Home » Modeling » EMF » [Teneo+EMF] Meet-in-the-Middle mapping
[Teneo+EMF] Meet-in-the-Middle mapping [message #517942] |
Tue, 02 March 2010 10:11  |
Before I start, I wish to confess, I'm a newbie in EMF (Please correct me if I'm wrong).
Let me briefly describe the situation:
PostgreSQL server is running at the backend with an already existing database in it, on one hand.
On the other hand, I have been given 8 EPackages as 8 .ecore files with each depending on each other.
Until now I found Teneo offering choices like 1)using Hibernate with .hbm.xml file, 2)using Eclipselink with orm.xml file, 3)using CDO+teneo with <persistence-mapping>, to map with the database.
I have a feeling (from some teneo tutorials I tried) that all these choices, creates its own tables for appropriate EClasses in the database rather than giving us control to perform mapping between an EClass and an 'Existing' table in a database.
Is there a technique for doing meet-in-the-middle mapping from teneo?
If they are available,
1)Is it possible to apply that technique for the situation I hinted before?
2)Is there an example or tutorial I can find?
Re: [Teneo+EMF] Meet-in-the-Middle mapping [message #517956 is a reply to message #517942] |
Tue, 02 March 2010 10:22   |
Hi Sudeep,
Teneo is mostly for top-down mapping. You can generate a hbm.xml/orm.xml file quite easily and then customize it to fit
to the database schema you currently have. But this is a manual task and currently not supported by tooling.
gr. Martin
Sudeep wrote:
> me if I'm wrong).
> If they are available, 1)Is it possible to apply that technique for the
> situation I hinted before? 2)Is there an example or tutorial I can find?
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo+EMF] Meet-in-the-Middle mapping [message #518218 is a reply to message #517956] |
Wed, 03 March 2010 09:06   |
Hello Martin,
Thanks for the reply. Well, I tried like you said; in this case, I have an existing database with less than 150 Tables in it.
For simplicity, I just picked one table called 'users' which was created with the following:
CREATE TABLE users
dtype character varying(31) NOT NULL,
id bigint NOT NULL,
active boolean,
autologin boolean NOT NULL,
firstname character varying(255),
lastname character varying(255),
e_id bigint,
CONSTRAINT users_pkey PRIMARY KEY (id),
On the other side, from the 8 ecore file's generated *.impl java packages, I picked one implementation class
public class NaturalPersonImpl extends EObjectImpl implements NaturalPerson {
I just planned to map the column 'firstname' in 'users' table with the 'firstName' attribute of the implementation class 'NaturalPersonImpl'
Selecting all the 8 ecore files, I generated a *.hbm file which had a big pile of mappings in it. As mentioned above, for simplicity, I just picked the
NaturalPersonimpl and its parent class from the generated-hbm.xml altered a bit which look like:
<!DOCTYPE hibernate-mapping PUBLIC "-//Hibernate/Hibernate Mapping DTD 3.0//EN" "http://hibernate.sourceforge.net/hibernate-mapping-3.0.dtd">
<hibernate-mapping schema="public" auto-import="false">
<class name="foundation.IdentifiableElement" entity-name="IdentifiableElement" abstract="true" lazy="false" discriminator-value="IdentifiableElement">
<meta attribute="eclassName">IdentifiableElement</meta>
<meta attribute="epackage">http://foundation/1.0</meta>
<id type="long" name="e_id" column="e_id" access=" org.eclipse.emf.teneo.hibernate.mapping.identifier.Identifie rPropertyHandler ">
<meta attribute="syntheticId">true</meta>
<generator class="native"/>
</id>
<discriminator type="string">
<column name="dtype" index="identifiableelementdtype" length="255" not-null="true"/>
</discriminator>
<version name="e_version" column="e_version" access=" org.eclipse.emf.teneo.hibernate.mapping.property.VersionProp ertyHandler ">
<meta attribute="syntheticVersion">true</meta>
</version>
<property name="guid" lazy="false" insert="true" update="true" not-null="true" unique="false" type="java.lang.String">
<column not-null="true" unique="false" name="`guid`"/>
</property>
<property name="namespace" lazy="false" insert="true" update="true" not-null="false" unique="false" type="java.lang.String">
<column not-null="false" unique="false" name="`namespace`"/>
</property>
</class>
<subclass name="foundation.impl.NaturalPersonImpl" entity-name="NaturalPerson" abstract="false" lazy="false" extends="IdentifiableElement" discriminator-value="NaturalPerson">
<meta attribute="eclassName">NaturalPerson</meta>
<join table="`users`">
<key column="e_id"/>
<property name="firstName" lazy="false" insert="true" update="true" not-null="false" unique="false" type="java.lang.String">
<column not-null="false" unique="false" name="`firstname`"/>
</property>
</join>
</subclass>
</hibernate-mapping>
With the .cfg.xml file configured, I ran the code:
Transaction tx = null;
Session session = SessionFactoryUtil.getInstance().openSession();
Query query = session.createQuery("SELECT s FROM NaturalPerson s");
List<NaturalPerson> natp1 = query.list();
NaturalPerson natp2 = natp1.get(1);
System.out.println(natp2.getFirstName());
This threw me an error as follows:
03.03.2010 14:29:34 org.slf4j.impl.JCLLoggerAdapter info
INFO: Hibernate Annotations 3.4.0.GA
INFO: Hibernate 3.3.2.GA
INFO: Configuration resource: /hibernate.cfg.xml
INFO: Reading mappings from resource : com/sap/usdl3/queries/hibernate.hbm.xml
INFO: using driver: org.postgresql.Driver at URL: jdbc:postgresql://localhost:5432/cdoago
03.03.2010 14:29:35 org.slf4j.impl.JCLLoggerAdapter info
INFO: schema update complete
Hibernate: select naturalper0_.e_id as e1_0_, naturalper0_.e_version as e3_0_, naturalper0_."guid" as guid4_0_, naturalper0_."namespace" as namespace5_0_, naturalper0_1_."firstname" as firstname2_1_ from public.IdentifiableElement naturalper0_ inner join public."users" naturalper0_1_ on naturalper0_.e_id=naturalper0_1_.e_id where naturalper0_.dtype='NaturalPerson'
Exception in thread "main" java.lang.IndexOutOfBoundsException: Index: 1, Size: 0
at java.util.ArrayList.RangeCheck(ArrayList.java:546)
at java.util.ArrayList.get(ArrayList.java:321)
at foundation.impl.CoreTesting.updateService(CoreTesting.java:4 1)
at foundation.impl.CoreTesting.main(CoreTesting.java:31)
Any idea would be helpful.
Re: [Teneo+EMF] Meet-in-the-Middle mapping [message #518232 is a reply to message #518218] |
Wed, 03 March 2010 09:39   |
Hi Sundeep,
And when you execute this sql directly then you get results?
Also (not directly related to this issue I think), to be sure, the session factory is created using a Teneo datastore,
right?
gr. Martin
Sudeep wrote:
> Hello Martin,
> with the following:
> CREATE TABLE users
> dtype character
> id bigint NOT NULL,
> active boolean,
> autologin boolean
> NOT NULL,
> firstname
> lastname character
> varying(255),
> e_id bigint,
> CONSTRAINT
> NaturalPerson {
> picked the NaturalPersonimpl and its parent class from the
> rPropertyHandler ">
> </id>
> </discriminator>
> </version>
> </property>
> </property>
> </class>
> </property>
> </join>
> </subclass>
> NaturalPerson s");
> 1, Size: 0
The Netherlands
Re: [Teneo+EMF] Meet-in-the-Middle mapping [message #518271 is a reply to message #518232] |
Wed, 03 March 2010 11:09   |
Hello Martin,
a) Previous time, I did'nt use a Teneo data store. So, now I used the data store, with the same *cfg.xml and *.hbm.xml file for manual mapping.
But, this time
--> it is looking for 'hibernate.properties' file instead of *.cfg.xml file
03.03.2010 16:51:50 org.slf4j.impl.JCLLoggerAdapter info
INFO: hibernate.properties not found
--> eventually without the use of *.hbm.xml file, it is automatically mapping.
03.03.2010 16:51:50 org.eclipse.emf.teneo.classloader.ClassLoaderResolver setClassLoaderStrategy
INFO: Class loader strategy set to: org.eclipse.emf.teneo.classloader.ContextClassLoaderStrategy
INFO: Mapping class: NamedElement -> namedelement
INFO: Mapping collection: NamedElement.synonyms -> namedelement_synonyms
and gave me an exception for the non-availability of hibernate.properties file:
Exception in thread "main" org.hibernate.HibernateException: 'hibernate.dialect' must be set when no Connection avalable
at org.hibernate.dialect.resolver.DialectFactory.buildDialect(D ialectFactory.java:107)
at org.hibernate.cfg.SettingsFactory.buildSettings(SettingsFact ory.java:138)
at org.hibernate.cfg.Configuration.buildSettingsInternal(Config uration.java:2119)
at org.hibernate.cfg.Configuration.buildSettings(Configuration. java:2115)
at org.hibernate.cfg.Configuration.buildSessionFactory(Configur ation.java:1339)
at org.eclipse.emf.teneo.hibernate.HbSessionDataStore.buildSess ionFactory(HbSessionDataStore.java:205)
at org.eclipse.emf.teneo.hibernate.HbSessionDataStore.initializ e(HbSessionDataStore.java:90)
b) Next, I included the 'hibernate.properties file'
03.03.2010 16:59:54 org.slf4j.impl.JCLLoggerAdapter info
INFO: loaded properties from resource hibernate.properties: {hibernate.connection.username=cdo_user, hibernate.connection.password=****, hibernate.dialect=org.hibernate.dialect.PostgreSQLDialect, hibernate.connection.url=jdbc:postgresql://localhost/test, hibernate.bytecode.use_reflection_optimizer=false, hibernate.connection.driver_class=org.postgresql.Driver, hibernate.hbm2ddl.auto=true}
like I specified in *.cfg.xml file, there is no choice(or I'm missing it?!) for putting 'mapping resource' in hibernate.properties file, Teneo again maps
automatically like before and this time I received an Exception as follows:
03.03.2010 16:59:57 org.slf4j.impl.JCLLoggerAdapter info
INFO: indexes: [yearrange_weekranges_pkey]
at foundation.impl.CoreTesting.updateService(CoreTesting.java:5 7)
at foundation.impl.CoreTesting.main(CoreTesting.java:40)
Code reference:
SessionFactory fsession = foundationds.getSessionFactory();
Session session = fsession.openSession();
session.beginTransaction();
Dependencies:
Require-Bundle: org.eclipse.core.runtime,
org.eclipse.emf.ecore;visibility:=reexport,
org.eclipse.emf.ecore.xmi;visibility:=reexport,
com.springsource.antlr;bundle-version="2.7.7",
com.springsource.javax.transaction;bundle-version="1.1.0",
com.springsource.org.apache.commons.collections;bundle-versi on= "3.2.0",
com.springsource.org.apache.commons.logging;bundle-version="1.1.1 ",
com.springsource.org.dom4j;bundle-version="1.6.1",
com.springsource.org.hibernate;bundle-version="3.3.2",
com.springsource.org.postgresql.jdbc3;bundle-version="8.3.603 ",
javax.activation;bundle-version="1.1.0",
javax.xml.stream;bundle-version="1.0.1",
org.eclipse.emf.teneo.hibernate;bundle-version="1.1.1",
slf4j.api;bundle-version="1.5.8",
javax.persistence;bundle-version="1.99.0",
org.apache.lucene;bundle-version="1.9.1"
Re: [Teneo+EMF] Meet-in-the-Middle mapping [message #518279 is a reply to message #518271] |
Wed, 03 March 2010 11:24   |
Hi Sudeep,
The mapping file is passed in as a property to Teneo, this should be done programmatically currently. You can write your
own property-reader to read properties from a file to pass them into Teneo.
To detect if it is a problem in Teneo/Hibernate with the mapping or the data. Can you execute this query directly in a
database explorer (in the database):
does this this return anything? If not then you need to check why it doesn't, my guess is that it has to do with the
inner join or the dtype clause.
gr. Martin
Sudeep wrote:
> Hello Martin,
> mapping. But, this time
> *.cfg.xml file
> 03.03.2010 16:51:50
> ory.java:138)
> uration.java:2119)
> java:2115)
> ation.java:1339)
> again maps
> 1, Size: 0
> Code reference:
> Dependencies:
The Netherlands
Re: [Teneo+EMF] Meet-in-the-Middle mapping [message #518485 is a reply to message #518477] |
Wed, 03 March 2010 23:44   |
Hi Sudeep,
There is a mapping between the Eclass and the table. The question is only if the resulting query is what you want.
This is the query generated by hibernate:
The problem that nothing is returned can be one of:
1) the where clause: naturalper0_.dtype='NaturalPerson', does the dtype column indeed contain a NaturalPerson value?
2) inner join public."users" naturalper0_1_ on naturalper0_.e_id=naturalper0_1_.e_id
are there records in IdentifiableElement and users which have an e_id with the same value?
if 1) is the problem then the dtype name can be changed using a @DiscriminatorValue annotation.
if 2) is the problem then you need to check how the join between the two tables should be done (which columns should be
used) and change the mapping accordingly.
gr. Martin
Sudeep wrote:
> yes Martin, 0 Zeilen=0 Rows.
> Well, I thought that a jdbc connection will be established between the
> EClass 'NaturalPerson' and the Table 'users', so all the data in 'users'
> table will be made available at the EClass 'NaturalPerson' too.
> If I'm right with the preceding sentence, having now 0 results, I guess
> there is no mapping established between the EClass and table.
> I must figure out where I'm making mistake and will update you soon.
The Netherlands
Re: [Teneo+EMF] Meet-in-the-Middle mapping [message #521366 is a reply to message #518494] |
Wed, 17 March 2010 08:37   |
Hello Martin,
Sorry for the delayed reply. It took some time to try out other Hibernate Inheritance mapping strategies.
With the JOINED inheritance strategy, in my case, the Identifier Generator (by default: generator class: native, I tried others too, but sadly no change)did'nt generate Primary Key/e_id for the superclass table and so consequently, there were no Foreign Key generated in the subclass table, hence it didnt allow persistence, returning null values.
I did'nt wanted SINGLE_TABLE strategy because, in my case I need separate tables for the subclasses.
In the end, I tried with the TABLE_PER_CLASS strategy and it worked! It generated the identifier in the existing subclass table from the next free row and persisted.
Thanks Martin, once again for the useful tips.
Also, I would like to know if you have published some papers(like articles, proceedings in conference) regarding 'Model-Relational Mapping' or Teneo, so that I can get better theoretical knowledge too.
Re: [Teneo+EMF] Meet-in-the-Middle mapping [message #521379 is a reply to message #521366] |
Wed, 17 March 2010 09:09  |
Hi Sudeep,
Good that it works!
I think that the best place for information is the Teneo wiki which is quite extensive:
http://wiki.eclipse.org/Teneo/Hibernate
with this specific part on model relational mapping:
http://wiki.eclipse.org/Teneo/Hibernate/ModelRelational
gr. Martin
Sudeep wrote:
> Hello Martin,
The Netherlands
Current Time: Sat Sep 13 11:30:12 EDT 2025
Powered by FUDForum. Page generated in 0.04659 seconds
