installJRE and IBM j9 [message #517832] |
Tue, 02 March 2010 00:06  |
does Bucky (installJRE) support non Sun JDKs, e.g. CDC1.x/Foundation1.x.
With IBM j9 Bucky throws an exception. Pointing to the .ee (Execution
Environment) file directly doesn't help either.
ecf2:/opt/toolbox/eclipse.org/buckminster/r11191 # ./buckminster
installJRE --location /opt/toolbox/ibm.com/j9/j9_6.1.1.20061110-161633/
ERROR: Exception occurred executing command line.
org.eclipse.core.runtime.CoreException: Exception occurred executing
command line.
at org.eclipse.debug.core.DebugPlugin.exec(DebugPlugin.java:814 )
at
org.eclipse.jdt.internal.launching.StandardVMType.generateLi braryInfo(StandardVMType.java:500)
at
org.eclipse.jdt.internal.launching.StandardVMType.getLibrary Info(StandardVMType.java:122)
at
org.eclipse.jdt.internal.launching.StandardVMType.getDefault LibraryLocations(StandardVMType.java:290)
at
org.eclipse.jdt.internal.launching.StandardVMType.canDetectD efaultSystemLibraries(StandardVMType.java:140)
at
org.eclipse.jdt.internal.launching.StandardVMType.validateIn stallLocation(StandardVMType.java:452)
at
org.eclipse.buckminster.jdt.commands.InstallJRE.internalRun( InstallJRE.java:82)
at
org.eclipse.buckminster.core.commands.WorkspaceCommand.run(W orkspaceCommand.java:191)
at
org.eclipse.buckminster.cmdline.AbstractCommand.basicRun(Abs tractCommand.java:155)
at org.eclipse.buckminster.cmdline.Headless.run(Headless.java:3 41)
at org.eclipse.buckminster.cmdline.Headless.run(Headless.java:1 35)
at org.eclipse.buckminster.cmdline.Headless.start(Headless.java :189)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at
at
at java.lang.reflect.Method.invoke(Method.java:585)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
Caused by: java.io.IOException: java.io.IOException:
/opt/toolbox/ibm.com/j9/j9_6.1.1.20061110-161633/bin/j9: cannot execute
at java.lang.UNIXProcess.<init>(UNIXProcess.java:148)
at java.lang.ProcessImpl.start(ProcessImpl.java:65)
at java.lang.ProcessBuilder.start(ProcessBuilder.java:451)
at java.lang.Runtime.exec(Runtime.java:591)
at java.lang.Runtime.exec(Runtime.java:507)
at org.eclipse.debug.core.DebugPlugin.exec(DebugPlugin.java:808 )
... 24 more
The directory layout of the j9 is like:
ecf2:/opt/toolbox/ibm.com/j9/j9_6.1.1.20061110-161633 # ls -la
total 36
drwxr-xr-x 6 root root 4096 Jan 22 2009 .
drwxr-xr-x 3 root root 4096 Jan 22 2009 ..
-rw-r--r-- 1 mkuppe cimasters 939 Jan 22 2009 CDC1-1_Foundation1-1.ee
drwxr-xr-x 5 mkuppe cimasters 4096 Jan 22 2009 bin
-rw-r--r-- 1 mkuppe cimasters 710 Nov 10 2006 buildinfo.xml
-rw-r--r-- 1 mkuppe cimasters 222 Nov 10 2006 copyright.txt
drwxr-xr-x 2 mkuppe cimasters 4096 Jan 22 2009 doc
drwxr-xr-x 2 mkuppe cimasters 4096 Jan 22 2009 examples
drwxr-xr-x 4 mkuppe cimasters 4096 Jan 22 2009 lib
Markus
P.S.: I assume http://www.eclipse.org/forums/index.php?t=tree&th=162762
has been missed.
Re: installJRE and IBM j9 [message #517870 is a reply to message #517833] |
Tue, 02 March 2010 02:08  |
Originally posted by: news.eclipse.org.08.lemmster.de
On 03/02/2010 10:29 AM, Thomas Hallgren wrote:
> Hi Markus,
> We just call on the jdt the same way the IDE does when you install a JRE
> there. Can you install the JRE in question using the IDE? From the looks
> of it, an attempt is made to execute some unix command. Is the JRE
> you're using runnable on the platform where you attempt the install?
The same JRE works perfectly in the IDE when set up via "Execution
Environment Description" and pointing to the .ee file.
Markus
Re: installJRE and IBM j9 [message #517871 is a reply to message #517870] |
>> Hi Markus,
Very odd. AFAICS, the IDE calls the exact same function to install the JRE. I suggest you raise a bug against JDT where
you attach the stack-trace.
Thomas Hallgren
FUDForum. Page generated in 0.25555 seconds
