Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » XText: cant find main class org.eclipse.emf.mwe.core.WorkflowRunner(referenced libraries )
XText: cant find main class org.eclipse.emf.mwe.core.WorkflowRunner [message #518866] |
Fri, 05 March 2010 05:41  |
I'm trying to get the example of the XText "tutorial" (getting started) running, but there seem to be problems with the referenced libraries (why arent they included by the wizard??):
When I start the mwe file by "Run as MWE Workflow" I get the above error:
"cant find main class org.eclipse.emf.mwe.core.WorkflowRunner"
I already reference library
org.eclipse.emf.mwe.core_0.7.2.v200908120417.jar
which includes the WorkflowRunner.
So why is it not found?
Can anybody give me a hint?
HansBjörn.
PS: Forget about it!
The error message was very misleading. In fact many other libs are missing, I wonder why the wizard has not added any one of them...
[Updated on: Fri, 05 March 2010 08:20] by Moderator
Re: XText: cant find main class org.eclipse.emf.mwe.core.WorkflowRunner [message #518974 is a reply to message #518925] |
Fri, 05 March 2010 10:27   |
Hi Sebastian,
I downloaded eclipse-SDK-3.5.1-xtext-0.7.2-win32.zip
from itemis and unzipped it under
C:\Programme\eclipse
This does not seem to be very deep...
The installation was just to extract the files from the zip, so what errors could I get from any log?
Now that I added a 24 (!) libraries one after the manually I do not get any syntax errors.
By invoking the Workflowrunner the logs says this:
0 INFO WorkflowRunner - ------------------------------------------------------------ --------------------------
16 INFO WorkflowRunner - EMF Modeling Workflow Engine 0.7.2, Build v200908120417
16 INFO WorkflowRunner - (c) 2005-2009 openarchitectureware.org and contributors
16 INFO WorkflowRunner - ------------------------------------------------------------ --------------------------
16 INFO WorkflowRunner - running workflow: C:/Dokumente und Einstellungen/profi/workspace/org.xtext.example.start/src/or g/xtext/example/GenerateEntities.mwe
391 INFO StandaloneSetup - Registering platform uri 'C:\Dokumente und Einstellungen\profi\workspace'
1578 INFO CompositeComponent - DirectoryCleaner: cleaning directory '../org.xtext.example.start/src-gen'
1578 INFO DirectoryCleaner - Cleaning C:\Dokumente und Einstellungen\profi\workspace\org.xtext.example.start\..\org .xtext.example.start\src-gen
1578 INFO CompositeComponent - DirectoryCleaner: cleaning directory '../org.xtext.example.start.ui/src-gen'
1578 INFO DirectoryCleaner - Cleaning C:\Dokumente und Einstellungen\profi\workspace\org.xtext.example.start\..\org .xtext.example.start.ui\src-gen
1578 INFO CompositeComponent - Generator
1641 INFO LanguageConfig - generating infrastructure for org.xtext.example.Entities with fragments : ImplicitRuntimeFragment, ImplicitUiFragment, GrammarAccessFragment, EcoreGeneratorFragment, ParseTreeConstructorFragment, ResourceFactoryFragment, AntlrDelegatingFragment, JavaValidatorFragment, JavaScopingFragment, FormatterFragment, LabelProviderFragment, TransformerFragment, OutlineNodeAdapterFactoryFragment, JavaBasedContentAssistFragment, DelegatingGeneratorFragment
4000 INFO JavaValidatorFragment - executing generate for org.eclipse.xtext.generator.validation.JavaValidatorFragment
4438 ERROR Generator - Unable to load extension file : org::eclipse::xtend::util::stdlib::io
EvaluationException : Unable to load extension file : org::eclipse::xtend::util::stdlib::io
org::eclipse::xtext::generator::ModuleExtensions.ext[128,26] on line 5 'simpleMethodName(key.type)'
org::eclipse::xtext::generator::GuiceModuleRt.xpt[2085,20] on line 71 'bindMethodName(this)'
org::eclipse::xtext::generator::GuiceModuleRt.xpt[1414,37] on line 45 'EXPAND bindingMethod FOREACH bindings'
at org.eclipse.internal.xtend.expression.ast.Expression.evaluat e(Expression.java:56)
at org.eclipse.internal.xtend.expression.ast.OperationCall.eval uateInternal(OperationCall.java:66)
at org.eclipse.internal.xtend.expression.ast.Expression.evaluat e(Expression.java:48)
at org.eclipse.internal.xtend.expression.ast.OperationCall.eval uateInternal(OperationCall.java:60)
at org.eclipse.internal.xtend.xtend.ast.ExpressionExtensionStat ement.evaluateInternal2(ExpressionExtensionStatement.java:58 )
at org.eclipse.internal.xtend.xtend.ast.ExpressionExtensionStat ement.evaluateInternal(ExpressionExtensionStatement.java:47)
at org.eclipse.internal.xtend.xtend.ast.AbstractExtension.evalu ate(AbstractExtension.java:162)
at org.eclipse.internal.xtend.expression.ast.OperationCall.eval uate(OperationCall.java:343)
at org.eclipse.internal.xtend.expression.ast.OperationCall.eval uateInternal(OperationCall.java:76)
at org.eclipse.internal.xpand2.ast.ExpressionStatement.evaluate Internal(ExpressionStatement.java:45)
at org.eclipse.internal.xpand2.ast.Statement.evaluate(Statement .java:39)
at org.eclipse.internal.xpand2.ast.AbstractDefinition.evaluate( AbstractDefinition.java:175)
at org.eclipse.internal.xpand2.ast.ExpandStatement.invokeDefini tion(ExpandStatement.java:195)
at org.eclipse.internal.xpand2.ast.ExpandStatement.evaluateInte rnal(ExpandStatement.java:145)
at org.eclipse.internal.xpand2.ast.FileStatement.evaluateIntern al(FileStatement.java:83)
at org.eclipse.xpand2.XpandFacade.evaluate2(XpandFacade.java:71 )
at org.eclipse.xpand2.XpandFacade.evaluate(XpandFacade.java:45)
at org.eclipse.xtext.generator.Generator.generateGuiceModuleRt( Generator.java:248)
at org.eclipse.xtext.generator.Generator.invokeInternal(Generat or.java:82)
at org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent.invok e(AbstractWorkflowComponent.java:124)
at org.eclipse.emf.mwe.core.container.CompositeComponent.intern alInvoke(CompositeComponent.java:101)
at org.eclipse.emf.mwe.core.container.CompositeComponent.invoke (CompositeComponent.java:86)
at org.eclipse.emf.mwe.core.WorkflowRunner.executeWorkflow(Work flowRunner.java:412)
at org.eclipse.emf.mwe.core.WorkflowRunner.run(WorkflowRunner.j ava:292)
at org.eclipse.emf.mwe.core.WorkflowRunner.main(WorkflowRunner. java:239)
4438 INFO WorkflowRunner - workflow completed in 2860ms!
Now I really dont know how to get an yfurther...
regards, HB.
Re: XText: cant find main class org.eclipse.emf.mwe.core.WorkflowRunner [message #519005 is a reply to message #518975] |
Fri, 05 March 2010 06:40   |
Am 05.03.10 16:31, schrieb HansBj:
> I just tried again to create a XText Project using the wizard.
> It does not include any libraries at all!
> The first error I get is that the reference in the grammar file to
> org.eclipse.xtext.common.Terminals
> cannot be solved.
> regards, HB.
Hi Hans Björn,
I just removed the dust from an old windows box, downloaded the Xtext
distro and launched Eclipse and created an empty workspace in c:/eclipse/ws.
After choosing
New -> Project .. -> Xtext Project
I end up with 3 projects in my workspace. They define the required deps,
e.g. the runtime project (org.xtext.example.mydsl by default) contains a
manifest.mf with the following entries:
Require-Bundle: org.eclipse.xtext,
org.eclipse.xtext.generator;resolution:=optional,
de.itemis.xtext.antlr;resolution:=optional,
org.apache.commons.logging;resolution:=optional,
org.eclipse.emf.codegen.ecore;resolution:=optional,
org.eclipse.xtext.log4j;resolution:=optional,
org.eclipse.emf.mwe.utils;resolution:=optional,
org.eclipse.emf.mwe.core;resolution:=optional,
com.ibm.icu;resolution:=optional,
org.eclipse.xtext.xtend;resolution:=optional
Can you confirm this behaviour on your machine?
Sebastian
Re: XText: cant find main class org.eclipse.emf.mwe.core.WorkflowRunner [message #622275 is a reply to message #518925] |
Hi Sebastian,
regards, HB.
Re: XText: cant find main class org.eclipse.emf.mwe.core.WorkflowRunner [message #1602189 is a reply to message #721879] |
Thu, 05 February 2015 06:25  |
I have to confirm that same issue. It occurs at me when I try to create project in existing workspace. Workspace already contains 10 other java projects but I'm not sure whether java projects are related to given issue.
Imports within xtext project are throwing such errors as:
Bundle 'org.eclipse.xtext' cannot be resolved. in MANIFEST.MF.
Couldn't resolve reference to Grammar 'org.eclipse.xtext.common.Terminals'. in MyDsl.xtext
etc.
When I create fresh new workspace then everything is fine.
I'm on linux platform, and I'm pretty sure that it's not max path problem. Projects are located inside following worspaces
/development/workspace/test/ <- fresh new workspace
/development/workspace/my/ <- existing workspace
Current Time: Tue Jul 22 22:11:15 EDT 2025
Powered by FUDForum. Page generated in 0.05891 seconds
