Re: My jar files (build through buckminster) do not contain .class files with latest buckminster [message #518461 is a reply to message #518403] |
Thu, 04 March 2010 03:11  |
Thanks for the quick help! Works fine now.
gr. Martin
Thomas Hallgren wrote:
> I found the cause. It was an API change in the JavaProject class that
> went unnoticed since we for historical reasons called the affected
> method using reflection. It's fixed in the latest published build.
> - thomas
> On 03/03/2010 11:26 PM, Thomas Hallgren wrote:
>> Hi Martin,
>> Something is definitely broken with the latest Buckminster build. I'm
>> investigating...
>> - thomas
>> On 03/03/2010 06:36 PM, Martin Taal wrote:
>>> Hi,
>>> I have the strange problem that with the latest buckminster version the
>>> jar files I build do not contain class files.
>>> The class files are build, see here:
>>> https://build.eclipse.org/hudson/job/emf-teneo-nightly/ws/bu ild/build/workspace/plugins/org.eclipse.emf.teneo/bin/org/ec lipse/emf/teneo/
>>> But they are not present in the jar files created by the site commamnd,
>>> see this example:
>>> https://build.eclipse.org/hudson/job/emf-teneo-nightly/ws/bu ild/output/org.eclipse.emf.teneo_1.1.2-osgi.bundle/jar/org.e clipse.emf.teneo_1.1.2.v201003031643.jar
>>> My feel is that this started to happen with the latest buckminster
>>> revision, It worked fine before with these versions:
>>> [java] Installing org.eclipse.buckminster.cmdline.product 1.2.0.r11238.
>>> [java] Installing
>>> org.eclipse.buckminster.core.headless.feature.feature.group
>>> 1.3.0.r11238.
>>> [java] Installing
>>> org.eclipse.buckminster.pde.headless.feature.feature.group 1.2.0.r11237.
>>> [java] Installing
>>> org.eclipse.buckminster.cvs.headless.feature.feature.group 1.1.0.r11210.
>>> [java] Installing
>>> org.eclipse.buckminster.emma.headless.feature.feature.group
>>> 0.9.0.r11210.
>>> and it fails with these versions:
>>> [java] Installing org.eclipse.buckminster.cmdline.product 1.2.0.r11245.
>>> [java] Installing
>>> 1.3.0.r11245.
>>> [java] Installing
>>> org.eclipse.buckminster.pde.headless.feature.feature.group 1.2.0.r11245.
>>> [java] Installing
>>> [java] Installing
>>> 0.9.0.r11210.
>>> See the build https://build.eclipse.org/hudson/job/emf-teneo-nightly
>>> I am not sure if it is a buckminster issue though...
>>> Does anyone have a clue what happens here?
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
FUDForum. Page generated in 0.49382 seconds
