Home » Modeling » EMF » how to use CDO dynamic ....?( Is there dynamic CDO?)
| how to use CDO dynamic ....? [message #518434] |
Thu, 04 March 2010 01:12  |
in the FAQ this question is answerd like this
| Quote: |
Yes. You can register dynamic EPackages with a CDOSession and commit them to the repository.
Note, that you can generally only register top-level packages with a CDO session.
Nested packages are registered implicitely if they have a namespace URI.
Ok the question is now how? or better what is wrong in the following code?
EPackage rootPackage = createRootPackage();
cdoSession.getPackageRegistry().putEPackage(rootPackage);
cdoResource = cdoTransaction.getOrCreateResource("/model");
cdoResource.getContents().add(rootPackage);
cdoTransaction.commit();
becase this throw a
java.lang.IllegalStateException: Revision was not registered: CDOResource@OID1:0v2
The seconed question is how to create dynamic objects?
EFactory eFactory = eClass.getEPackage().getEFactoryInstance();
EObject newObject = eFactory.create(eClass);
cdoResource.getContents().add(newObject);
thows ...
java.lang.IllegalArgumentException: Use CDOFactory to create dynamic object:org.eclipse.emf.ecore.impl.DynamicEObjectImpl@2ebade60
So how to use CDOFactory?
Are there some CDO dynamic tutorials?
THX
Stephan
[Updated on: Thu, 04 March 2010 01:17] by Moderator
| Re: how to use CDO dynamic ....? [message #518801 is a reply to message #518738] |
Thu, 04 March 2010 23:22   |
--------------090304040101030607030709
Am 04.03.2010 21:43, schrieb Stephan Zehrer:
>> I don't think you want to add an EPackage to a resource, right?
> Why not?
Because there is no implementation of EPackage that implements
InternalCDOObject at the same time. In other word, Ecore itself is not a
CDO native model. Hence it can not be stored in CDOResources in a
repository. Please note that this will change very soon when Martin has
finished the implementation of our new "legacy" mode. That will allow
you to store non-native objects in CDO resources.
> Where else they will be stored? How do I commit the "add" of my
> (root)Package on a session?
Packages are committed implicitely, if needed. You just need to register
them with the session package registry and CDO will recognize if you're
going to commit objects of classes of these packages. Please note that
even the registration of needed packages happens automatically. Only in
the case of dynamic packages you need to do it *before* you even create
objects (because the CDOFactory has to be set).
> I my test code I have a transaction open but is this required for
> the registration of a package?
You can not commit packages if they are not needed by objects (in a
commit operation).
> Maybe some background infos:
> In my current pure EMF implementation I have all my (dynamic) classes
> definition in a "metamodel" resource and my objects several other
> resources. No i try to migrate to CDO ...
>>> becase this throw a java.lang.IllegalStateException: Revision was
>>> not registered: mailto:CDOResource@OID1:0v2
>> OID1 is generally the internal root resource of the resource (folder)
>> structure. Recently I fixed a problem in that area and possibly this
>> exception does not appear with the latest sources or builds. Can you
>> confirm this?
> Well now i updated on CDO 3.0.0v20100304-1006 but now run into this
> line (class EmbeddedClientSessionProtocol) (by calling openTransaction)
> // TODO: implement
> EmbeddedClientSessionProtocol.loadRevisions(infos, branchPoint,
> referenceChunk, prefetchDepth)
> throw new UnsupportedOperationException();
> I there a better change if I go back to CDO 2.X?
No, CDO 3.0 is recommended. But the embedded session is not yet fully
implemented. It's work in progress that has been suspended in favour of
the branching support and offline mode work. I've added an
UnsupportedOperationException to the constructor of
EmbeddedClientSessionConfiguration to make this obvious a bit earlier in
your setup. Sorry for the inconvenience.
That said, you can already embed sessions via Net4j JVM transport. Just
create a normal CDONet4jSessionConfiguration and configure a JVMConnector:
| IAcceptor acceptor =
(IAcceptor)IPluginContainer.INSTANCE.getElement("org.eclipse.net4j.acceptors ",
"jvm", "myAcceptor");
IConnector connector =
(IConnector)IPluginContainer.INSTANCE.getElement("org.eclipse.net4j.connectors ",
"jvm", "myAcceptor");|
CDOSessionConfiguration configuration = CDONet4jUtil.createSessionConfiguration();
configuration.setConnector(connector);
configuration.setRepositoryName(repositoryName);|
Cheers
/Eike
>> This is shorter:
>> EObject newObject = EcoreUtil.create(eClass);
> Ok thx
>> Usually the CDOPackageRegistry recognizes dynamic packages
>> automatically and replaces the EFactory instance. But you must ensure
>> that you are using that factory. So, after registering the package
>> with the session registry you can create new DynamicCDOObjectImpl
>> instances. You can not use instances with CDO that you created
>> *before* the package was registered with CDO!
> Ok .. but I think i have complied this order...
>> I don't think so. Please feel free to add one to
>> http://wiki.eclipse.org/User_Contributed_CDO_Documentation ;)
> As far as it will work :)
Content-Type: text/html; charset=UTF-8
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<meta content="text/html; charset=UTF-8" http-equiv="Content-Type">
</head>
<blockquote cite="mid:hmp61r$1ml$1@build.eclipse.org" type="cite">
<blockquote type="cite">
<blockquote type="cite">cdoResource =
<br>
<br>
</blockquote>
<br>
</blockquote>
Why not?
<br>
</blockquote>
a CDO native model. Hence it can not be stored in CDOResources in a
you to store non-native objects in CDO resources.<br>
<br>
<blockquote cite="mid:hmp61r$1ml$1@build.eclipse.org" type="cite">Where
else they will be stored? How do I commit the "add" of my (root)Package
on a session?
<br>
</blockquote>
register them with the session package registry and CDO will recognize
if you're going to commit objects of classes of these packages. Please
note that even the registration of needed packages happens
automatically. Only in the case of dynamic packages you need to do it
*before* you even create objects (because the CDOFactory has to be set).<br>
<br>
<blockquote cite="mid:hmp61r$1ml$1@build.eclipse.org" type="cite"><br>
<br>
<br>
</blockquote>
commit operation).<br>
<br>
<br>
resources. No i try to migrate to CDO ... <br>
<br>
<blockquote type="cite">cdoTransaction.commit();
<br>
becase this throw a java.lang.IllegalStateException: Revision was not
registered: <a class="moz-txt-link-freetext" href="mailto:CDOResource@OID1:0v2">mailto:CDOResource@OID1:0v2</a>
<br>
</blockquote>
confirm this?
<br>
</blockquote>
<br>
<br>
// TODO: implement
<br>
<br>
<br>
<br>
</blockquote>
in your setup. Sorry for the inconvenience.<br>
<br>
JVMConnector:<br>
<br>
<title></title>
<style type="text/css">
<!--code { font-family: Courier New, Courier; font-size: 10pt; margin: 0px; }-->
</style>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8">
<!-- = Java Sourcecode to HTML automatically converted code = --><!-- = Java2Html Converter 5.0 [2006-02-26] by Markus Gebhard markus@jave.de = -->
<!-- = Further information: http://www.java2html.de = -->
<div class="java" align="left">
<table bgcolor="#ffffff" border="0" cellpadding="3" cellspacing="0">
<tbody>
<tr>
<!-- start source code --> <td align="left" nowrap="nowrap"
valign="top"> <code><font color="#ffffff"> </font><font
color="#000000">IAcceptor acceptor = </font><font color="#000000">(</font><font
color="#000000">IAcceptor</font><font color="#000000">)</font><font
color="#000000">IPluginContainer.INSTANCE.getElement</font ><font
color="#000000">(</font><font color="#2a00ff">"org.eclipse.net4j.acceptors"</font><font
color="#000000">, </font><font color="#2a00ff">"jvm"</font><font
color="#000000">, </font><font color="#2a00ff">"myAcceptor"</font><font
color="#000000">)</font><font color="#000000">;</font><br>
<font color="#ffffff"> </font><font color="#000000">IConnector connector = </font><font
color="#000000">(</font><font color="#000000">IConnector</font><font
color="#000000">)</font><font color="#000000">IPluginContainer.INSTANCE.getElement</font ><font
color="#000000">(</font><font color="#2a00ff">"org.eclipse.net4j.connectors"</font><font
color="#000000">)</font><font color="#000000">;</font></code> </td>
<!-- end source code --> </tr>
</tbody>
</table>
</div>
<!-- = END of automatically generated HTML code = -->
<tbody>
<tr>
<td align="left" nowrap="nowrap" valign="top"><code><font
color="#ffffff"> </font><font color="#000000"> CDOSessionConfiguration configuration = CDONet4jUtil.crea teSessionConfiguration </font><font
color="#000000">()</font><font color="#000000">;</font><br>
<font color="#ffffff"> </font><font color="#000000">configuration.setConnector</font><font
color="#000000">(</font><font color="#000000">connector</font><font
<font color="#ffffff"> </font><font color="#000000">configuration.setRepositoryName</font><font
color="#000000">(</font><font color="#000000">repositoryName</font><font
</tbody>
</table>
</div>
<!-- ======================================================== --><br>
<br>
Cheers<br>
/Eike<br>
<br>
----<br>
<a class="moz-txt-link-freetext" href="http://thegordian.blogspot.com">http://thegordian.blogspot.com</a><br>
<a class="moz-txt-link-freetext" href="http://twitter.com/eikestepper">http://twitter.com/eikestepper</a><br>
<br>
<br>
<blockquote type="cite">EFactory eFactory =
<br>
<br>
</blockquote>
This is shorter:
<br>
<br>
</blockquote>
Ok thx
<br>
<br>
<blockquote type="cite">So how to use CDOFactory?
<br>
</blockquote>
that you are using that factory. So, after registering the package with
the session registry you can create new DynamicCDOObjectImpl instances.
You can not use instances with CDO that you created *before* the
<br>
</blockquote>
<br>
<br>
<br>
<blockquote type="cite">I don't think so. Please feel free to add one
to <a class="moz-txt-link-freetext" href="http://wiki.eclipse.org/User_Contributed_CDO_Documentation">http://wiki.eclipse.org/User_Contributed_CDO_Documentation</a> ;)
<br>
</blockquote>
<br>
<br>
<br>
</blockquote>
</body>
</html>
--------------090304040101030607030709--
| Re: how to use CDO dynamic ....? [message #519220 is a reply to message #518801] |
Mon, 08 March 2010 01:58   |
[quote title=Eike Stepper wrote on Thu, 04 March 2010 23:22]
>> Why not?
>Because there is no implementation of EPackage that implements InternalCDOObject at the same time. In other word, Ecore itself is not a CDO native model. Hence it can not be stored in CDOResources in a repository. Please note that this will change very soon when Martin has
>finished the implementation of our new "legacy" mode. That will allow you to store non-native objects in CDO resources.
Ok I will discuss this later cause I thought I was already able to do this with the Gastro Server and standard CDO UI Eclipse plugin.
>Packages are committed implicitely, if needed. You just need to register them with the session package registry and CDO will recognize if you're going to commit objects of classes of these packages. Please note that
>even the registration of needed packages happens automatically. Only in the case of dynamic packages you need to do it *before* you even create objects (because the CDOFactory has to be set).
Ah ok ... maybe you should update your FAQ entry ...
| Quote: |
>> // TODO: implement
>No, CDO 3.0 is recommended. But the embedded session is not yet fully implemented. It's work in progress that has been suspended in favour of the branching support and offline mode work. I've added an
>UnsupportedOperationException to the constructor of EmbeddedClientSessionConfiguration to make this obvious a bit earlier in your setup. Sorry for the inconvenience.
>That said, you can already embed sessions via Net4j JVM transport. Just create a normal CDONet4jSessionConfiguration and configure a JVMConnector:
Ok now I wrote some (standalone) example code
http://wiki.eclipse.org/CDO_Embedded
I am using a container wired configuration. I is required to use 2 containers?
Because I run into this problem ...
Exception in thread "main" java.lang.UnsupportedOperationException
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.doSave(ResourceImpl.java:1438)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(ResourceImpl.java:1406)
at org.eclipse.emf.cdo.common.model.EMFUtil.getEPackageBytes(EMFUtil.java:250)
at org.eclipse.emf.cdo.server.internal.db.MetaDataManager.getEPackageBytes(MetaDataManager.java:201)
at org.eclipse.emf.cdo.server.internal.db.MetaDataManager.fillSystemTables(MetaDataManager.java:227)
at org.eclipse.emf.cdo.server.internal.db.MetaDataManager.fillSystemTables(MetaDataManager.java:267)
at org.eclipse.emf.cdo.server.internal.db.MetaDataManager.writePackageUnits(MetaDataManager.java:158)
at org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.writePackageUnits(DBStoreAccessor.java:573)
at org.eclipse.emf.cdo.internal.server.Repository.initSystemPackages(Repository.java:1073)
at org.eclipse.emf.cdo.internal.server.Repository.doActivate(Repository.java:1036)
at org.eclipse.net4j.util.lifecycle.Lifecycle.activate(Lifecycle.java:70)
at org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(LifecycleUtil.java:98)
at org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(LifecycleUtil.java:88)
at org.eclipse.emf.cdo.server.CDOServerUtil.addRepository(CDOServerUtil.java:90)
at StandaloneCDODynamic.run(StandaloneCDODynamic.java:73)
at StandaloneCDODynamic.main(StandaloneCDODynamic.java:61)
| Re: how to use CDO dynamic ....? [message #520029 is a reply to message #519831] |
Wed, 10 March 2010 16:33   |
Hi Eike,
[quote title=Eike Stepper wrote on Wed, 10 March 2010 01:15]
>Your example code was missing this important piece of code:
>CDONet4jServerUtil.prepareContainer(container);
Ahh thx, well I already mentioned the problem of finding all relevent documentation.
In your Gastro Server Example you call first "addRepository" and afterwards "prepareContainer". But this will not fix the issue ..
>But that didn't cause your problem. Although the stack trace you showed is different, I found a bug in your snippet. You're calling
>resource.eContents() instead of resource.getContents(). Read the JavaDoc and you'll realize the small but important difference
Ups .. just a type I know the different but I never reach the point during debuging
>I fixed your wiki article accordingly.
Thx but ... did you test it?
Because in my setup i still have the problem in the line
CDOServerUtil.addRepository(container, cdoRepository);
even I have added the CDONet4jServerUtil.prepareContainer(container); line.
It started to setup the database but agin this error
main [org.eclipse.emf.cdo.internal.common.model.CDOPackageRegistryImpl] Registering http://www.eclipse.org/emf/2002/Ecore --> org.eclipse.emf.ecore.impl.EcorePackageImpl@2eda2cef (name: ecore) (nsURI: http://www.eclipse.org/emf/2002/Ecore, nsPrefix: ecore)
main [org.eclipse.emf.cdo.internal.common.model.CDOPackageRegistryImpl] Registering http://www.eclipse.org/emf/CDO/Eresource/2.0.0 --> org.eclipse.emf.cdo.eresource.impl.EresourcePackageImpl@d5c0f9 (name: eresource) (nsURI: http://www.eclipse.org/emf/CDO/Eresource/2.0.0, nsPrefix: eresource)
main [org.eclipse.emf.cdo.server.internal.db.MetaDataManager] Writing package unit: CDOPackageUnit[id=http://www.eclipse.org/emf/2002/Ecore, state=LOADED, type=LEGACY, originalType=LEGACY, timeStamp=Mar 10, 2010 22:11:20:139]
main [org.eclipse.net4j.db.DBUtil] INSERT IGNORE INTO cdo_package_units VALUES (?, ?, ?, ?)
main [org.eclipse.net4j.util.lifecycle.Lifecycle] Deactivating DBStoreAccessor@20
main [org.eclipse.net4j.util.lifecycle.Lifecycle] Deactivating SmartPreparedStatementCache@21
at StandaloneCDODynamic.run(StandaloneCDODynamic.java:74)
at StandaloneCDODynamic2.main(StandaloneCDODynamic2.java:62)
T.G.I.F
Stephan
| Re: how to use CDO dynamic ....? [message #520082 is a reply to message #520029] |
Thu, 11 March 2010 01:09   |
Am 10.03.2010 22:33, schrieb Stephan Zehrer:
> Hi Eike,
> documentation.
> afterwards "prepareContainer". But this will not fix the issue .. :(
The background:
When a client opens a session through the Net4j protocol a new IChannel
through the IConnector is created and needs to be associated with the
CDO protocol on the server side. This protocol instance is the
"connection" between the Net4j channel and the repository. For this
purpose the server-side IConnector has a protocol factory configured
(contributed to the IManagedContainer with the
CDONet4jServerUtil.prepareContainer() call). That is the
CDOServerProtocolFactory. To find the appropriate repository this
factory needs an IRepositoryProvider. You can also create your own
provider that only knows the repository that you explicitely created.
But in the example you're using a container-based provider, i.e. one
that looks up the repository by name in the container. This is the
reason why you need both, the repository instance in the container and
the protocol factory *before* the first session is opened. The order of
these two calls is not relevant.
>> JavaDoc and you'll realize the small but important difference ;)
> during debuging :)
Yes, it worked nicely. I attached my console log.
> line.
> main
> [org.eclipse.emf.cdo.internal.common.model.CDOPackageRegistr yImpl]
> main
> 22:11:20:139]
> VALUES (?, ?, ?, ?)
> DBStoreAccessor@20
> at
> org.eclipse.emf.ecore.resource.impl.ResourceImpl.doSave(Reso urceImpl.java:1438)
> at
> org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(Resour ceImpl.java:1406)
> at
> org.eclipse.emf.cdo.common.model.EMFUtil.getEPackageBytes(EM FUtil.java:250)
> at
> org.eclipse.emf.cdo.server.internal.db.MetaDataManager.getEP ackageBytes(MetaDataManager.java:201)
> at
> org.eclipse.emf.cdo.server.internal.db.MetaDataManager.fillS ystemTables(MetaDataManager.java:227)
> at
> org.eclipse.emf.cdo.server.internal.db.MetaDataManager.fillS ystemTables(MetaDataManager.java:267)
> at
> org.eclipse.emf.cdo.server.internal.db.MetaDataManager.write PackageUnits(MetaDataManager.java:158)
> at
> org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.write PackageUnits(DBStoreAccessor.java:573)
> at
> org.eclipse.emf.cdo.internal.server.Repository.initSystemPac kages(Repository.java:1073)
> at
> org.eclipse.emf.cdo.internal.server.Repository.doActivate(Re pository.java:1036)
> at
> org.eclipse.net4j.util.lifecycle.Lifecycle.activate(Lifecycl e.java:70)
> at
> org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(Life cycleUtil.java:98)
> at
> org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(Life cycleUtil.java:88)
> at
> org.eclipse.emf.cdo.server.CDOServerUtil.addRepository(CDOSe rverUtil.java:90)
This stack trace does not match latest HEAD. Can you retry with that?
Cheers
/Eike
| Re: how to use CDO dynamic ....? [message #522229 is a reply to message #522141] |
Sun, 21 March 2010 10:20   |
Hi Stephan,
It strikes me that your problem could be related with this one:
303466: CDO not robust when using dynamic packages
https://bugs.eclipse.org/bugs/show_bug.cgi?id=303466
I suggest you start a discussion there with Jasper...
Cheers
/Eike
Am 20.03.2010 05:01, schrieb Stephan Zehrer:
> Eike Stepper wrote on Fri, 19 March 2010 15:55
>> > No sorry .. still the same error in my standalone version.
>> > Even with the latest update of today. (I updated the libraries on
>> the > wiki page) I could not find it yet ... it seems it throws the >
>> exception the following line
>> That's odd. And I'm already packing for the EclipseCon and can not
>> investigate ;-(
> No problem, it is just an example, not high prio.
> Quote:
>> > It seems for "org.eclipse.emf.cdo.server.db" there is no source
>> code > bundle.
>> I can see
>> org.eclipse.emf.cdo.server.db.source_3.0.0.v20100317-1547.ja r
> Yes sorry ... was my mistake, forgot to update a library.
> The error is in following method of MetaDataManager (cdo.server)
> private byte[] getEPackageBytes(InternalCDOPackageUnit packageUnit)
> EPackage ePackage =
> packageUnit.getTopLevelPackageInfo().getEPackage();
> CDOPackageRegistry packageRegistry =
> getStore().getRepository().getPackageRegistry();
> return EMFUtil.getEPackageBytes(ePackage, ZIP_PACKAGE_BYTES,
> packageRegistry);
> Within the EMFUtil.getEPackageBytes(...) method a "resource.save ..."
> is called but in this case the related resource is a EMF resource
> where save is not implemented.
> My feeling says in general this problem is related of a wrong or
> missing lib.
> Is there somewhere a full list of required libs if you run CDO
> standalone?
> Quote:
>> Yes, we added a last minute hot fix that checks that the store
>> properties (SUPPORTING_BRANCHES) are in line with the adequate
>> mapping strategy.
> Ok :)
> Quote:
>> > If "IRepository.Props.SUPPORTING_BRANCHES" is disabled it works.
>> > Is the configuration of the example wrong?
>> What example?
> as usually http://wiki.eclipse.org/CDO_Embedded#Libraries :)
> Have fun in Santa Clara :)
> T.G.I.F.
> Stephan
| Re: how to use CDO dynamic ....? [message #545453 is a reply to message #518434] |
Wed, 07 July 2010 16:24   |
Hi everyone
I want to embed a database into my application to avoid communication with the server and so improve performances.
I use the example CDO_Embedded (http://wiki.eclipse.org/CDO_Embedded)
The server begins starting,
but the same error as in the previous posts occurs in CDOServerUtil.addRepository.
main [org.eclipse.emf.cdo.internal.common.model.CDOPackageRegistryImpl] Registering http://www.eclipse.org/emf/2002/Ecore --> org.eclipse.emf.ecore.impl.EcorePackageImpl@8c436b (name: ecore) (nsURI: http://www.eclipse.org/emf/2002/Ecore, nsPrefix: ecore)
main [org.eclipse.emf.cdo.internal.common.model.CDOPackageRegistryImpl] Registering http://www.eclipse.org/emf/CDO/Eresource/2.0.0 --> org.eclipse.emf.cdo.eresource.impl.EresourcePackageImpl@1094d48 (name: eresource) (nsURI: http://www.eclipse.org/emf/CDO/Eresource/2.0.0, nsPrefix: eresource)
main [org.eclipse.emf.cdo.server.internal.db.MetaDataManager] Writing package unit: CDOPackageUnit[id=http://www.eclipse.org/emf/2002/Ecore, state=LOADED, type=LEGACY, originalType=LEGACY, timeStamp=7 juil. 2010 17:25:13:467]
at org.eclipse.emf.cdo.common.model.EMFUtil.getEPackageBytes(EMFUtil.java:254)
at org.eclipse.emf.cdo.server.internal.db.MetaDataManager.getEPackageBytes(MetaDataManager.java:174)
at org.eclipse.emf.cdo.server.internal.db.MetaDataManager.fillSystemTables(MetaDataManager.java:201)
at org.eclipse.emf.cdo.server.internal.db.MetaDataManager.fillSystemTables(MetaDataManager.java:244)
at org.eclipse.emf.cdo.server.internal.db.MetaDataManager.writePackageUnits(MetaDataManager.java:106)
at org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.writePackageUnits(DBStoreAccessor.java:552)
at org.eclipse.emf.cdo.internal.server.Repository.initSystemPackages(Repository.java:1349)
at org.eclipse.emf.cdo.internal.server.Repository.doActivate(Repository.java:1312)
at org.eclipse.net4j.util.lifecycle.Lifecycle.activate(Lifecycle.java:72)
at org.eclipse.emf.cdo.server.CDOServerUtil.addRepository(CDOServerUtil.java:128)
at javaTestAutomaton.EmbeddedServer.start(EmbeddedServer.java:85)
at javaTestAutomaton.EmbeddedServer.<init>(EmbeddedServer.java:66)
at javaTestAutomaton.EmbeddedServer.main(EmbeddedServer.java:70)
(the org.eclipse.emf.ecore.resource.impl.ResourceImpl.doSave function I have has only one instruction : "throw java.lang.UnsupportedOperationException" )
I don't understand what you mean by dynamic packages. Is that the option when migrating a genmodel to CDO or loading ePackages automatically in the data base only when needed.
Did you manage to solve the error in the previous posts ?
( I don't understand what is in https://bugs.eclipse.org/bugs/show_bug.cgi?id=303466)
I think I don't need CDO dynamic. If this is the problem, how to remove it from CDO_Embedded example http://wiki.eclipse.org/CDO_Embedded ?
The problem seems due to ePackage.
When CDOServerUtil.addRepository(container, cdoRepository); is called, the cdoRepository's PackageRegistry is null. So I cannot put any ePackage instance in it. is that the problem ?
Thank you for your help
Suzanne
| Re: how to use CDO dynamic ....? [message #545506 is a reply to message #545453] |
Thu, 08 July 2010 02:20   |
--------------020800070103020207090204
Hi Suzanne,
Comments below...
Cheers
/Eike
Contact: http://www.esc-net.de Blogger <http://thegordian.blogspot.com>Twitter <http://twitter.com/eikestepper>Linkedin <http://de.linkedin.com/in/eikestepper>Xing <http://www.xing.com/profile/Eike_Stepper>
Article: What exactly is inside that p2 repository? < http://thegordian.blogspot.com/2010/05/what-exactly-is-insid e-that-p2.html>
Am 07.07.2010 22:24, schrieb Suzanne:
> Hi everyone
What version of CDO are you using?
> main [org.eclipse.emf.cdo.internal.common.model.CDOPackageRegistr yImpl] Registering http://www.eclipse.org/emf/2002/Ecore --> org.eclipse.emf.ecore.impl.EcorePackageImpl@8c436b (name: ecore) (nsURI: http://www.eclipse.org/emf/2002/Ecore, nsPrefix: ecore)
> main [org.eclipse.emf.cdo.internal.common.model.CDOPackageRegistr yImpl] Registering http://www.eclipse.org/emf/CDO/Eresource/2.0.0 --> org.eclipse.emf.cdo.eresource.impl.EresourcePackageImpl@1094d48 (name: eresource) (nsURI: http://www.eclipse.org/emf/CDO/Eresource/2.0.0, nsPrefix: eresource)
Does your instance model (one of your client resources) contain instances of EModelElement, e.g. EClasses?
The legacy mode is only present in CDO 3.0 and must be explicitely enabled per CDOView/CDOTransaction: http://www.eclipse.org/cdo/documentation/relnotes_30/relnote s-3.0.html#Legacy_models_are_now_supported
Please note that we've not yet tested if the legacy mode supports instances of Ecore itself, as this is really a special case.
> at org.eclipse.emf.ecore.resource.impl.ResourceImpl.doSave(Reso urceImpl.java:1438)
> at org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(Resour ceImpl.java:1406)
> at org.eclipse.emf.cdo.common.model.EMFUtil.getEPackageBytes(EM FUtil.java:254)
> at org.eclipse.emf.cdo.server.internal.db.MetaDataManager.getEP ackageBytes(MetaDataManager.java:174)
> at org.eclipse.emf.cdo.server.internal.db.MetaDataManager.fillS ystemTables(MetaDataManager.java:201)
> at org.eclipse.emf.cdo.server.internal.db.MetaDataManager.fillS ystemTables(MetaDataManager.java:244)
> at org.eclipse.emf.cdo.server.internal.db.MetaDataManager.write PackageUnits(MetaDataManager.java:106)
> at org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.write PackageUnits(DBStoreAccessor.java:552)
> at org.eclipse.emf.cdo.internal.server.Repository.initSystemPac kages(Repository.java:1349)
> at org.eclipse.emf.cdo.internal.server.Repository.doActivate(Re pository.java:1312)
> at org.eclipse.net4j.util.lifecycle.Lifecycle.activate(Lifecycl e.java:72)
> at org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(Life cycleUtil.java:98)
> at org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(Life cycleUtil.java:88)
> at org.eclipse.emf.cdo.server.CDOServerUtil.addRepository(CDOSe rverUtil.java:128)
> at javaTestAutomaton.EmbeddedServer.start(EmbeddedServer.java:8 5)
> at javaTestAutomaton.EmbeddedServer.main(EmbeddedServer.java:70 )
No, it means that an EPackage is loaded directly from an .ecore file at runtime, without a code generation step.
Yes, according to https://bugs.eclipse.org/bugs/show_bug.cgi?id=303466#c19 the fix is available in CDO 3.0 GA (Helios).
I think the problem is that you're either having EModelElement instances in your resources or are using legacy models (dynamic or static/generated) in CDO pre-3.0, or both.
No, see above...
Content-Type: multipart/related;
boundary="------------030900060908090006010205"
--------------030900060908090006010205
<html>
<head>
</head>
Hi Suzanne,<br>
<br>
Comments below...<br>
<br>
<!--WISESTAMP_SIG_75934_START--><span style="color: black;">
<div dir="ltr">
<div>Cheers
<br>
/Eike
<br>
<br>
</div>
<div style="padding: 5px 0pt; font-family: arial,sans-serif;
font-size: 13.3px;"><span style="color: gray;">Contact: <a
href="http://www.esc-net.de">http://www.esc-net.de</a></span>
<a href="http://thegordian.blogspot.com" style="padding: 0pt
2px; color: blue; font-size: 10pt;" _service=""><img
src="cid:part1.02090804.06090402@esc-net.de" alt="Blogger"
style="vertical-align: middle; padding-bottom: 5px;"
border="0" height="16" width="16"></a><a
href="http://twitter.com/eikestepper" style="padding: 0pt
src="cid:part2.01010706.06000600@esc-net.de" alt="Twitter"
href="http://de.linkedin.com/in/eikestepper" style="padding:
0pt 2px; color: blue; font-size: 10pt;" _service=""><img
src="cid:part3.05050606.00070209@esc-net.de"
alt="Linkedin" style="vertical-align: middle;
padding-bottom: 5px;" border="0" height="16" width="16"></a><a
href="http://www.xing.com/profile/Eike_Stepper"
style="padding: 0pt 2px; color: blue; font-size: 10pt;"
_service=""><img
src="cid:part4.01000607.04070200@esc-net.de" alt="Xing"
border="0" height="16" width="16"></a></div>
<div style="color: gray; font-size: 13.3px; padding-bottom:
5px;">Article: <span style="color: blue; text-decoration:
underline;"><a
href=" http://thegordian.blogspot.com/2010/05/what-exactly-is-insid e-that-p2.html"
undefined="">What exactly is inside that p2 repository?</a></span></div>
</div>
</span><!--WISESTAMP_SIG_75934_END--><br>
<br>
<blockquote cite="mid:i12np1$ef5$1@build.eclipse.org" type="cite">Hi
everyone
<br>
<br>
<br>
(<a class="moz-txt-link-freetext" href="http://wiki.eclipse.org/CDO_Embedded">http://wiki.eclipse.org/CDO_Embedded</a>)
<br>
<br>
CDOServerUtil.addRepository. <br>
</blockquote>
What version of CDO are you using?<br>
<br>
<br>
main
Registering <a class="moz-txt-link-freetext" href="http://www.eclipse.org/emf/2002/Ecore">http://www.eclipse.org/emf/2002/Ecore</a> -->
(nsURI: <a class="moz-txt-link-freetext" href="http://www.eclipse.org/emf/2002/Ecore">http://www.eclipse.org/emf/2002/Ecore</a>, nsPrefix: ecore)
<br>
main
Registering <a class="moz-txt-link-freetext" href="http://www.eclipse.org/emf/CDO/Eresource/2.0.0">http://www.eclipse.org/emf/CDO/Eresource/2.0.0</a> -->
<a class="moz-txt-link-freetext" href="http://www.eclipse.org/emf/CDO/Eresource/2.0.0">http://www.eclipse.org/emf/CDO/Eresource/2.0.0</a>, nsPrefix:
eresource)
<br>
CDOPackageUnit[id=<a class="moz-txt-link-freetext" href="http://www.eclipse.org/emf/2002/Ecore">http://www.eclipse.org/emf/2002/Ecore</a>,
2010 17:25:13:467]
<br>
</blockquote>
instances of EModelElement, e.g. EClasses?<br>
<br>
<a class="moz-txt-link-freetext" href=" http://www.eclipse.org/cdo/documentation/relnotes_30/relnote s-3.0.html#Legacy_models_are_now_supported"> http://www.eclipse.org/cdo/documentation/relnotes_30/relnote s-3.0.html#Legacy_models_are_now_supported</a><br>
<br>
instances of Ecore itself, as this is really a special case.<br>
<br>
<br>
<blockquote cite="mid:i12np1$ef5$1@build.eclipse.org" type="cite">main
<br>
DBStoreAccessor@20
<br>
<br>
<br>
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.doSave(Reso urceImpl.java:1438) <br>
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(Resour ceImpl.java:1406) <br>
at
org.eclipse.emf.cdo.common.model.EMFUtil.getEPackageBytes(EM FUtil.java:254) <br>
at
org.eclipse.emf.cdo.server.internal.db.MetaDataManager.getEP ackageBytes(MetaDataManager.java:174) <br>
at
org.eclipse.emf.cdo.server.internal.db.MetaDataManager.fillS ystemTables(MetaDataManager.java:201) <br>
at
org.eclipse.emf.cdo.server.internal.db.MetaDataManager.fillS ystemTables(MetaDataManager.java:244) <br>
at
org.eclipse.emf.cdo.server.internal.db.MetaDataManager.write PackageUnits(MetaDataManager.java:106) <br>
at
org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.write PackageUnits(DBStoreAccessor.java:552) <br>
at
org.eclipse.emf.cdo.internal.server.Repository.initSystemPac kages(Repository.java:1349) <br>
at
org.eclipse.emf.cdo.internal.server.Repository.doActivate(Re pository.java:1312) <br>
at
<br>
at
org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(Life cycleUtil.java:98) <br>
at
org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(Life cycleUtil.java:88) <br>
at
org.eclipse.emf.cdo.server.CDOServerUtil.addRepository(CDOSe rverUtil.java:128) <br>
at
<br>
at
javaTestAutomaton.EmbeddedServer.<init>(Embedd edServer.java:66)
<br>
at
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
at runtime, without a code generation step.<br>
<br>
<br>
<br>
<a class="moz-txt-link-freetext" href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=303466">https://bugs.eclipse.org/bugs/show_bug.cgi?id=303466</a>)
<br>
</blockquote>
Yes, according to
<a class="moz-txt-link-freetext" href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=303466#c19">https://bugs.eclipse.org/bugs/show_bug.cgi?id=303466#c19</a> the fix is
available in CDO 3.0 GA (Helios).<br>
<br>
<blockquote cite="mid:i12np1$ef5$1@build.eclipse.org" type="cite">I
<a class="moz-txt-link-freetext" href="http://wiki.eclipse.org/CDO_Embedded">http://wiki.eclipse.org/CDO_Embedded</a> ?
<br>
<br>
<br>
</blockquote>
static/generated) in CDO pre-3.0, or both.<br>
<br>
<blockquote cite="mid:i12np1$ef5$1@build.eclipse.org" type="cite">When
<br>
</blockquote>
No, see above...<br>
<br>
<br>
</body>
</html>
Content-Type: image/png;
name="blogger.png"
Content-ID: <part1.02090804.06090402@esc-net.de>
Content-Disposition: inline;
filename="blogger.png"
iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAMAAAAoLQ9TAAAABGdBTUEAAK/I NwWK6QAAABl0
RVh0U29mdHdhcmUAQWRvYmUgSW1hZ2VSZWFkeXHJZTwAAADkUExURf9xEv9m AP////9lAP+Q
SP9kAP9jAP9fAP9nAf9vD//x5/9hAP/iz/9iAP9eAP/s4P9vEP9yEv9qAP9q B/+LRP+we/90
I/+RSP/z6/+jZv/y6P+8kP/59f5yE//awf/Ttv9hAf9nAv/17v+4if9sC/9o BP+bWP/r3v/k
0v+wfP+QRv/o2f9gAP+OQ/93HP/l0/+0gv/Rsv/9/P/j0P+pcP+0hf/dx//D m//+/v+td/9o
AP+NQv/Yvf+zgv/x6P/q2/9xG//p2f9pAP/s3//8+fxxE//ex/+AK/9oCP/j 0f/Uuv///4Xw
StcAAABMdFJOU/////////////////////////////////////////////// ////////////
/////////////////////////////////////////wCejeTMAAAAsklEQVR4 2kSP1w6DMBAE
7cMGQg0hvffee++d//+f2IaIeTlppNXtIo88UAjxEIlhjCUG5lwJQuwoulqh FuUGcWGSiTF7
bt40EEoXBKtyIPQS5PffFqyHlhCS2obTK5kDmJ8lXxgA0zsPXer0L3zSUVmI D9ip3SC+hKwQ
2CxCtXYYL25gu1S8bf4jib5fTM+MNE079jom/+KwJUojwnAVifcQ46jM4M23 BHmkEK53iPcT
YACE/Q4KzoVQVwAAAABJRU5ErkJggg==
name="twitter.png"
Content-ID: <part2.01010706.06000600@esc-net.de>
filename="twitter.png"
iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8/9hAAAABmJLR0QA/wD/ AP+gvaeTAAAA
CXBIWXMAAABIAAAASABGyWs+AAAACXZwQWcAAAAQAAAAEABcxq3DAAABxUlE QVQ4y4WTMW4U
QRBFX3X3zoy8FgZphTCYAEg4gAPEYbgBJEgEXIALkHMfAjIwItnAAfLK2JYB r3dmuj7BzI5m
2WBLqqzq//q/fxt9NTmrzo7MCIhgRpWSsaMSgEta5czcjYtWTKPxfALZXTEE 2wmAxLXD11VL
BZy2MAuJB/iuA3oAoJb4lUUCVkAGTM5t06gjATMjBiPFaFsADvx1MTFoBd/q zHkMeLcLgCEe
JqjbrCJ1IAkghGDz20Z/XEzMMMTnZTsSYANMAl7fq7YlZOBaUCCk4WowwyRA mBmL7CxcmwDu
rh+rzKU71YhQ/dnr8VbiaRF4MgmbAAZkxJU7lRk3Wby5W3FcJlbSICAjZjFS jJ42rSXWgoWL
fYPfLvaCMTVxJ0XoJTmQ/stF6GPABDhzcepi7uJ74yQDuXcDErjjGhkwNvHx xCjMOMkCg3eX
S85zyVEMtGt24GWVxvsM5yi3+nBV8/7iBmJv0gaZQMZhNL4cHXBYdDkY7HQL vD0oebVfQuud
a8FGHSAaP1vnpMmbHgDEECwafLq/x8fZlGfJKCVKiapvXLyoEsdl3JYwBMpd uW1YEjlz4aMh
AY+iURiU/Vf/B6EE4kjfs5YLAAAAAElFTkSuQmCC
name="linkedin.png"
Content-ID: <part3.05050606.00070209@esc-net.de>
filename="linkedin.png"
CXBIWXMAAABIAAAASABGyWs+AAAACXZwQWcAAAAQAAAAEABcxq3DAAACGklE QVQ4y6WTO2sU
URTHf3dmdp0kTnZJzErSrPjKYqNY2GljodhoLRLB1sLCD2DrZxAsfCAE/AaC grY+SBQSFTSC
xizGzZ3MTiYz92UxY5KNYuOBP+eew/3/73lwxfWHT9yjuR8YL0CwyxygAAPo Cqr0ntFcvjBB
cH++x8WzJzm8v/EnWVdks0PEgNWO95/XePD4HZ4ADk6MAhD6Hs26/08yBjwr ODrZBK0JADyv
LP7GsX2Evse9xR5Lsvgr+XfsO7ctoKwj9AWh7wEQIFCF+3sFGjCmgiJwQFwY Yge3X3cZrwXM
r2SDg9tJ1rokaw1alRXI3NAO61w60AAHTkE7qtNu1PjSUywsb3L60AgjNcHz hZgXb39WApoA
C3FqsIGjMxYC8OZbxlQU0GmFTLdCznWireV0pobYSDKevuzilMZDg0wN/cxu XdrMLVqX53TT
cu3OJ87cmmdlrQBgemoYKTMwqhSI+4Z0QMBhjANgcTnj1UdJHGd8Xc0AmBit Ecu0moGGODH0
h7cF8tyidSmgjSWWG6AUWpkypw1xLwXA4z8tQINcN/T3moEWtLZbr0mZQV5s 55RFJuU8RHR1
1iWtIzQ8nxOtIVCw9D2lWbM06w4ZZ8wtrEJRcLw9TDMUyKRg7kOPSHQR0ZVZ lyRjMDkOOVAU
FfLS57viHRaJLsHM+THuPtuDUgLTW2U0X672t47rrw82vOu/z9w8xS+MkDzV Boy6+QAAAABJ
RU5ErkJggg==
name="xing.png"
Content-ID: <part4.01000607.04070200@esc-net.de>
filename="xing.png"
iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAIAAACQkWg2AAAACXBIWXMAAAsT AAALEwEAmpwY
AAABsklEQVR42mP8//8/AymAEb+G1x9333hU9fffZy52ZTONrQQ0/P7z7sLd hJfvN7Mw80mL
ROkqTodqAIKvv379+fuXhZmZh50dpv7f49dLLt1LYWD4ryRZCETsrJIIDYdu 3y5fu16AizPE
0CTFzgoo8fPXoxPX/T9/v8DHbWCito6LXRHFDw/evnXpm3D39Ws1Eck9xVmy wqLP3/SevlXC
ysKtLtuoJFmMxdObL17ymzqN8S9LnZddua/VrUcWD149FRNwNFFby8oiiEXD itNnImfN5WTi
nBhu7Gvw5OLdiv+MQnqKU6WEI7AE6+vPnx17+68+fmGrJL0wRe/rl/jbL94r isfqKs1kZuJE
1/Dt16/27TtatmzjYeZcnuZpqnDi3J16FmZxYDhKCAViibiVp8+Ur1v39N0H X12DFRkJ33/u
O3LVk+E/i5xYqq7iNCwaXn769PLTZ0ZGBnFePjE+3j9/3155kPvk9XIudgV9 5XnCfI6Ek8a7
T4dO3vD4+++HlHC4kepywhr+/P0ITEIPXk5jZxXTVpgE1EY48X36euHs7fBv P+8CVespzYGH
FSOpyRsAAuDh4a3m5z0AAAAASUVORK5CYII=
--------------030900060908090006010205--
--------------020800070103020207090204--
| Re: how to use CDO dynamic ....? [message #545616 is a reply to message #518434] |
Thu, 08 July 2010 08:42   |
Hi Eike
Thank you for your answer.
I was using a CDO 3.0 version which contains more recent version of CDO plugin than http://download.eclipse.org/modeling/emf/cdo/updates/3.0-releases/. So I did not install it.
I have downloaded the lastest CDO version from https:// build.eclipse.org/hudson/job/emf-cdo-integration/lastSuccess fulBuild/artifact/result/site.p2/ (#625) I still have the same problem.
For the legacy problem, I added CDOUtil.setLegacyModeDefault(true); before CDOServerUtil.addRepository(container, cdoRepository); just in case. But it did not change anything.
| Quote: |
I don't create a model and I don't register any package before the error occurs. But the LifecycleUtil.activate(cdoRepository) function registers Ecore package and Eresource package.
main [org.eclipse.emf.cdo.internal.common.model.CDOPackageRegistryImpl] Registering http://www.eclipse.org/emf/2002/Ecore --> org.eclipse.emf.ecore.impl.EcorePackageImpl@60029d (name: ecore) (nsURI: http://www.eclipse.org/emf/2002/Ecore, nsPrefix: ecore)
main [org.eclipse.emf.cdo.internal.common.model.CDOPackageRegistryImpl] Registering http://www.eclipse.org/emf/CDO/Eresource/2.0.0 --> org.eclipse.emf.cdo.eresource.impl.EresourcePackageImpl@157bf4c (name: eresource) (nsURI: http://www.eclipse.org/emf/CDO/Eresource/2.0.0, nsPrefix: eresource)
Maybe the function LifecycleUtil.activate(cdoRepository) create a resource with EModelElement and a wrong legacy. Is it possible to avoid that or change the Ecore package legacy ?
If the problem has been solved before, I may have a problem with my plugin version. Can you give me a configuration with which the CDO_Embedded example worked ?
A new problem occurs after installing https://build.eclipse.org/hudson/job/emf-cdo-integration/las tSuccessfulBuild/artifact/result/site.p2/ (#625) :
when I run a CDO server (org.eclipse.emf.cdo.server.product), it seems to start correctly but I cannot open a session neither with my program nor with the CDO session view. A timeout Exception occurs. I did not modify the cdo-server.xml file, it was working well before the update .
Suzanne
| Re: how to use CDO dynamic ....? [message #546035 is a reply to message #545616] |
Sat, 10 July 2010 02:21  |
--------------040808080508050705010605
Am 08.07.2010 14:42, schrieb Suzanne:
> Hi Eike
> I was using a CDO 3.0 version which contains more recent version of CDO plugin than http://download.eclipse.org/modeling/emf/cdo/updates/3.0-rel eases/ So I did not install it.
> I have downloaded the lastest CDO version from https://build.eclipse.org/hudson/job/emf-cdo-integration/las tSuccessfulBuild/artifact/result/site.p2/ (#625) I still have the same problem.
Because you removed the previous questions and answers and did not respond to the former posts directly it's hard for me to remember what your problem was ;-(
You better remove that, unless you really really want to use legacy models.
> Quote:
> main [org.eclipse.emf.cdo.internal.common.model.CDOPackageRegistr yImpl] Registering http://www.eclipse.org/emf/2002/Ecore --> org.eclipse.emf.ecore.impl.EcorePackageImpl@60029d (name: ecore) (nsURI: http://www.eclipse.org/emf/2002/Ecore, nsPrefix: ecore)
> main [org.eclipse.emf.cdo.internal.common.model.CDOPackageRegistr yImpl] Registering http://www.eclipse.org/emf/CDO/Eresource/2.0.0 --> org.eclipse.emf.cdo.eresource.impl.EresourcePackageImpl@157bf4c (name: eresource) (nsURI: http://www.eclipse.org/emf/CDO/Eresource/2.0.0, nsPrefix: eresource)
No resources are created during activation of a repository.
Can you post a zip with a reproducible example?
Do you have a stack trace of the timeout exception? Usually the reason can be found there.
<html>
<head>
</head>
<blockquote cite="mid:i14h39$7so$1@build.eclipse.org" type="cite">Hi
Eike
<br>
<br>
<br>
of CDO plugin than
<a class="moz-txt-link-freetext" href=" http://download.eclipse.org/modeling/emf/cdo/updates/3.0-rel eases/"> http://download.eclipse.org/modeling/emf/cdo/updates/3.0-rel eases/</a>.
So I did not install it. <br>
<a class="moz-txt-link-freetext" href=" https://build.eclipse.org/hudson/job/emf-cdo-integration/las tSuccessfulBuild/artifact/result/site.p2/"> https://build.eclipse.org/hudson/job/emf-cdo-integration/las tSuccessfulBuild/artifact/result/site.p2/</a>
(#625) I still have the same problem. <br>
</blockquote>
what your problem was ;-(<br>
<br>
<blockquote cite="mid:i14h39$7so$1@build.eclipse.org" type="cite">For
<br>
</blockquote>
models.<br>
<br>
<br>
<br>
<blockquote type="cite">Does your instance model (one of your
EClasses?
<br>
<br>
<a class="moz-txt-link-freetext" href=" http://www.eclipse.org/cdo/documentation/relnotes_30/relnote"> http://www.eclipse.org/cdo/documentation/relnotes_30/relnote</a>
<br>
<br>
case.
<br>
</blockquote>
<br>
<br>
<br>
<br>
main
<br>
main
eresource)
<br>
<br>
<br>
<br>
</blockquote>
No resources are created during activation of a repository.<br>
<br>
<br>
<br>
</blockquote>
Can you post a zip with a reproducible example?<br>
<br>
<br>
(#625) :
<br>
<br>
</blockquote>
reason can be found there.<br>
<br>
</body>
</html>
--------------040808080508050705010605--
Current Time: Thu Nov 20 04:46:53 EST 2025
Powered by FUDForum. Page generated in 0.13053 seconds
