Home » Archived » EPF » Loading EPF libraries outside of EPF
Loading EPF libraries outside of EPF [message #518177] Wed, 03 March 2010 06:12 Go to next message
Originally posted by: Patrick.Schoenbach.robustsoft.de
I am to write a program that analyzes EPF libraries and that generates
some reports from these analyzes. Preferably, the program should run
independently from Eclipse?
How can I load the EPF library models? Would it be necessary or possible
to reuse some EPF code?
Patrick
Re: Loading EPF libraries outside of EPF [message #524750 is a reply to message #518177] Fri, 02 April 2010 05:59 Go to previous messageGo to next message
Hello Patrick,
I'm working on a similar project. And am still in the research phase. So far I've come to know a few things. The following is what i've realised so far.
I've built the application using Eclipse plugin Development + RCP.
And to read the library, I've set the target platform to EPF Composer, So that the plugins are available for import.
I'll be importing those plugins related with the library ,and using the already defined methods, I can open the library.
Will let you know my progress. Also, any help from your side will be most appreciated.
Anup Chaudhari.
Re: Loading EPF libraries outside of EPF [message #599316 is a reply to message #518177] Fri, 02 April 2010 05:59 Go to previous message
Hello Patrick,
Anup Chaudhari.
Previous Topic:EPF model transformation problem with Multi file xmi resources
Next Topic:EPF and Eclipse capababilities
Current Time: Sat Jul 26 20:22:24 EDT 2025
Powered by FUDForum. Page generated in 0.03601 seconds
