Home » Modeling » TMF (Xtext) » eOpposite with xtext(I 'd like to introduce an eOpposite with xtext)
eOpposite with xtext [message #517948] Tue, 02 March 2010 10:20 Go to next message
I 'd like to introduce an eOpposite relation
like in the model in the picture.
please help me.
http://img35.imageshack.us/img35/7070/capturepe.png
[Updated on: Tue, 02 March 2010 10:21] by Moderator
Re: eOpposite with xtext [message #517954 is a reply to message #517948] Tue, 02 March 2010 10:34 Go to previous messageGo to next message
Why dont you just use eContainer()?
e.g:
Arc:
'arc' 'weight' weight = INT
'kind' kind = ArcKind
'outgoings' '{' outgoings += [Node]* '}'
Node:
'node' name = ID
if you invoke eContainer() on a Node in something like a Validator, you would get a reference to its Arc
Re: eOpposite with xtext [message #517962 is a reply to message #517954] Tue, 02 March 2010 10:40 Go to previous messageGo to next message
thank you
but
wih your solution , you can't introduce a join between outcomings and source.
we should have a relation between outcomings and source,
also I dont like in the textual model introduce these outcomings.
[Updated on: Tue, 02 March 2010 10:43] by Moderator
Re: eOpposite with xtext [message #517965 is a reply to message #517948] Tue, 02 March 2010 10:42 Go to previous messageGo to next message
i'm just trying to resolve a such problem, i've changed the Xpand in my way but not xtext there's always problems in it..
is there someone who has an example in which he transformes eOposite into xText ??
Re: eOpposite with xtext [message #518065 is a reply to message #517965] Tue, 02 March 2010 17:15 Go to previous message
Hi everybody,
it is recommended to use imported metamodels if you want to use opposite
references. If you want to stick with generated metamodels, have a look
at the Xtext FAQ to learn about the post processor:
http://wiki.eclipse.org/Xtext/FAQ#How_can_I_control_the_Xtex t_meta_model_inference.C2.A0.3F
Please note the emf contract that both sides of the referenced have to
exist in the concrete syntax because it is required to create a proxy
for either of them.
See also https://bugs.eclipse.org/bugs/show_bug.cgi?id=282486
Sebastian
Am 02.03.10 16:42, schrieb tunisiano:
> into xText ??
> Thanks
Previous Topic:Xtext: Howto define function calls AND parentheses
Next Topic:Problem with imports when parsing inside a standalone java class
Current Time: Thu Sep 25 12:22:09 EDT 2025
Powered by FUDForum. Page generated in 0.05709 seconds
