Headless SVN not working with 3.6? [message #519008] |
Fri, 05 March 2010 11:43  |
I tried both subversive and subclipse but without success.
When I try it with subversive I get
ERROR [0001] : org.eclipse.team.svn.core.operation.UnreportableException: Selected SVN connector library is not available or cannot be loaded.
If you selected native JavaHL connector, please check if binaries are available or install and select pure Java Subversion connector from the plug-in connectors update site.
If connectors already installed then you can change the selected one at: Window->Preferences->Team->SVN->SVN Connector.
INFO: TAG-ID 0001 = Query for ch.ethz.origo.aranea.messagedsl.feature:eclipse.feature
if I try subclipse I get
ERROR [0001] : No suitable provider for component ch.ethz.origo.aranea.messagedsl.feature:eclipse.feature was found in resourceMap file:/home/build/tmp/ch.ethz.origo.aranea.messagedsl.build/aranea.rmap
ERROR [0001] : No suitable provider for component ch.ethz.origo.aranea.messagedsl.feature:eclipse.feature was found in searchPath aranea
ERROR [0001] : Rejecting provider svn(https://svn.origo.ethz.ch/aranea/trunk/dev/{0}): No component match was found
ERROR Unable to load default SVN Client
Running the same mspec from within eclipse works fine and fetches the projects from SVN.
Re: Headless SVN not working with 3.6? [message #519080 is a reply to message #519042] |
Sat, 06 March 2010 03:28   |
There is a problem with subversive but everything seems OK with subclipse. I have tested it on both Linux and Windows
(64 and 32 bit) and everything seems to work OK. Are you starting with a clean installation or updating an existing one?
Perhaps installing subclipse on top of subversive?
- thomas
On 03/05/2010 09:15 PM, Thomas Hallgren wrote:
> Darn, I must have done something wrong when I published the new external
> site today. I'll have a look at it tomorrow.
> Thanks for reporting so rapidly and I'm sorry for the inconvenience.
> - thomas
> On 03/05/2010 07:30 PM, Carsten Reckord wrote:
>> Hi Thomas, hi Patrick,
>> I have the same problem with subversive when using
>> http://download.eclipse.org/tools/buckminster/headless-3.6
>> http://download.cloudsmith.com/buckminster/external-3.6
>> A workaround is to follow the procedure from
>> https://bugs.eclipse.org/bugs/show_bug.cgi?id=295696 and install the SVN
>> connectors directly from polarion for the moment.
>> Carsten
>> On 05.03.2010 18:35, Thomas Hallgren wrote:
>>> Hi Patrick,
>>> What sites are you using for provisioning the headless Buckminster?
>>> - thomas
>>>> ERROR [0001] :
>>>> at:
>>>> resourceMap
>>>> file:/home/build/tmp/ch.ethz.origo.aranea.messagedsl.build/a ranea.rmap
>>>> searchPath aranea
>>>> was found
>>>> projects from SVN.
FUDForum. Page generated in 0.08500 seconds
