Home » Archived » Buckminster » [hudson] exported empty packages cause compiler errors
[hudson] exported empty packages cause compiler errors [message #518503] Thu, 04 March 2010 05:19 Go to next message
When building a project (RAP) from binary imported p2 site in Hudson, empty packages will cause compiler errors, e.g.:
Error: file C:\hudson\jobs\test-build\workspace\plugins\org.eclipse.rap. jface\META-INF\MANIFEST.MF, line 15: Package 'org.eclipse.jface.bindings.keys' does not exist in this plug-in
Manual builds (PDE) work.
Is there anything I can set (in hudson/buckminster) to ignore this?
Re: [hudson] exported empty packages cause compiler errors [message #518513 is a reply to message #518503] Thu, 04 March 2010 05:34 Go to previous messageGo to next message
Hi Erdal,
I think the error you get here stems from the PDE compiler. You can control the severity of this error and many other
compiler errors using a workspace template. I.e.
1. Start your IDE on a new workspace.
2. Configure the preferences using the normal preferences dialog, i.e. "Window" -> "Preferences" -> "Plug-in
Development" -> "Compilers"
3. Exit the IDE.
4. Create a zip from the workspace root and use this zip as -T <zip file> when you import.
HTH,
- thomas
Re: [hudson] exported empty packages cause compiler errors [message #518524 is a reply to message #518503] Thu, 04 March 2010 06:41 Go to previous messageGo to next message
I modified the build job:
import -T http://localhost/development/metadata.zip
import http://localhost/development/app.cquery
It complains:
import '-T' 'http://localhost/development/metadata.zip'
Missing BOM URL
Help text for org.eclipse.buckminster.core.import:This command will populate the workspace from a Bill of Materials (BOM)
The metadata.zip zip archive contains the .metada folder of my newly created workspace...
What am I missing?
Re: [hudson] exported empty packages cause compiler errors [message #518527 is a reply to message #518503] Thu, 04 March 2010 06:54 Go to previous messageGo to next message
ok, my fault, should be:
import -T http://localhost/development/metadata.zip http://localhost/development/app.cquery
But still complaining:
Doing full workspace refresh
Waiting for jobs to end
Workspace at C:\hudson\jobs\app\workspace is not empty
Finished: FAILURE
Re: [hudson] exported empty packages cause compiler errors [message #518537 is a reply to message #518527] Thu, 04 March 2010 07:07 Go to previous messageGo to next message
Hi Erdal,
Is the workspace originally empty? That's a prerequisite for using a template.
- thomas
> Finished: FAILURE
Re: [hudson] exported empty packages cause compiler errors [message #518541 is a reply to message #518503] Thu, 04 March 2010 07:29 Go to previous message
Yes, the workspace is removed, first.
I am using this version:
org.eclipse.buckminster.core_1.1.350.r10861.jar
Do I have to use the latest buckminster?
Re: [hudson] exported empty packages cause compiler errors [message #518549 is a reply to message #518541] Thu, 04 March 2010 03:04 Go to previous message
Are you issuing any commands prior to the import such as setpref? If you do, that won't work since it first creates a
workspace where it can store the preference.
No, there has been a couple of updates since then but none that is relevant to this problem.
- thomas
Previous Topic:My jar files (build through buckminster) do not contain .class files with latest buckminster
Next Topic:Wiki page describing eclipse.org Teneo build setup using Buckminster
Current Time: Sat Nov 01 17:03:55 EDT 2025
Powered by FUDForum. Page generated in 0.05301 seconds
