Home » Eclipse Projects » Standard Widget Toolkit (SWT) » browser.setUrl freeze
browser.setUrl freeze [message #518368] Wed, 03 March 2010 16:59 Go to next message
I have swt.browser with xulrunner (swt-3.6M5-gtk-linux-x86_64, xulrunner-sdk-1.9.1.3-linux-x86_64 - my own build). I render the page and get all links from the page as String[]. Now I want to render all pages the links refer to. So I made my own ProgressListener which takes link one by one and calls browser.setUrl() in its completed method. The trouble is that the rendering freezes. The ProgressListener is not noticed again until I move with the cursor or invoke any other system event. What am I doing wrong? I am not sure if its swt-xulrunner or OS problem? I am using Ubuntu 9.10 x86_64.
Most important part of my code is attached.
Thanks a lot for any help.
My code:
public class Test {
//swt
private Shell shell;
private Display display;
private Label status;
private Browser browser;
private ExtractLocationListener extractLocListener;
private RebuildLocationListener rebuildLocListener;
private AdvancedStatusTextListener statusListener;
private Text url;
private Button backButton;
private Button refreshButton;
private Button forwardButton;
private Button stopButton;
private Button goButton;
private Button extractButton;
private Button rebuildButton;
private Label tabInfo;
private Label statusInfo;
private TabFolder tabFolder;
private Tree treeOfBlocks;
private Tree treeOfCritics;
private Tree treeOfRegularity;
private TreeViewer treeOfBlocksViewer;
private TreeViewer treeOfCriticsViewer;
private TreeViewer treeOfRegularityViewer;
//implementation
private Links links;
public Test() {
display = new Display();
shell = new Shell(display);
shell.setText("Test");
createContents(shell, "");
try {
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch()) {
display.sleep();
display.dispose();
} catch (SWTException ex) {
* Creates the main window's contents
* @param shell the main window
* @param location the initial location
private void createContents(Shell shell, String location) {
// Create the web browser
browser = new Browser(shell, SWT.MOZILLA);
// Here I create a button that gets all links from to rendered webpage
// and set them to the 'links'.
// Add browsers event handlers
extractLocListener = new AdvancedLocationListener(url, statusInfo);
statusListener = new AdvancedStatusTextListener(status);
browser.addLocationListener(extractLocListener);
browser.addProgressListener(new AdvancedProgressListener(links));
browser.addStatusTextListener(statusListener);
static class AdvancedLocationListener implements LocationListener {
private Text url;
private Label info;
public AdvancedLocationListener(Text url, Label info) {
// Store the address box for updates
this.url = url;
this.info = info;
public void changing(LocationEvent event) {
// Show the location that's loading
url.setText("Loading ... " + event.location);
public void changed(LocationEvent event) {
// Show the loaded location
url.setText(event.location);
info.setText("Loaded");
public class AdvancedProgressListener implements ProgressListener {
public AdvancedProgressListener(Links links) {
this.links = links;
public void changed(ProgressEvent event) {
public void completed(ProgressEvent event) {
if (links.hasLinks()) {
browser.setUrl(links.getLink());
static class AdvancedStatusTextListener implements StatusTextListener {
public AdvancedStatusTextListener(Label label) {
// Store the label on which to report status
status = label;
public void changed(StatusTextEvent event) {
// Report the status
status.setText(event.text);
new Test();
[Updated on: Wed, 03 March 2010 17:01] by Moderator
Re: browser.setUrl freeze [message #518423 is a reply to message #518368] Thu, 04 March 2010 00:01 Go to previous messageGo to next message
Do you want the urls to be opened in same browser or in a seperate browser....
What you are doing is opening the url's in the same browser which is providing the urls...
this may result is recursive calls....
Re: browser.setUrl freeze [message #518545 is a reply to message #518423] Thu, 04 March 2010 07:42 Go to previous messageGo to next message
Hi, I want to open all urls in the same browser. The loading of browser's content occurs asynchronously, so it shouldn't be recursive calls. The behaviour is weird, cos when I move the cursor browser loads 1-3 urls and freezes again and so on.. Any suggestions? Thanks.
Re: browser.setUrl freeze [message #518689 is a reply to message #518545] Thu, 04 March 2010 13:30 Go to previous messageGo to next message
I tried my code on win XP with xulrunner-sdk-1.9.1.3-win32 and swt-3.6M5-win32-x86 and it works fine, no freeze anymmore. All pages are loaded successfully. I dont know if it's OS, xulrunner or swt problem? I tried the snippet below that doesn't use xulrunner and it freezed on kubuntu too. So I guess it is OS or swt problem. What do u think?
final Display display = new Display();
final Shell shell = new Shell(display);
shell.setLayout(new FillLayout());
// pretend the following links were parsed out from the google.com page
final String[] links = {
"http://www.google.com/intl/en/ads/",
"http://www.google.com/services/",
"http://www.google.com/intl/en/about.html",
"http://www.google.com/intl/en/privacy.html"
final Browser browser = new Browser(shell, SWT.NONE);
browser.setUrl("google.com");
browser.addProgressListener(new ProgressAdapter() {
if (++linkIndex > 3) return; // done
String link = links[linkIndex];
System.out.println("changing to " + link);
browser.setUrl(link);
shell.setBounds(10,10,300,300);
shell.open();
if (!display.readAndDispatch()) display.sleep();
display.dispose();
Re: browser.setUrl freeze [message #518717 is a reply to message #518689] Thu, 04 March 2010 14:41 Go to previous messageGo to next message
It's difficult to know where the problem lies without being able to
reproduce the problem and investigate. I would suggest logging a report
with swt (
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Platform &component=SWT )
and including the snippet that hangs. An SWT.NONE-style Browser on Linux
actually does use XULRunner, to find out which one make the snippet's first
line "Device.DEBUG=true;". Be sure to specify your XULRunner version and
linux distro, as the snippet worked for me on 32-bit Ubuntu 9.10.
Grant
"Filip" <filip.pekarek@gmail.com> wrote in message
news:hmou7l$3as$1@build.eclipse.org...
> Hello,
> public static void main(String[] args) {
page
> shell.open();
> display.dispose();
Re: browser.setUrl freeze [message #518854 is a reply to message #518717] Fri, 05 March 2010 05:07 Go to previous messageGo to next message
Thanks for reply. So I guess it's my own xulrunner-sdk build problem. I haven't found any build for 64-bit linux so I builded it by myself. Here's the procedure:
1) download source code for xulrunner from http://releases.mozilla.org/pub/mozilla.org/xulrunner/releas es/
2) extract downloaded file to any directory
3) go to extracted directory
4) run: ./configure --enable-application=xulrunner --with-java-bin-path=/usr/lib/jvm/java-6-openjdk/bin/ --with-java-include-path=/usr/lib/jvm/java-6-openjdk/include / --enable-chrome-format=jar --disable-tests
5) install all mising dependencies
6) run: make
Could anybody try it or post me a link for 64bit linux xulrunner release? Thanks a lot.
Re: browser.setUrl freeze [message #518951 is a reply to message #518854] Fri, 05 March 2010 09:32 Go to previous messageGo to next message
It's surprising that your linux distro doesn't come with one. Anyways,
mozilla.org doesn't build 64-bit versions for their releases (I think this
will change soon), but they do build them nightly. The 1.9.1.x stream
should be generally stable, so you're probably safe to try the latest
xulrunner-1.9.1.9 64-bit build from
http://ftp.mozilla.org/pub/mozilla.org/xulrunner/nightly/lat est-mozilla-1.9.1/ .
Grant
news:hmql5r$in5$1@build.eclipse.org...
the procedure:
> 4) run:
../configure --enable-application=xulrunner --with-java-bin-path=/usr/lib/jvm
> 6) run: make
Thanks a lot.
Re: browser.setUrl freeze [message #519519 is a reply to message #518951] Tue, 09 March 2010 03:02 Go to previous message
Using latest nightly xulrunner linux-x86_64 build helped. Now it works fine. Thanks a lot !
[Updated on: Tue, 09 March 2010 03:02] by Moderator
Previous Topic:Filtering lines in StyledText
Next Topic:SWT Combo and disable + colors
Current Time: Sun Jul 27 11:23:24 EDT 2025
Powered by FUDForum. Page generated in 0.25444 seconds
