browser.setUrl freeze [message #518368] |
Wed, 03 March 2010 16:59  |
I have swt.browser with xulrunner (swt-3.6M5-gtk-linux-x86_64, xulrunner-sdk-1.9.1.3-linux-x86_64 - my own build). I render the page and get all links from the page as String[]. Now I want to render all pages the links refer to. So I made my own ProgressListener which takes link one by one and calls browser.setUrl() in its completed method. The trouble is that the rendering freezes. The ProgressListener is not noticed again until I move with the cursor or invoke any other system event. What am I doing wrong? I am not sure if its swt-xulrunner or OS problem? I am using Ubuntu 9.10 x86_64.
Most important part of my code is attached.
Thanks a lot for any help.
My code:
public class Test {
//swt
private Shell shell;
private Display display;
private Label status;
private Browser browser;
private ExtractLocationListener extractLocListener;
private RebuildLocationListener rebuildLocListener;
private AdvancedStatusTextListener statusListener;
private Text url;
private Button backButton;
private Button refreshButton;
private Button forwardButton;
private Button stopButton;
private Button goButton;
private Button extractButton;
private Button rebuildButton;
private Label tabInfo;
private Label statusInfo;
private TabFolder tabFolder;
private Tree treeOfBlocks;
private Tree treeOfCritics;
private Tree treeOfRegularity;
private TreeViewer treeOfBlocksViewer;
private TreeViewer treeOfCriticsViewer;
private TreeViewer treeOfRegularityViewer;
//implementation
private Links links;
public Test() {
display = new Display();
shell = new Shell(display);
shell.setText("Test");
createContents(shell, "");
try {
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch()) {
display.sleep();
display.dispose();
} catch (SWTException ex) {
* Creates the main window's contents
* @param shell the main window
* @param location the initial location
private void createContents(Shell shell, String location) {
// Create the web browser
browser = new Browser(shell, SWT.MOZILLA);
// Here I create a button that gets all links from to rendered webpage
// and set them to the 'links'.
// Add browsers event handlers
extractLocListener = new AdvancedLocationListener(url, statusInfo);
statusListener = new AdvancedStatusTextListener(status);
browser.addLocationListener(extractLocListener);
browser.addProgressListener(new AdvancedProgressListener(links));
browser.addStatusTextListener(statusListener);
static class AdvancedLocationListener implements LocationListener {
private Text url;
private Label info;
public AdvancedLocationListener(Text url, Label info) {
// Store the address box for updates
this.url = url;
this.info = info;
public void changing(LocationEvent event) {
// Show the location that's loading
url.setText("Loading ... " + event.location);
public void changed(LocationEvent event) {
// Show the loaded location
url.setText(event.location);
info.setText("Loaded");
public class AdvancedProgressListener implements ProgressListener {
public AdvancedProgressListener(Links links) {
this.links = links;
public void changed(ProgressEvent event) {
public void completed(ProgressEvent event) {
if (links.hasLinks()) {
browser.setUrl(links.getLink());
static class AdvancedStatusTextListener implements StatusTextListener {
public AdvancedStatusTextListener(Label label) {
// Store the label on which to report status
status = label;
public void changed(StatusTextEvent event) {
// Report the status
status.setText(event.text);
new Test();
[Updated on: Wed, 03 March 2010 17:01] by Moderator
Re: browser.setUrl freeze [message #518689 is a reply to message #518545] |
Thu, 04 March 2010 13:30   |
I tried my code on win XP with xulrunner-sdk-1.9.1.3-win32 and swt-3.6M5-win32-x86 and it works fine, no freeze anymmore. All pages are loaded successfully. I dont know if it's OS, xulrunner or swt problem? I tried the snippet below that doesn't use xulrunner and it freezed on kubuntu too. So I guess it is OS or swt problem. What do u think?
final Display display = new Display();
final Shell shell = new Shell(display);
shell.setLayout(new FillLayout());
// pretend the following links were parsed out from the google.com page
final String[] links = {
"http://www.google.com/intl/en/ads/",
"http://www.google.com/services/",
"http://www.google.com/intl/en/about.html",
"http://www.google.com/intl/en/privacy.html"
final Browser browser = new Browser(shell, SWT.NONE);
browser.setUrl("google.com");
browser.addProgressListener(new ProgressAdapter() {
if (++linkIndex > 3) return; // done
String link = links[linkIndex];
System.out.println("changing to " + link);
browser.setUrl(link);
shell.setBounds(10,10,300,300);
shell.open();
if (!display.readAndDispatch()) display.sleep();
display.dispose();
Re: browser.setUrl freeze [message #518717 is a reply to message #518689] |
Thu, 04 March 2010 14:41   |
It's difficult to know where the problem lies without being able to
reproduce the problem and investigate. I would suggest logging a report
with swt (
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Platform &component=SWT )
and including the snippet that hangs. An SWT.NONE-style Browser on Linux
actually does use XULRunner, to find out which one make the snippet's first
line "Device.DEBUG=true;". Be sure to specify your XULRunner version and
linux distro, as the snippet worked for me on 32-bit Ubuntu 9.10.
Grant
"Filip" <filip.pekarek@gmail.com> wrote in message
news:hmou7l$3as$1@build.eclipse.org...
> Hello,
> public static void main(String[] args) {
page
> shell.open();
> display.dispose();
FUDForum. Page generated in 0.04924 seconds
