| Home » Archived » M2M (model-to-model transformation) » [ATL] Increase transformation performance
 Goto Forum:|
| [ATL] Increase transformation performance [message #50933] | Fri, 06 July 2007 05:36  |  |
| Eclipse User  |  |  |  |  | Originally posted by: erik_becker.gmx.de
 Hi all,
 I'm working on a transformation of a business process model to another.
 The models to transform could get quite big, so I'm looking for some
 ways to increase the performance of my transformation.
 In the manual i read, that attributes are computed once only. Does this
 mean if I call an attribute-helper in the context of a source model
 element the result is computed at the first time I call this attribute?
 As the source models element could not be change the result of the
 helper (regardless if attribute or not) should always be the same.
 If this is right, I would use attributes to implement 'statement' about
 source model elements (e. g. 'isActivity', 'hasSuccessor') to increase
 performance. Please, correct me if I'm wrong.
 Are there any other 'tricks' to get a better performance?
 Thanks and Greets
 Erik
| Re: [ATL] Increase transformation performance [message #50989 is a reply to message #50933] | Fri, 06 July 2007 07:21   |  |
| Eclipse User  |  |  |  |  | Hi Erik,
 You are right ;-).
 Yes, there are some tricks, but they depend on your transformation
 scenario. It is difficult for me to tell you more without knowing about it.
 Frédéric Jouault
| Re: [ATL] Increase transformation performance [message #51807 is a reply to message #51664] | Tue, 10 July 2007 08:37   |  |
| Eclipse User  |  |  |  |  | Hi Eric,
 Yes, using attribute helpers instead of operation helpers can
 significantly improve performance because their results are cached.
 However, this depends on whether you access several times the same
 feature of a given element or not.
 Avoiding allInstances() is definitely a good thing.
 Using rule inheritance may also help because this reduces the number of
 calls to allInstances() generated by the compiler.
 Note that doing a semantic transformation at the XML level typically
 reduces performance because you cannot rely on types for matching, but
 usually match XML!Element with a guard.
 Frédéric Jouault
 Erik Becker wrote:
 > Hello Frédéric,
 > What do you need to know? I'm doing a XML to XML transformation of a
 > workflow model with ATL and have often to use statement to check if a
 > element (representing activities, events, participants etc.) fulfill a
 > characteristic or not (e. g.)
 > At the moment I use helper (not attributes) to implement these
 > statement. Would it be better (and still work) if I use attributes
 > instead helpers?
 > I tried to avoid 'allInstances()' calls are there any other functions /
 > operation or rules which should be used carefully with respect to
 > peformance issues?
 > Greets
 > Erik
 > Frédéric Jouault schrieb:
 >> Hi Erik,
 >> about it.
 >> Best regards,
 >> Frédéric Jouault
| Re: [ATL] Increase transformation performance [message #51908 is a reply to message #51807] | Tue, 10 July 2007 11:20   |  |
 Hi Frédéric,
 I have to call some of the helpers several times on the same element
 (context), so I think it will increase performance if its cached.
 Are the results cached for each model element (context)?
 Thanks for your advice concerning using ATL for XML transformation. T
 totally agree, that using another meta model to transform my models
 would be a better way, but with respect time and effort I've to do it
 this 'dirty' way. I saves me to write 2 meta model (source and target)
 and 2 transformations (xml -> source and target -> xml).
 Erik
 > Regards,
 > Frédéric Jouault
 > Erik Becker wrote:
 >> Hello Frédéric,
 >> instead helpers?
 >> / operation or rules which should be used carefully with respect to
 >> peformance issues?
 >> Greets
 >> Erik
 >>> Hi Erik,
 >>> about it.
 >>> Best regards,
 >>> Frédéric Jouault
| Re: [ATL] Increase transformation performance [message #52120 is a reply to message #52014] | Wed, 11 July 2007 11:25  |  |
 target)
 >> Personally, I would write the 2 metamodels even if I had no
 >> performance issue ;-).
 > Be sure I will do it next time, but now there's no time for this. ;-)
 > My performence did dramatically increase as I made some helpers from
 > operations to attributes (features). In my case It reduced the runtime
 > to about 30% of the time before the change.
 That is definitely nice :-).
 > Unfortunately I've now to change my module structure because the helpers
 > now have to be in the module and not in the libraries.
 > Is it possible to put rules from the (main) module in the libraries?
 > My main module is quite complex and I would like to separate the rules
 > and helper concerning their purpose to reduce the complexity.
 You should be able to use attribute helpers in libraries, provided you
 compile them with the ATL 2006 compiler (i.e., not with the ATL 2004
 compiler), and you use a recent version of the VM.
 > In your last posting You wrote something about rule inheritance. Where
 > can I find info on that?
 There is some information about rule inheritance on the wiki:
 http://wiki.eclipse.org/ATL_Language_Troubleshooter#Rule_inh eritance
 feel free to improve it if necessary ;-).
 Frédéric Jouault
 Current Time: Thu Oct 30 21:53:40 EDT 2025
 Powered by FUDForum . Page generated in 0.24467 seconds |
