Home » Modeling » GMF (Graphical Modeling Framework) » Drawing blocks with predefined inputs/outputs
Drawing blocks with predefined inputs/outputs [message #519572] Tue, 09 March 2010 06:06 Go to next message
I am currently investigating if GMF would be a good choice to develop a specific type of editor.
In this editor, I have a certain types of blocks which can be dragged on the canvas. Each block type has a specific number of inputs and outputs. The user can then link inputs/outputs of a block to other blocks on the canvas.
The number (and name and type) of the inputs/ouptuts are fixed and depends on the block which is selected.
It is something similar as a digital electronic diagram in which you can add components and link them together.
Do you think GMF could be used to realize something like that without too much 'hacking' ?
The point which is not clear for me is how to be able to add "complex" elements to a diagram (the blocks + the inputs/outputs) and forbid the user to delete the inputs/outputs of the block.
Re: Drawing blocks with predefined inputs/outputs [message #520386 is a reply to message #519572] Fri, 12 March 2010 03:26 Go to previous message
Totally, GMF does it perfectly with really few changes. Actually, I did
the same think and I just had to add one line of code for the placement
of the port relatively to its parent.
Le 09/03/2010 12:06, C a écrit :
> Hello,
> canvas.
> Thanks
Previous Topic:Draw a Lozange from Polygon
Next Topic:One domain file and multiple diagram files: is it possible?
Current Time: Sat Jul 19 01:55:50 EDT 2025
Powered by FUDForum. Page generated in 0.06152 seconds
