Home » Modeling » UML2 » How to : UML deep modifications(How, in fact, to build the UML2 plug-in)
How to : UML deep modifications [message #519242] Mon, 08 March 2010 04:21 Go to next message
Hi everybody,
in my quest of understanding EMF, I'm currently trying to make modifications on UML.
Starting from the tutorial "Customizing UML", I got the point that what I have to do is an heavyweight modification.
In fact, what I have to do is to add/modify elements and associations in UML with adding a new package.
My first thought was to start from the UML2 plug-in, to modify the meta-model inside, to regenerate the plug-in / java classes, and to push this new plug-in to check the modifications.
But it seems to be a massive set of plug-ins (I downloaded the package "SDK" at this address : http://www.eclipse.org/modeling/mdt/downloads/?project=uml2)
which is composed of a lot of jars. I started to check the uml package : (org.eclipse.uml2.uml.source_3.0.1.v200908281330.jar), composed itself by a lot of UML files (L1, L2, L3, uml.uml, ...)
My questions are very simple :
1 - Is it correct to modify the plug-in like that?
2 - Where can I find documentation for developers about UML2 project? (just found javadoc)
3 - I guess there is a reason to have so many files...?
4 - The UML specification is divided into packages. My extension should be made in the same kind : making a new package, merging another one. But in the file UML.uml, I didn't found this package structure. Is it normal?
Thank you for the help!
Re: How to : UML deep modifications [message #519250 is a reply to message #519242] Mon, 08 March 2010 04:43 Go to previous messageGo to next message
[Updated on: Wed, 10 March 2010 08:55] by Moderator
Re: How to : UML deep modifications [message #519281 is a reply to message #519242] Mon, 08 March 2010 01:28 Go to previous messageGo to next message
Am 08.03.2010 10:21, schrieb CaribeanAlien:
> My questions are very simple : 1 - Is it correct to modify the plug-in
> like that?
It's usually better to check out the needed projects directly from CVS:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.mdt/org .eclipse.uml2/plugins/?root=Modeling_Project
I guess the homepage http://www.eclipse.org/uml2 is a good place to
start. The left nav has a link to the wiki, too:
http://wiki.eclipse.org/MDT-UML2
Certainly ;-)
Cheers
/Eike
Re: How to : UML deep modifications [message #519329 is a reply to message #519250] Mon, 08 March 2010 04:24 Go to previous messageGo to next message
Vlad,
Coments below.
Vlad Varnica wrote:
> Hi Alien :p ,
> IQuote:
> This is an EMF limitation as soon as you try you deal with
> associations modification and nested packages creation.
Normally of one wishes to add/modify something one has the choice of
either extending classes normally in a new package or modifying the
existing classes directly, which is generally a bad design approach.
I'm not sure how this is an EMF limitation, it's just the way the
universe works.
> All open source UML solutions are built on the top of EMF and GMF,
> therefore you can not get what you expect using one of them !!
Your line of reasoning is bizarre.
> Quote:
> This is a logical way to work because you have the model, the editor,
> the mapping between the model and the editor, and the transformation
> stage. The best for each project is look directly in the code and
> don't forget that without the 3 month required training you will not
> be able to understand the framework and change it for your needs. It
> is better to contribute in this case.
Only three months now? I though it would take 1 or 2 years.
> Quote:
>> normal?
> Yes, you are right and UML model information should be saved inside
> packages. If you use EclipseUML2 metamodel then you will see that this
> package architecture is already respected. The problem is the EMF
> transformation stage, so you can not change it.
The OMG defines the concept of package merging where independently
defined aspects of a given "element" are merged. The UML project
implements this merging algorithm and applies to UML's definition to
arrive at a merged definition. Note that I said the UML project defines
this and applies it, not EMF itself.
> My personal feeling in order not to waste your time is that you should
> consider two options and have a clear view of you need.
> You either want to create an UML solution or to be an UML user.
> If you want to create your own tool from scratch then you have a
> personal investment of about 18 months. You should learn EMF, GMF or
> GEF and UML 2. For each framework a 3 months book reading and
> exercices and then 3 months first project test (e.g. your first
> project will be mediocre but it is more a test). After 18 months if
> your motivation is still high then you should start your modeling
> project.
> If you want to use open source tool and see missing features then you
> should contribute and not just ask other to do the job for you. I mean
> that you can contribute by many ways, even writing a documentation is
> a contribution.
Have you not dished out this drivel enough times yet?
> If you don't want to create your tools, or to contribute then you have
> two choices which are using open source, say thanks never complain or
> pay to use professional tools and have the right to compalin because
> you have paid.
To answer the actual question that's been asked, there are two choices.
Defining a heavy weight extension, which involves extending the UML
model and generating that extension, or defining a light weight
extension, which involves defining a profile that can be used to
stereotype UMLs base artifacts. The latter approach is much more
amenable to reusing all the existing tools so unless it proves
inadequate for your needs, that's the easier way to go.
Re: How to : UML deep modifications [message #519351 is a reply to message #519242] Mon, 08 March 2010 10:11 Go to previous messageGo to next message
To Vlad,
thank you for the reply. I totally agree with the philosophy of contributing to open source projects.
If you want to use open source tool and see missing features then you should contribute and not just ask other to do the job for you. I mean that you can contribute by many ways, even writing a documentation is a contribution.
I'm not asking others to do my job! I'm currently trying to get into UML2 and EMF, and to apply a simple modification (adding a class, or modify a class to have relationships with another elements for example). I guess this would be doable, but I haven't found information about how to do that. I have checked the different tutorials, the long talk inside the Eclipsepedia UML page, etc... I have ordered the EMF book, and will start study it soon. But still, I didn't get any information about UML2 development.
What I asked was more something like "hey guys, I'm a newbie, I desperately try to get into the project, but the documents I read didn't help me. Did I miss something?", and not "I don't understand, please do my job in my place". I just want to know if there is an entry point to this big project.
So, if you tell me there is no documentation to enter into UML2, I would be happy to write it during my "investigation".
(For the packages, I think I found them in "Infrastructure.uml")
To Eike : thanks for the CVS root, I'will check it.
To Ed :
Thanks for the precisions. I don't remember where I found this information, but I think it won't be possible with a profile (light weight extension) to alter existing associations.
But still, even if my solution can be solved with a lightweight modification, I'm curious to know how these heavyweight modifications can be applied, and I will try to experiment it one day, just for curiosity of seeing how this works.
Re: How to : UML deep modifications [message #519416 is a reply to message #519351] Mon, 08 March 2010 13:20 Go to previous messageGo to next message
Comments below.
CaribeanAlien wrote:
> To Vlad,
> Quote:
Don't take offense. Vlad tends not to address the actual issues that
are raised. It seems he can't help it.
There's not a lot of information for UML2.
> To Ed : Thanks for the precisions. I don't remember where I found this
Extending UML is a very complex task for a beginner. You'd need to
extend UML's UML2.ecore (if you have UML2 installed in the ID, you can
load UML's Ecore modeling into the Sample Ecore Editor using Load
Resource...->Browse Registered Packages to find UML's namespace. You
also need to and be sure you're using UML's extended GenModel, not just
EMF's base GenModel; I think the importer only creates UML's extended
GenModel if you load Ecore from a UML model though so you'll need to
fiddle with the GenModel namespace in the document...
Re: How to : UML deep modifications [message #519704 is a reply to message #519416] Tue, 09 March 2010 12:37 Go to previous messageGo to next message
[Updated on: Wed, 10 March 2010 08:54] by Moderator
Re: How to : UML deep modifications [message #523762 is a reply to message #519242] Mon, 29 March 2010 04:48 Go to previous messageGo to next message
Hi guys,
a few weeks after my last post, I just wanted to tell about my work on modifying UML2.
Well, as it was said previously, it's way not easy to do it! Being rigorous is really important in this kind of task.
First advice : check the build details! It's really important to set up the environment correctly. By that, I mean having the correct version of EMF, the correct JDK/JRE, ... In order to do that, I had to download the latest dev. version of Eclipse (with EMF 2.6 => couldn't migrate from 2.5 to 2.6 on a Galileo Eclipse, don't know why)
Then, checking out from CVS the sources. Here come the first trick: you got on CVS a lot of projects. I was interested in org.eclipse.uml2.uml, but then I realize there was also a "releng" version of this project. What is this "releng"? If I understood correctly, it's a project you need to use to build the former. Reading some documentation, I conclude that in this project, there is a file you can use to check out the former project and its dependency.
At this point, I got all needed projects. So I started to browse the main project (uml2.uml), in order to understand what is the goal of those files. It's important from there to understand the goal of this project : wiki-UML2
* a useable implementation of the UML metamodel to support the development of modeling tools
* a common XMI schema to facilitate interchange of semantic models
* test cases as a means of validating the specification
* validation rules as a means of defining and enforcing levels of compliance
I'm still working on understanding the meaning of each file, in order to do my own modifications. I'm unfortunately missing time, so I hope I'll get a chance to go deeper, and write a documentation from what I learned.
But it's really, really difficult, and a little bit frustrating.
So, here is my simple question :
During this browsing, I understood that, as in any EMF project, code is generated from the genmodel. I just finished regenerating it, it seems to work. But, as long as I'm doing a slight difference "adding an element 'foo', supertyped by Element, on the UML.ecore, I'm having troubles. I succeed in generating the genmodel, but then, when generating code, it fails.
So : is there a way to make this modification? Where should I look closer? Is the genmodel customized, or something?
Thank you for your help!
Re: How to : UML deep modifications [message #523813 is a reply to message #523762] Mon, 29 March 2010 04:46 Go to previous messageGo to next message
What specifically do you mean by "it fails"? Are you updating the UML
model of UML and reloading the Ecore version from that?
> Hi guys,
> modifying UML2.
> rigorous is really important in this kind of task. First advice :
> project : http://wiki.eclipse.org/MDT-UML2
> compliance
> learned. But it's really, really difficult, and a little bit frustrating.
> generating code, it fails. So : is there a way to make this
> or something?
Re: How to : UML deep modifications [message #523879 is a reply to message #523813] Mon, 29 March 2010 13:30 Go to previous messageGo to next message
actually, I'm currently making modification on uml.merge.uml, which is the "source" of the genmodel (I was wrong previously, it's not the UML.ecore).
I'm currently facing 2 situations :
- modification of .uml -> update .genmodel -> generate model code : calculation, modifications, but no file creation for the new element
- same as before, but first delete .java files : compilation errors. I'm currently exploring this solution : started with 13 errors, 5 remaining.
It seems that the genmodel is not the only one file generating code, or there are human-added files also. I hope an improving tomorrow Smile
Re: How to : UML deep modifications [message #523885 is a reply to message #523879] Mon, 29 March 2010 09:10 Go to previous messageGo to next message
Be sure to monitor the Error Log view for potential problems there.
> UML.ecore).
> remaining.
> or there are human-added files also. I hope an improving tomorrow :)
Re: How to : UML deep modifications [message #524524 is a reply to message #523885] Thu, 01 April 2010 05:13 Go to previous messageGo to next message
Thanks Ed, you were right, it was a memory issue causing the missing classes. (java heap space). I fix it, and kind of succeed making some modifications in the generations.
So I'm now testing it. I think I made my modifications in a wrong way; since I didn't know exactly on which uml level to put my modifications, I modified directly the uml.merged.uml. Seems to work, but now I realized that standalone applications have to load at the beginning the uml2.uml.resource jar file. I manage to regenerate this jar file, but it seems it doesn't take modifications from the same uml.merged.uml file. So I have an old version of resource, and a new implementation in the uml2.uml plug-in.
I'll try to figure out how to fix it. But still, the lack of docs make the work hard. Does anyone else feel this lack? Do you think it could be possible to organize a group with some people to write this documentation? I would be interested to work on it. Smile
Re: How to : UML deep modifications [message #529210 is a reply to message #524524] Fri, 23 April 2010 09:14 Go to previous messageGo to next message
Hello all
let me share,
UML extension is 2 type light weight using Profiles, stereotypes , tagged values and Heavy weight using new concepts as u mentioned
why using Eclipse extension I guess what u need is a tool that allow heavy weight Eclipse of course has a plugin project that is special for heavy weight and My freind work was on that
I advise u to read more about eclipse projects and tools for heavy weight and I will try to give u the specific eclipse project
I hope this could help u
wafaa
Re: How to : UML deep modifications [message #628316 is a reply to message #519250] Mon, 08 March 2010 09:04 Go to previous messageGo to next message
Vlad,
Coments below.
Vlad Varnica wrote:
> Hi Alien :p ,
> IQuote:
universe works.
> Quote:
> Quote:
>> normal?
> project.
> a contribution.
> you have paid.
Re: How to : UML deep modifications [message #628322 is a reply to message #519351] Mon, 08 March 2010 13:20 Go to previous messageGo to next message
Comments below.
> To Vlad,
> Quote:
Re: How to : UML deep modifications [message #628323 is a reply to message #519416] Tue, 09 March 2010 12:37 Go to previous messageGo to next message
> The OMG defines the concept of package merging where independently defined aspects of a given "element" are merged. The UML project implements this merging algorithm and applies to UML's definition to arrive at a merged definition. Note that I said the UML project defines this and applies it, not EMF itself.
I am not talking about package merge but just about UML metamodel structure composed by packages !!
btw, I don't care for package merge and feel free to do as you want this is just a non sense for me !!
Re: How to : UML deep modifications [message #628387 is a reply to message #524524] Fri, 23 April 2010 09:14 Go to previous message
Hello all
let me share,
wafaa
Previous Topic:create InterfaceRealization issue
Next Topic:UML2 metamodel
Current Time: Sat Jul 26 06:45:51 EDT 2025
Powered by FUDForum. Page generated in 0.11398 seconds
