Home » Eclipse Projects » Buckminster dev » [Buckminster-dev] CQuery: Can branchTagPath and revision be based on environment properties?
[Buckminster-dev] CQuery: Can branchTagPath and revision be based on environment properties? [message #519848] Wed, 10 March 2010 03:48
I'd like to be able to pass in an environment variable into a CQuery which indicates the branch and version (revision). This allows setting up a build environment (from Subversion) for any branch/revision without each new branch needing a new/modified cquery.
Right now, the only way I see to set the branchTagPath and revision is to hard code them in the cquery (FYI: just have one advisor node for ".*" which adds the revision and branch info for everything). Is it possible to use environment variables, or something else, to set the branchTagPath and revision during a resolve? Maybe there's a different strategy I should consider?
Matt
Previous Topic:[buckminster-dev] Project meta data is out of date for tools.buckminster
Next Topic:Panel debate on Continous Integration and Build at EclipseCon
Current Time: Fri Jul 18 18:59:56 EDT 2025
Powered by FUDForum. Page generated in 0.03595 seconds
