, the
perspectives are all shown, but the icons for the commands which are
assigned to the perspective aren't visible. They only appear if I change
the perspective. In the debugger I've seen that the handler for this
perspective isn't called initially (only if I switch to another
perspective and back). The plugin.xml is as follows:
<extension
point="org.eclipse.ui.perspectives">
<perspective
class="my.perspectives.PerspectiveFactory01"
id="my.perspectives.Test01"
name="Test01">
</perspective>
<perspective
class="my.perspectives.PerspectiveFactory02"
id="my.perspectives.Test02"
name="Test02">
</perspective>
</extension>
<extension
point="org.eclipse.ui.commands">
<command
defaultHandler="my.handlers.ShowTest01Handler"
id="my.commands.ShowTest01"
name="Show Test01">
</command>
</extension>
<menuContribution
locationURI="toolbar:my.ui.view.Test01">
<command
commandId="my.ui.commands.Store"
icon="src/main/resources/icons/fam/page_save.png"
label="Save"
style="push"
tooltip="save">
<visibleWhen>
<with variable="activePartId">
<test property="my.test.isEnabled"/></with>
</visibleWhen>
</command>
<command
commandId="my.ui.commands.Create"
icon="src/main/resources/icons/fam/page_add.png"
id="createPulldownCommand"
label="New"
style="push"
tooltip="New">
<visibleWhen>
<test property="my.test.isEnabledForCreate"/></with>
</visibleWhen>
</command>
</menuContribution>
</extension>
Even if I omit the visibleWhen part the icons (page_save and page_add in
this case) aren't shown. Has something changed there in RAP?
TIA,
Ralf.
Re: Icons initially not visible in perspective [message #520221 is a reply to message #520121] |
Thu, 11 March 2010 05:34   |
Ralf Sternberg schrieb:
> Hi Ralf,
> Are you using a design provided by the the rap.design.example bundle?
> Does it make a difference when you access your application like this:
> http://HOST:PORT/rap?startup=ENTRYPOINT
Hi Ralf,
it doesn't make a difference.
> If so, it might be a regression of this bug:
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=295451
The bug description sounds like the same problem, and the project
content looks similar to mine. But I can't get the example run. I always
get Error 404 if I launch the test project. And initially after
importing the project my IDE complaints about "Access restrictions":
Access restriction: The type PlatformUI is not accessible due to
restriction on required library
C:\MyProjects\plugins\rap-bundles_1.3.0-M5\plugins\org.eclip se.rap.ui.workbench_1.3.0.20100201-1223.jar
I've set a target environment with the new RAP version. Perhaps someone
could check if the bug occurs with the actual Milestone release.
TIA,
Ralf.
> R. Heydenreich wrote:
>> Hi all,
>> <extension
>> <perspective
>> name="Test01">
>> </perspective>
>> <perspective
>> name="Test02">
>> </perspective>
>> </extension>
>> <extension
>> <command
>> name="Show Test01">
>> </command>
>> </extension>
>> <menuContribution
>> <command
>> label="Save"
>> style="push"
>> tooltip="save">
>> <visibleWhen>
>> </visibleWhen>
>> </command>
>> <command
>> label="New"
>> style="push"
>> tooltip="New">
>> <visibleWhen>
>> </visibleWhen>
>> </command>
>> </menuContribution>
>> </extension>
>> TIA,
>> Ralf.
Re: Icons initially not visible in perspective [message #520384 is a reply to message #520221] |
Thu, 11 March 2010 22:30   |
Hi Ralf,
does this error occurs while using one of the new designs (business or
fancy) or in the default look and feel? It's important for us to know
because the new designs and the default look uses different managers
for displaying contribution items.
Regards Holger
>> Hi Ralf,
> Hi Ralf,
I've
> TIA,
> Ralf.
>>> Hi all,
>>> <extension
>>> <perspective
>>> name="Test01">
>>> </perspective>
>>> <perspective
>>> name="Test02">
>>> </perspective>
>>> </extension>
>>> <extension
>>> <command
>>> name="Show Test01">
>>> </command>
>>> </extension>
>>> <menuContribution
>>> <command
>>> label="Save"
>>> style="push"
>>> tooltip="save">
>>> <visibleWhen>
>>> </visibleWhen>
>>> </command>
>>> <command
>>> label="New"
>>> style="push"
>>> tooltip="New">
>>> <visibleWhen>
>>> </visibleWhen>
>>> </command>
>>> </menuContribution>
>>> </extension>
>>> TIA,
>>> Ralf.
http://eclipsesource.com
http://twitter.com/eclipsesource
Re: Icons initially not visible in perspective [message #520419 is a reply to message #520221] |
Fri, 12 March 2010 05:31   |
Hi Ralf,
see my comments below...
>> Hi Ralf,
> Hi Ralf,
Then it is not related to the designs. Would you open a bug for this issue?
M5 definitely works, there is no such access restriction. I guess you
need to reload your target / rebuild your projects etc. You don't have
another version of this bundle in your workspace, have you?
Best regards, Ralf
>>> Hi all,
>>> <extension
>>> <perspective
>>> name="Test01">
>>> </perspective>
>>> <perspective
>>> name="Test02">
>>> </perspective>
>>> </extension>
>>> <extension
>>> <command
>>> name="Show Test01">
>>> </command>
>>> </extension>
>>> <menuContribution
>>> <command
>>> label="Save"
>>> style="push"
>>> tooltip="save">
>>> <visibleWhen>
>>> </visibleWhen>
>>> </command>
>>> <command
>>> label="New"
>>> style="push"
>>> tooltip="New">
>>> <visibleWhen>
>>> </visibleWhen>
>>> </command>
>>> </menuContribution>
>>> </extension>
>>> TIA,
>>> Ralf.
Re: Icons initially not visible in perspective [message #520492 is a reply to message #520419] |
Fri, 12 March 2010 10:23  |
> Hi Ralf,
>>> Hi Ralf,
>> Hi Ralf,
OK. I will try to create a simple project that shows the bug. This will
take some time.
No, I've installed a clean eclipse (3.5) and added my projects. Clean
and rebuild didn't solve the problem.
Ralf.
> Best regards, Ralf
>>>> Hi all,
>>>> <extension
>>>> <perspective
>>>> name="Test01">
>>>> </perspective>
>>>> <perspective
>>>> name="Test02">
>>>> </perspective>
>>>> </extension>
>>>> <extension
>>>> <command
>>>> name="Show Test01">
>>>> </command>
>>>> </extension>
>>>> <menuContribution
>>>> <command
>>>> label="Save"
>>>> style="push"
>>>> tooltip="save">
>>>> <visibleWhen>
>>>> </visibleWhen>
>>>> </command>
>>>> <command
>>>> label="New"
>>>> style="push"
>>>> tooltip="New">
>>>> <visibleWhen>
>>>> </visibleWhen>
>>>> </command>
>>>> </menuContribution>
>>>> </extension>
>>>> TIA,
>>>> Ralf.
Current Time: Sat Jul 19 04:37:56 EDT 2025
Powered by FUDForum. Page generated in 0.17537 seconds
