Home » Archived » Buckminster » Wiki page describing eclipse.org Teneo build setup using Buckminster
| Re: Wiki page describing eclipse.org Teneo build setup using Buckminster [message #518083 is a reply to message #518062] |
Tue, 02 March 2010 18:26   |
Hi Achim,
Thanks, with script, you mean ant script? So if one ant script/target does several 'emma' calls then it should work?
gr. Martin
Achim Demelt wrote:
> Hi Martin,
> That's a great resource for anyone trying to adopt Buckminster for their own
> projects. Cool!
> I noticed that you're running multiple emma calls, but Hudson (and most
> other CI servers) only accepts one coverage output result, which loses most
> of your coverage output. Well, there's a remedy for that if you can perform
> all "emma" invocations in a row inside a script. You'll have to pass the "-
> m" parameter (for merge) to all but the first emma call. The last call to
> emma should have the --xml option to actually produce the overall coverage
> output.
> As I said, you have to perform all emma calls inside a script, because the
> coverage state gets lost when the VM shuts down.
> HTH,
> Achim
> Martin Taal wrote:
>> Hi,
>> I wrote a fairly detailed wiki page on the build setup of Teneo using
>> Buckminster.
>> I hope it is of interest/help for other people to:
>> http://wiki.eclipse.org/Teneo/Teneo_Build_Setup
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
| Re: Wiki page describing eclipse.org Teneo build setup using Buckminster [message #518345 is a reply to message #518083] |
Wed, 03 March 2010 15:28   |
No, I mean Buckminster script. That's just a file that contains multiple
Buckminster commands. It can be passed to Buckminster via the "--scriptfile"
argument. For example, my script looks like this:
import config/tests.cquery
build
emma -l test.engine.all/engine.all.launch -o ${out.dir}/TEST-engine.all.xml
emma -m -l test.engine.all/engine.all.plugin.launch -o ${out.dir}/TEST-
engine.all.plugin.xml --html ${out.dir}/coverage/coverage.html --xml
${out.dir}/coverage/coverage.xml
Note the "-m" argument for the second "emma" call. It merges the coverage
results with those from the preceding "emma" call.
HTH,
Achim
Martin Taal wrote:
> Hi Achim,
> gr. Martin
> Achim Demelt wrote:
>> Hi Martin,
>> own projects. Cool!
>> most of your coverage output. Well, there's a remedy for that if you can
>> perform all "emma" invocations in a row inside a script. You'll have to
>> pass the "- m" parameter (for merge) to all but the first emma call. The
>> last call to emma should have the --xml option to actually produce the
>> overall coverage output.
>> the coverage state gets lost when the VM shuts down.
>> HTH,
>> Achim
>> Martin Taal wrote:
>>> Hi,
>>> Buckminster.
| Re: Wiki page describing eclipse.org Teneo build setup using Buckminster [message #518363 is a reply to message #518345] |
Wed, 03 March 2010 16:10   |
Thanks Achim, clear now, I have made a note of this in the wiki doc also.
In Teneo's case the code coverage is less usefull at the moment (but maybe you know a solution :-). Teneo uses a two
step build process:
1) build the core plugins and create an update site with them
2) create a new workspace and target platform for the test plugins. The plugins/update site from step 1 are included in
the target platform, then build the test plugins and run tests
As my main plugins are in the target platform emma does not include them in the code coverage part. Is there a way to
tell emma to also include part of the target platform into the code coverage analysis?
For example by specifying package names or plugin id's or anything else.
I choose this build setup because then the tests are run against the exact binaries/jar files/plugins downloaded by users.
gr. Martin
> build
> HTH,
> Achim
> Martin Taal wrote:
>> Hi Achim,
>> gr. Martin
>> Achim Demelt wrote:
>>> Hi Martin,
>>> own projects. Cool!
>>> HTH,
>>> Achim
>>> Martin Taal wrote:
>>>> Hi,
>>>> Buckminster.
The Netherlands
| Re: Wiki page describing eclipse.org Teneo build setup using Buckminster [message #518695 is a reply to message #518363] |
Thu, 04 March 2010 09:04   |
Hi Martin,
I haven't tried this myself, but you may want to take a look at the
"Coverage" tab in the launch configuration in the IDE. You should have a
workspace similar to the one you're using for your headless tests, i.e. only
test bundles as source, and the actual bundles to test as binaries in your
TP. I think you can then select the binary bundles for coverage analysis.
But, as I said, I haven't tried this myself.
Achim
> you know a solution :-). Teneo uses a two step build process:
> plugins/update site from step 1 are included in the target platform, then
> in the code coverage part. Is there a way to tell emma to also include
> part of the target platform into the code coverage analysis? For example
> gr. Martin
>> "--scriptfile" argument. For example, my script looks like this:
>> build
>> ${out.dir}/TEST-engine.all.xml emma -m -l
>> HTH,
>> Achim
>> Martin Taal wrote:
>>> Hi Achim,
>>> gr. Martin
>>> Achim Demelt wrote:
>>>> Hi Martin,
>>>> their own projects. Cool!
>>>> can perform all "emma" invocations in a row inside a script. You'll
>>>> have to pass the "- m" parameter (for merge) to all but the first emma
>>>> call. The last call to emma should have the --xml option to actually
>>>> produce the overall coverage output.
>>>> HTH,
>>>> Achim
>>>> Martin Taal wrote:
>>>>> Hi,
>>>>> Buckminster.
| Re: Wiki page describing eclipse.org Teneo build setup using Buckminster [message #518730 is a reply to message #518695] |
Thu, 04 March 2010 15:23  |
Hi Achim,
Okay thanks, I will check it out.
gr. Martin
Achim Demelt wrote:
> Hi Martin,
> Cheers,
> Achim
>> gr. Martin
>>> build
>>> HTH,
>>> Achim
>>> Martin Taal wrote:
>>>> Hi Achim,
>>>> gr. Martin
>>>> Achim Demelt wrote:
>>>>> Hi Martin,
>>>>> HTH,
>>>>> Achim
>>>>> Martin Taal wrote:
>>>>>> Hi,
>>>>>> Buckminster.
The Netherlands
Current Time: Fri Nov 07 22:05:56 EST 2025
Powered by FUDForum. Page generated in 0.05047 seconds
