Home » Eclipse Projects » Rich Client Platform (RCP) » How can I get the path of the project
How can I get the path of the project [message #519293] Mon, 08 March 2010 07:25 Go to next message
Hello, I'm developing a plug-in for Eclipse. I want to save some folders inside the project to use it when it will be published.
The problem is that I don't know how to get the path in will it be the plug-in when it's going to be "installed" on the eclipse. So, how can I get that path?.
For example..the answer I need at get the path in windows would be:
c:\eclipse\plug-ins\myplugin\folderIwanttouse....
or something similar...the problem is that I don't know the first part of the path...
Thank you!
Re: How can I get the path of the project [message #519298 is a reply to message #519293] Mon, 08 March 2010 07:48 Go to previous messageGo to next message
You can retrieve the location of a plugin using: Platform.getBundle("myplugin").getLocation()
and you can also get the URL of included folders and resources using: Platform.getBundle("myplugin").findEntries("folder", "*.jpeg", true). Keep in mind that the URL it returns may be bundleresource:// urls, so that you'll probably have to use FileLocator.toFileURL on them.
Mickael Istria - BonitaSoft S.A.
http://www.bonitasoft.com/products/downloads.php
Re: How can I get the path of the project [message #519524 is a reply to message #519298] Tue, 09 March 2010 03:35 Go to previous messageGo to next message
In my case I had to create a directory Template in the Workspace directory. To do this i use this code:
String templateAbsoluteRoot = Platform.getLocation().toOSString()
			+ PlatformUI.getPreferenceStore().getDefaultString(PreferencesUtils.SEPARATOR)
			+ PlatformUI.getPreferenceStore().getDefaultString(PreferencesUtils.DIR_TEMPLATE);
File templateD = new File(templateAbsoluteRoot);
		if( ! templateD.exists() )
			templateD.mkdir();
Remember the dependence
org.elcipse.core.resources
in your plugin.xml
Re: How can I get the path of the project [message #519707 is a reply to message #519293] Tue, 09 March 2010 12:48 Go to previous messageGo to next message
Hello, thank you so much.
I have tried to use:
the problem, is that I don't know how to put like the string of getbundle... I have seen my plugin.xml and I have the id of the plugin...also the name....
I have tried with both and it didn't work...
I must missing something...what?
I also has though about add the dependence that says Luca Gallici on the plugin.xml but I don't know where....in it
Re: How can I get the path of the project [message #519729 is a reply to message #519293] Tue, 09 March 2010 09:28 Go to previous messageGo to next message
See what Mickael wrote. Bundle#findEntries(*) and Bundle#getEntry(*)
can give you access to folders that are in your plugin. Consider this a
read-only location.
Then the question becomes what to do with them. To copy them out for
use, simply get the InputStream and away you go.
If you are using a legacy API that needs a java.io.File (as opposed to
an InputStream) then use FileLocator.toFileURL(*) to make sure you have
a file that you can use (FileLocator even copies it out to a temporary
location if necessary).
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: How can I get the path of the project [message #520172 is a reply to message #519293] Thu, 11 March 2010 07:59 Go to previous messageGo to next message
Thank you Paul Webster, but the problem is that I don't know what to use in:
What I must put on the "myplugin" string?
I have tried with the id wizard or name wizard that it's on the plugin.xml, but the execution stops a that time.
I suppose once I have this fixed, I only must use the methods you say to access to the folder I want.
Thank you!
Re: How can I get the path of the project [message #520176 is a reply to message #520172] Thu, 11 March 2010 08:02 Go to previous messageGo to next message
> in:
You have to put the id of the plugin. It is the value of Bundle-SymbolicName that you can read in your MANIFEST.MF.
Re: How can I get the path of the project [message #520401 is a reply to message #519293] Fri, 12 March 2010 04:47 Go to previous messageGo to next message
A lot of thanks!
It works perfectly. I have seen that the path I get is the path of the myplugin project in the workspace. I suppose that if it's would be installed the path will be indicates the folder of the plugin inside de eclipse folder, won't be?.
[Updated on: Fri, 12 March 2010 04:54] by Moderator
Re: How can I get the path of the project [message #520541 is a reply to message #520401] Fri, 12 March 2010 09:06 Go to previous message
José wrote:
> Thanks!
> I have seen it, but the problem I'm having is that I'm receiving an
> error at executing this instruction:
> I suppose the problem is that I'm not putting the correct string where
> it's the "myplugin" one. I have tried with the Id and the Name that are
> in the plugin.xml...
1) it must be the Bundle-SymbolicName (as mentioned by Mickael) from
your MANIFEST.MF file (check in the MANIFEST tab if you have the PDE
editor open). There shouldn't be a relevant ID in your plugin.xml
2) do you run with a workspace? Either a real workspace (because you
use org.eclipse.core.resources), or try simply -data
/path/to/a/temp/workspace
Later,
PW
Paul Webster
Previous Topic:Running a java program from Plugin Application
Next Topic:Changing the classpath of an exported product
Current Time: Fri Jul 18 22:16:00 EDT 2025
Powered by FUDForum. Page generated in 0.30719 seconds
