Home » Eclipse Projects » JFace » DataBinding DateTime?
DataBinding DateTime? [message #516690] Wed, 24 February 2010 09:10 Go to next message
What is the correct method for databinding a DateTime ?
Are there any snippets, or documentation, available ?
Charlie
Re: DataBinding DateTime? [message #518428 is a reply to message #516690] Wed, 03 March 2010 20:00 Go to previous messageGo to next message
This should work for you:
bindingContext.bindValue(WidgetProperties.selection().observ e(dateTime),
modelObservable);
or
bindingContext.bindValue(SWTObservables.observeSelection(dat eTime),
modelObservable);
See also DateAndTimeObservableValue if you have separate widgets for
date and time, and you need to combine the date and time components into
a single timestamp-style observable.
Hope this helps,
Matthew
> Thanks
> Charlie
Re: DataBinding DateTime? [message #518676 is a reply to message #518428] Thu, 04 March 2010 12:44 Go to previous message
Hi Matthew,
Yes, this helps.
Thank you
Charlie
> modelObservable);
> or
> modelObservable);
> Hope this helps,
> Matthew
>> Thanks
>> Charlie
Previous Topic:[Databinding] binding to sub objects
Next Topic:[Databinding] Transform Boolean value bound to checkbox control into string and save it as a map val
Current Time: Wed Jul 23 12:26:55 EDT 2025
Powered by FUDForum. Page generated in 0.24379 seconds
