| FormSection question [message #50542] | Tue, 27 May 2003 16:06  |  |
| Eclipse User  |  |  |  |  | Originally posted by: lmap.canada.com
 I am playing with the FormSection class and getting an weird behavior.  When
 I open my editor with an expanded form section, the form's control is 3 or 4
 lines higher than what I would like it to be.  If I collapse and expand the
 form, the height is adjusted to the expected value.  What am I missing?
 Btw, I know this is an internal API and that we should not be using it.  But
 I need to implement the PDE editor's look & feel so I need to use those
 classes (better than keeping reinventing the wheel).  I am now trying to
 decide if I should leave a dependency to an internal package or if I should
 copy the jar to my plugin.  Any tips here?  Another related question: does
 anyone know why the org.eclipse.update.ui.forms.internal.* classes are not
 part of API?
 Thx in advance!
| Re: FormSection question [message #51974 is a reply to message #50542] | Wed, 28 May 2003 10:33  |  |
| Eclipse User  |  |  |  |  | Luiz,
 I started a small project that extracts the minimal components required
 for a collapsable textbox.  If you'd like to take a look,
 :pserver:anonymous@cvs.zclipse.sourceforge.net:/cvsroot/zclipse
 (CollapsableTextBox project, run using the XTextboxTester)
 I started looking into extracting this for the same reason you list
 below, so that I'm not using internal APIs.  I'd definitely like to get
 access to the PDE stuff, but I can understand why eclipse is reluctant
 to add every complex widget to the core public API.
 Incidentally, I'm interested in creating or hooking into a component
 repository where working code components can be freely shared and used.
 As it relates to your post, if eclipse won't make the PDE widgets
 public, and you are able to extract the widgets yourself, it would be
 nice to have a one-stop shop for finding your work and not have to
 reinvent the wheel (org.zclipse.zlibrarian project in the same cvs
 repository is the thing I've just started working on).
 Todd
 Luiz Marcelo wrote:
 > part of API?
 > Thx in advance!
FUDForum. Page generated in 0.04316 seconds
