Home » Eclipse Projects » Eclipse Platform » Should I be able to create a "category" element in extension point "org.eclipse.ui.co
Should I be able to create a "category" element in extension point "org.eclipse.ui.co [message #518793] Thu, 04 March 2010 20:13 Go to next message
I'm stepping through "Creating Eclipse Plugins". I was trying to create a command. The instructions in the book said to add an extension from the "org.eclipse.ui.commands" extension point. I found that, but it then said to create a new "category" from the "New" context menu. However, instead of "category", I only see "Generic". Is this expected? Should I have done something else beforehand in order to be able to add "category" off of that extension point?
Re: Should I be able to create a "category" element in extension point "org.eclipse.u [message #518981 is a reply to message #518793] Fri, 05 March 2010 10:52 Go to previous messageGo to next message
When downloading eclipse there are usually 2 version offered. runtime
and SDK. The SDK includes all of the source + schema, and that schema
is what PDE uses to fill in the context menu.
You need to get the Eclipse SDK (or update your runtime to an SDK with
all the source).
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: Should I be able to create a "category" element in extension point "org.eclipse.u [message #518985 is a reply to message #518981] Fri, 05 March 2010 10:58 Go to previous messageGo to next message
So without installing an entirely new distribution, is there a practical way to "update your runtime to an SDK with
all the source"? I wouldn't mind downloading a new distribution, if I could just integrate the pieces I need into my existing distribution, without much risk of screwing it up.
Re: Should I be able to create a "category" element in extension point "org.eclipse.u [message #519402 is a reply to message #518985] Mon, 08 March 2010 07:58 Go to previous message
Depends on where you got your distribution from ... if it is the galileo
distro, then simply use Help>Install new software to install the Eclipse
SDK (PDE SDK, JDT SDK, Platform SDK and RCP SDK are the ones that should
get installed from hopefully the one main feature).
PW
Paul Webster
Previous Topic:Veto Undo
Next Topic:convert webworks help to eclipse help
Current Time: Fri Jul 25 19:27:53 EDT 2025
Powered by FUDForum. Page generated in 0.04788 seconds
