Home » Eclipse Projects » Web Tools incubator » On-going nightmare -> ClassNotFoundException: org.apache.cxf.transport.servlet.CXFServlet
On-going nightmare -> ClassNotFoundException: org.apache.cxf.transport.servlet.CXFServlet [message #519039] Fri, 05 March 2010 14:42 Go to next message
Really unnerving!
I'm able to develop for a while without issue and suddenly (like after a machine reboot) my project starts throwing a ClassNotFoundException. Nothing I do short of starting the project from scratch fixes it.
I'm using: Galieo, JDK1.6.0, Tomcat 6.0.24, CXF-2.2.6 with the WTP
My JRE has a VM arg I read about somewhere as well:
-Xbootclasspath/p:C:\apache\cxf\apache-cxf-2.2.6\lib\jaxb-ap i-2.1.jar;C:\apache\cxf\apache-cxf-2.2.6\lib\jaxb-impl-2.1.1 2.jar;C:\apache\cxf\apache-cxf-2.2.6\lib\jaxb-xjc-2.1.12.jar
I tried deploying my application to the tomcat webapp directory and didn't have any luck there either (lots of class loader/boot class loader exceptions).
Can someone tell me how a CXF application classpath is built so I can troubleshoot this?
Re: On-going nightmare -> ClassNotFoundException: org.apache.cxf.transport.servlet.CXFServlet [message #519048 is a reply to message #519039] Fri, 05 March 2010 15:53 Go to previous messageGo to next message
I've done something horribly here. Just not sure what it is.
I have "Export runtime libraries to WEB-INF/lib at deployment time" checked. Which jars are supposed to be copied and to where? Is there a way to confirm this is happening?
Re: On-going nightmare -> ClassNotFoundException: org.apache.cxf.transport.servlet.CXFServlet [message #519054 is a reply to message #519048] Fri, 05 March 2010 17:26 Go to previous messageGo to next message
Working now in Tomcat (free-standing from a WAR) and in Galileo!
I needed to copy a number of jars to WEB-INF/lib. Here is the list that's working for me (note that I'm on cxf-2.2.6):
commons-collections-3.1.jar
commons-logging-1.1.1.jar
cxf-2.2.6.jar
geronimo-jaxws_2.1_spec-1.0.jar
jaxb-api-2.1.jar
neethi-2.0.4.jar
slf4j-api-1.5.8.jar
slf4j-jdk14-1.5.8.jar
spring-beans-2.5.6.jar
spring-context-2.5.6.jar
spring-core-2.5.6.jar
wsdl4j-1.6.2.jar
XmlSchema-1.4.5.jar
Here is my WebContent directory structure:
|-WEB-INF
|---classes
|---lib
|---web.xml
|---cxf-servlet.xml
|-wsdl
|---boardcallink.wsdl
|---boardcallink.xjb
|---boardcallink_schema1.xsd
To generate and use a war (for those to which it's not obvious):
cd <path to WebContent dir>
tar -cf MyWebService.war *
cp MyWebService.war $CATALINA_HOME/webapps
cd $CATALINA_HOME/bin
./startup.sh
Test from a browser:
http://localhost:8080/MyWebService/services
Re: On-going nightmare -> ClassNotFoundException: org.apache.cxf.transport.servlet.CXFServlet [message #519104 is a reply to message #519048] Sat, 06 March 2010 10:08 Go to previous messageGo to next message
Hi Kurt,
I've tested this with Eclipse 3.5.1, JDK 1.6.0, Tomcat 6.0.24 and CXF 2.2.6 with the VM arg, deploying to tomcat and rebooting but have been unable to reproduce.
Kurt wrote on Fri, 05 March 2010 15:53
All the jars from the CXF lib directory should be resolved to the WEB-INF/lib directory at deployment time. Try exporting the project as a WAR by selecting File > Export > Web > WAR file to confirm that is happening.
Is there anything of note in the Error log view when this happens?
Re: On-going nightmare -> ClassNotFoundException: org.apache.cxf.transport.servlet.CXFServlet [message #519117 is a reply to message #519104] Sat, 06 March 2010 12:52 Go to previous messageGo to next message
Nothing found in .log that is relevant.
All of the jars from cxf-2.2.6/lib are being copied when I export a WAR. I couldn't get this to work and the export action has the same problem I did when I tried it manually. The JAXB jar in the JDK causes unhappiness:
Caused by: java.lang.LinkageError: JAXB 2.0 API is being loaded from the bootstrap classloader, but this RI (from jar:file:/C:/apache/apache-tomcat-6.0.14/webapps/BoardCalLin k/WEB-INF/lib/jaxb-impl-2.1.12.jar!/com/sun/xml/bind/v2/mode l/impl/ModelBuilder.class) needs 2.1 API. Use the endorsed directory mechanism to place jaxb-api.jar in the bootstrap classloader. (See http://java.sun.com/j2se/1.5.0/docs/guide/standards/)
This doesn't explain, however, why I'm unable to run tomcat from within Eclipse without copying the jars (or at least why it only works some of the time). How does one go about troubleshooting that? Is that a JAXB 2.0 jar problem as well?
Did I say "thanks Shane" for all of the hand-holding?
Re: On-going nightmare -> ClassNotFoundException: org.apache.cxf.transport.servlet.CXFServlet [message #519126 is a reply to message #519117] Sat, 06 March 2010 15:59 Go to previous messageGo to next message
Hi Kurt,
Being unable to run tomcat from within Eclipse without copying the jars doesn't sound like a JAXB 2.0 problem.
Could you tell me the full version number of the 1.6 JDK you're running and the version of WTP you've got installed?
Also do you know which JAX-WS Tools milestone you're running as well?
This wiki page may help you narrow it down:
http://wiki.eclipse.org/JAXWS/MilestonePlan
Re: On-going nightmare -> ClassNotFoundException: org.apache.cxf.transport.servlet.CXFServlet [message #519128 is a reply to message #519126] Sat, 06 March 2010 16:34 Go to previous messageGo to next message
An acute understanding of the Eclipse version naming strategy escapes me, but here are my best guesses at the version numbers:
Java v1.6.0-b105
JAX-WS Tools Core v0.5.2, Build id: 20090911111021
Web Developer Tools v3.1.1, Build id: 20100211202452
Re: On-going nightmare -> ClassNotFoundException: org.apache.cxf.transport.servlet.CXFServlet [message #519132 is a reply to message #519128] Sat, 06 March 2010 17:56 Go to previous messageGo to next message
OK, the first thing i'd do is upgrade the 1.6 JDK to the latest update.
There are JAXB problems running CXF with pre 1.6.0_04 versions of the JDK.
I should have asked that question earlier.
Re: On-going nightmare -> ClassNotFoundException: org.apache.cxf.transport.servlet.CXFServlet [message #519178 is a reply to message #519132] Sun, 07 March 2010 14:31 Go to previous messageGo to next message
Shane,
I upgraded to JDK1.6.0_18-b07 and am having the same problem. Starting the web service within Galileo only works consistently when I copy the jars I mentioned earlier to WEB-INF/lib.
Re: On-going nightmare -> ClassNotFoundException: org.apache.cxf.transport.servlet.CXFServlet [message #519193 is a reply to message #519178] Sun, 07 March 2010 17:28 Go to previous messageGo to next message
You could try installing the latest version of JAX-WS Tools.
The build you are using is quite old. There may have been something in the earlier builds that was causing this that went undetected.
The latest milestone is due at the end of this week and will be available on the
http://download.eclipse.org/webtools/milestones/ update site. I can update this thread when it's available.
If you'd like to try the latest code now i can point you to an integration build download. You can install this by unzipping into your Eclipse dropins folder.
Re: On-going nightmare -> ClassNotFoundException: org.apache.cxf.transport.servlet.CXFServlet [message #521852 is a reply to message #519193] Thu, 18 March 2010 18:22 Go to previous messageGo to next message
Latest milestone now available on http://download.eclipse.org/webtools/milestones/ (It was a few days late).
There's currently a bug in the way the JAX-WS Tools features are listed on the update site.
Deselect the 'Group items by category' check box and select the following features to install:
CXF Web Services SDK
JAX-WS DOM Tools SDK
JAX-WS Tools SDK
Re: On-going nightmare -> ClassNotFoundException: org.apache.cxf.transport.servlet.CXFServlet [message #522820 is a reply to message #519039] Tue, 23 March 2010 22:01 Go to previous message
Loaded the latest!
I'm trying to sort out a problem opening the Dynamic Web Project wizard:
The selected wizard could not be started.
Plug-in "org.eclipse.jst.servlet.ui" was unable to instantiate class "org.eclipse.jst.servlet.ui.project.facet.WebProjectWizard".
I'll keep at it.
Previous Topic:JPA Diagram Editor contribution proposal
Next Topic:On-going nightmare -> ClassNotFoundException: org.apache.cxf.transport.servlet.CXFServlet
Current Time: Sun Jul 27 07:53:11 EDT 2025
Powered by FUDForum. Page generated in 0.08230 seconds
