Home » Eclipse Projects » Rich Client Platform (RCP) » Hideing an Editor
Hideing an Editor [message #518967] Fri, 05 March 2010 10:19 Go to next message
I want to hide Editors and restore the later.
Something like
editorOne.open();
editorOne.setVisible( false );
editorTwo.open()
editorTwo.setVisible( false );
editorOne.setVisible( true );
Is this possible ? Does anybody knows how ?
André
Re: Hideing an Editor [message #519004 is a reply to message #518967] Fri, 05 March 2010 06:36 Go to previous messageGo to next message
there is some API that can help ... it mostly works :-)
See org.eclipse.ui.IWorkbenchPage.hideEditor(IEditorReference)
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: Hideing an Editor [message #519096 is a reply to message #519004] Sat, 06 March 2010 06:54 Go to previous messageGo to next message
Thanks !!
Currently I work with Eclipse 3.4 as target platform, the method hideEditor is not available in this release Sad
So I build this workaround
	 public static void hideEditor( IWorkbenchPage page, IEditorReference ref) {
//	    if (!(this.editorPresentation.containsEditor((EditorReference)ref))) {
//	      return;
		 // this.editorPresentation.closeEditor(ref);
		 Field field = FieldUtils.findField( page.getClass(), "editorPresentation");
		 Object obj = FieldUtils.get( page, field );
		 Method method = MethodUtils.findMethod( obj.getClass(), "closeEditor", new Class[] { IEditorReference.class } );
		 MethodUtils.invoke( obj, method, ref );
		 // this.activationList.remove(ref);
		 field = FieldUtils.findField( page.getClass(), "activationList");
		 method = MethodUtils.findMethod( obj.getClass(), "remove", new Class[] { IEditorReference.class } );
	    //updateActivePart();
		 method = MethodUtils.findMethod( page.getClass(), "updateActivePart", new Class[0] );
		 MethodUtils.invoke( page, method );
		 IEditorPart editor = ref.getEditor(false);
		 if( editor != null ) {
			 SaveablesList modelManager = (SaveablesList) editor.getSite().getService(ISaveablesLifecycleListener.class);
			 Object result = modelManager.preCloseParts( Arrays.asList(editor), true, editor.getEditorSite().getWorkbenchWindow() );
			 modelManager.postClose( result );
	 public static void showEditor( IWorkbenchPage page, IEditorReference ref) {
//		      return;
			 // this.editorPresentation.addEditor((EditorReference)ref, "", false);
			 Method method = MethodUtils.findMethod( obj.getClass(), "addEditor", new Class[] { EditorReference.class, String.class } );
			 MethodUtils.invoke( obj, method, ref, "" );
			 // this.activationList.add(ref);
			 method = MethodUtils.findMethod( obj.getClass(), "add", new Class[] { IEditorReference.class } );
		    //this.removedEditors.add(ref); TODO
André
Re: Hideing an Editor [message #519409 is a reply to message #519096] Mon, 08 March 2010 12:58 Go to previous message
I'll just offer a word of caution, certain other internals were shifted
around to make that work in 3.5. As long as it does what you want, of
course it's great, but I would try and run a few tests to make sure you
are not leaking editors anywhere.
PW
Paul Webster
Previous Topic:Adding login-type check to oe.ui.ide.workbench Product
Next Topic:Problem with Splash Browser
Current Time: Thu Jul 17 23:22:00 EDT 2025
Powered by FUDForum. Page generated in 0.07118 seconds
