Home » Modeling » Epsilon » Problem reproducing EOL Tool Simmetrics Example
Problem reproducing EOL Tool Simmetrics Example [message #519148] Sun, 07 March 2010 06:36 Go to next message
I'm stuck trying to reproduce the Simmetrics Tool example. I'm exporting the tool as a plugin, place in the dropins folder and can see it in the Epsilon perspective in the tools tab. No problem there. However, when trying to use the similarity function, I keep getting a class not found exception: java.lang.ClassNotFoundException: uk.ac.shef.wit.simmetrics.similaritymetrics.JaroWinkler
I'm really no expert creating Eclipse plugins. So I have been putting the library in the plugin's build path and added it to the bundle-class path ... with little success.
What am I overlooking? How should the Manifest for the example look like?
Thanks a lot for your help!
Anne
Re: Problem reproducing EOL Tool Simmetrics Example [message #519176 is a reply to message #519148] Sun, 07 March 2010 09:30 Go to previous messageGo to next message
Hi Anne,
The Simmetrics example is out of date (had to remove simmetrics.jar due
to licensing issues). For an up-to-date example of calling Java from
Epsilon please have a look at
http://eclipse.org/gmt/epsilon/doc/articles/call-java-from-e psilon/
Please let me know if you specifically need the Simmetrics example and
I'll try to restore it under epsilonlabs.sf.net .
Dimitris
Anne Keller wrote:
> Anne
Spread the word: http://www.eclipse.org/gmt/epsilon/spreadtheword
Follow Epsilon on Twitter: http://twitter.com/epsilonews
Re: Problem reproducing EOL Tool Simmetrics Example [message #519184 is a reply to message #519176] Sun, 07 March 2010 15:47 Go to previous messageGo to next message
Hi Dimitris,
thank you for the quick reply and the article. I had checked the article before and don't think that this is where the problem lies. The tool works fine for functions not accessing the simmetrics library. So I guess my problem is somehow with exporting the simmetrics jar...
Thanks again,
Anne
Re: Problem reproducing EOL Tool Simmetrics Example [message #519190 is a reply to message #519184] Sun, 07 March 2010 16:31 Go to previous messageGo to next message
Hi Anne,
To make simmetrics.jar visible to your tool, you need to create a plugin
from it using the New->Plug-in from Existing JAR Archives wizard and
then add the created simmetrics plugin to the dependencies of the plugin
where you define the tool.
Dimitris
Anne wrote:
> Hi Dimitris,
> Thanks again,
> Anne
Re: Problem reproducing EOL Tool Simmetrics Example [message #519246 is a reply to message #519190] Mon, 08 March 2010 04:32 Go to previous messageGo to next message
Hi Dimitris,
thank you, that works!
Anne
Re: Problem reproducing EOL Tool Simmetrics Example [message #587147 is a reply to message #519190] Mon, 08 March 2010 04:32 Go to previous message
Hi Dimitris,
Anne
Previous Topic:Problem reproducing EOL Tool Simmetrics Example
Next Topic:[EuGENia] Reorder nodes in ECore2GMF.eol
Current Time: Sun Jul 27 15:29:38 EDT 2025
Powered by FUDForum. Page generated in 0.13306 seconds
